int | IsInDomain (vtkSMProperty *property) override |
| Returns true if the value of the propertyy is in the domain. More...
bool | IsInDomain (unsigned int idx, T val) |
| Returns true if the double (val) is in the domain. More...
T | GetMinimum (unsigned int idx, int &exists) |
| Return a min. More...
T | GetMaximum (unsigned int idx, int &exists) |
| Return a max. More...
int | GetResolution () |
| Returns a resolution. More...
bool | GetResolutionExists () |
| Returns if a resolution is set for the domain. More...
T | GetMinimum (unsigned int idx) |
| Returns the minimum/maximum value, is exists, otherwise 0 is returned. More...
T | GetMaximum (unsigned int idx) |
unsigned int | GetNumberOfEntries () |
| Returns the number of entries in the internal maxima/minima list. More...
void | Update (vtkSMProperty *) override |
| Update self checking the "unchecked" values of all required properties. More...
void | SetAnimationValue (vtkSMProperty *property, int idx, double value) override |
| Set the value of an element of a property from the animation editor. More...
DefaultModes | GetDefaultMode (unsigned int index=0) |
| Get the default-mode that controls how SetDefaultValues() behaves. More...
int | SetDefaultValues (vtkSMProperty *, bool use_unchecked_values) override |
| Set the property's default value based on the domain. More...
bool | GetMinimumExists (unsigned int idx) |
| Returns if minimum/maximum bound is set for the domain. More...
bool | GetMaximumExists (unsigned int idx) |
| Is the (unchecked) value of the property in the domain? Overwritten by sub-classes. More...
| A vtkSMProperty is often defined with a default value in the XML itself. More...
| Provides access to the vtkSMProperty on which this domain is hooked up. More...
| Helper method to get the number of input connections hence the number of available vtkPVDataInformation from input proxy connected to the required property with the given function. More...
| Returns a given required property of the given function. More...
| When the IsOptional flag is set, IsInDomain() always returns true. More...
| Helper methods to get vtkPVDataInformation from input proxy connected to the required property with the given function and provided input index. More...
virtual void | Modified () |
| vtkSMRangeDomainTemplate () |
| ~vtkSMRangeDomainTemplate () override |
int | ReadXMLAttributes (vtkSMProperty *prop, vtkPVXMLElement *element) override |
| Set the appropriate ivars from the xml element. More...
const std::vector< vtkEntry > & | GetEntries () const |
void | SetEntries (const std::vector< vtkEntry > &new_value) |
| vtkSMDomain () |
| ~vtkSMDomain () override |
| Load the state of the domain from the XML. More...
| Remove the given property from the required properties list. More...
| Add a new required property to this domain. More...
void | DomainModified () |
| Invokes DomainModifiedEvent. More...
void | InvokeModified () |
| Gets the number of required properties added. More...
| Set the domain's property. More...
| Add the header and creates a new vtkPVXMLElement for the domain, fills it up with the common attributes. More...
virtual void | ChildSaveState (vtkPVXMLElement *domainElement) |
| vtkSMSessionObject () |
| ~vtkSMSessionObject () override |
| vtkSMObject () |
| ~vtkSMObject () override |
| vtkObject () |
virtual | ~vtkObject () |
| vtkObjectBase () |
virtual | ~vtkObjectBase () |
| vtkObjectBase (const vtkObjectBase &) |
template<class T>
class vtkSMRangeDomainTemplate< T >
superclass for type-specific range domains i.e.
domains that constrain a value within a min and max.
vtkSMRangeDomainTemplate represents an interval in real space (using precision based on the data-type) specified using a min and a max value. Valid XML attributes are:
* * min
* * max
* * resolution
Both min and max attributes can have one or more space space separated value arguments. Resolution expects only one value. Optionally, a Required Property may be specified (which typically is a information property) which can be used to obtain the range for the values as follows:
* <DoubleRangeDomain ...>
* <RequiredProperties>
* <Property name="<InfoPropName>" function="RangeInfo" />
* </RequiredProperties>
* </DoubleRangeDomain>
vtkSMRangeDomainTemplate provides a mechanism to control how the default value for any property can be determined using the domain either the min, max or mid of the range. One can do that using the "default_mode" attribute in XML with valid values as "min", "max", "mid", or a comma separated sequence of the three e.g "min,max,min". If none is specified, "mid" is assumed. The comma-separated sequence can be used to set a different mode for each component of the property i.e. "min,max,min" means set element 0 as min, element 1 as max and element 2 and min. If the number of elements on the property is less than the number of default specified, the last value is assumed to be repeated. Thus, "min,max,min" is same as the regular expression "min,max,min(,min)*".
Definition at line 52 of file vtkSMRangeDomainTemplate.h.
