vtkSMCameraLink Class Reference
creates a link between two cameras. More...
#include <vtkSMCameraLink.h>
Inheritance diagram for vtkSMCameraLink:
Collaboration diagram for vtkSMCameraLink:
typedef vtkSMProxyLink Superclass
void AddLinkedProxy (vtkSMProxy *proxy, int updateDir) override
 Add a property to the link. More...
void RemoveLinkedProxy (vtkSMProxy *proxy) override
 Remove a linked proxy. More...
virtual void UpdateViews (vtkSMProxy *caller, bool interactive)
 Update all the views linked with an OUTPUT direction. More...
virtual void SetSynchronizeInteractiveRenders (int)
 Get/Set if the link should synchronize interactive renders as well. More...
virtual int GetSynchronizeInteractiveRenders ()
virtual void SynchronizeInteractiveRendersOn ()
virtual void SynchronizeInteractiveRendersOff ()
bool HasGlobalID ()
virtual void EnableLocalPushOnly ()
virtual void DisableLocalPushOnly ()
virtual void SetLocation (vtkTypeUInt32)
virtual void PrototypeOn ()
virtual void PrototypeOff ()
bool IsPrototype ()
virtual void SetPrototype (bool)
static vtkSMCameraLinkNew ()
static vtkSMCameraLinkSafeDownCast (vtkObject *o)
static std::set< std::pair< std::string, std::string > > CameraProperties ()
 Get the list of camera properties to link. More...
static vtkSMObjectNew ()
static vtkObjectNew ()
static vtkObjectBaseNew ()
 vtkSMCameraLink ()
 ~vtkSMCameraLink () override
void UpdateVTKObjects (vtkSMProxy *proxy) override
 Called when an input proxy is updated (UpdateVTKObjects). More...
void PropertyModified (vtkSMProxy *proxy, const char *pname) override
 Called when a property of an input proxy is modified. More...
void UpdateProperty (vtkSMProxy *, const char *) override
 Called when a property is pushed. More...
std::string GetXMLTagName () override
 Override to ajust to this class name. More...
void CopyProperties (vtkSMProxy *caller)
 Internal method to copy vtkSMproperty values from caller to all linked proxies. More...
void ResetCamera (vtkObject *caller)
void UpdateState () override
 Update the internal protobuf state. More...
 vtkSMRemoteObject ()
 Default constructor. More...
 Destructor. More...
 vtkSMSessionObject ()
 vtkSMObject ()
 ~vtkSMObject () override
int SynchronizeInteractiveRenders
vtkTypeUInt32 GlobalID
vtkTypeUInt32 Location
bool Prototype
bool ClientOnlyLocationFlag
Friends
class vtkInternals
When a link is created between camera A->B, whenever any property on camera A is modified, a property with the same name as the modified property (if any) on camera B is also modified to be the same as the property on the camera A. Similarly whenever camera A->UpdateVTKObjects() is called, B->UpdateVTKObjects() is also fired.
Definition at line 22 of file vtkSMCameraLink.h.
Definition at line 26 of file vtkSMCameraLink.h.
◆ vtkSMCameraLink()
vtkSMCameraLink::vtkSMCameraLink ( )
◆ ~vtkSMCameraLink()
vtkSMCameraLink::~vtkSMCameraLink ( )
static vtkSMCameraLink* vtkSMCameraLink::New ( )
virtual const char* vtkSMCameraLink::GetClassName ( )
Reimplemented from vtkSMProxyLink.
static int vtkSMCameraLink::IsTypeOf ( const char *  type)
virtual int vtkSMCameraLink::IsA ( const char *  type)
static vtkSMCameraLink* vtkSMCameraLink::SafeDownCast ( vtkObject o)
void vtkSMCameraLink::PrintSelf ( ostream &  os,
◆ SetSynchronizeInteractiveRenders()
virtual void vtkSMCameraLink::SetSynchronizeInteractiveRenders ( int  )
On by default.
◆ GetSynchronizeInteractiveRenders()
virtual int vtkSMCameraLink::GetSynchronizeInteractiveRenders ( )
On by default.
◆ SynchronizeInteractiveRendersOn()
virtual void vtkSMCameraLink::SynchronizeInteractiveRendersOn ( )
On by default.
◆ SynchronizeInteractiveRendersOff()
virtual void vtkSMCameraLink::SynchronizeInteractiveRendersOff ( )
On by default.
◆ CameraProperties()
static std::set<std::pair<std::string, std::string> > vtkSMCameraLink::CameraProperties ( )
For each pair, first item is the (information) property to read and the second is the property to set.
◆ AddLinkedProxy()
void vtkSMCameraLink::AddLinkedProxy ( vtkSMProxy proxy,
int  updateDir
updateDir determines whether a property of the proxy is read or written. When a property of an input proxy changes, it's value is pushed to all other output proxies in the link. A proxy can be set to be both input and output by setting updateDir to INPUT | OUTPUT
◆ RemoveLinkedProxy()
void vtkSMCameraLink::RemoveLinkedProxy ( vtkSMProxy proxy)
◆ UpdateViews()
virtual void vtkSMCameraLink::UpdateViews ( vtkSMProxy caller,
bool  interactive
interactive indicates if the render is interactive or not.
◆ LoadState()
void vtkSMCameraLink::LoadState ( const vtkSMMessage msg,
vtkSMProxyLocator locator
This method is used to initialise the object to the given state If the definitionOnly Flag is set to True the proxy won't load the properties values and just setup the new proxy hierarchy with all subproxy globalID set.
This allow to split the load process in 2 step to prevent invalid state when property refere to a sub-proxy that does not exist yet.
◆ UpdateVTKObjects()
void vtkSMCameraLink::UpdateVTKObjects ( vtkSMProxy proxy)
overrideprotectedvirtual
Argument is the input proxy.
◆ PropertyModified()
void vtkSMCameraLink::PropertyModified ( vtkSMProxy proxy,
const char *  pname
caller:- the input proxy. pname:- name of the property being modified.
◆ UpdateProperty()
void vtkSMCameraLink::UpdateProperty ( vtkSMProxy ,
const char *
inlineoverrideprotectedvirtual
caller :- the input proxy. pname :- name of property that was pushed.
Definition at line 97 of file vtkSMCameraLink.h.
◆ GetXMLTagName()
std::string vtkSMCameraLink::GetXMLTagName ( )
Definition at line 102 of file vtkSMCameraLink.h.
◆ CopyProperties()
void vtkSMCameraLink::CopyProperties ( vtkSMProxy caller)
◆ ResetCamera()
void vtkSMCameraLink::ResetCamera ( vtkObject caller)
◆ UpdateState()
void vtkSMCameraLink::UpdateState ( )
◆ vtkInternals
friend class vtkInternals
friend
Definition at line 122 of file vtkSMCameraLink.h.
int vtkSMCameraLink::SynchronizeInteractiveRenders
Definition at line 112 of file vtkSMCameraLink.h.
