void | Update (vtkSMProperty *) override |
| Update the domain using the "unchecked" values (if available) for all required properties. More...
Public Member Functions inherited from vtkSMIntRangeDomain |
virtual int | GetMinimum (unsigned int idx, int &exists) |
| Return a min. More...
virtual int | GetMaximum (unsigned int idx, int &exists) |
| Return a max. More...
virtual int | GetMinimumExists (unsigned int idx) |
| Returns if minimum/maximum bound is set for the domain. More...
virtual int | GetMaximumExists (unsigned int idx) |
virtual int | GetMinimum (unsigned int idx) |
| Returns the minimum/maximum value, is exists, otherwise 0 is returned. More...
virtual int | GetMaximum (unsigned int idx) |
| Is the (unchecked) value of the property in the domain? Overwritten by sub-classes. More...
| Set the value of an element of a property from the animation editor. More...
| A vtkSMProperty is often defined with a default value in the XML itself. More...
| Provides access to the vtkSMProperty on which this domain is hooked up. More...
| Helper method to get the number of input connections hence the number of available vtkPVDataInformation from input proxy connected to the required property with the given function. More...
| Returns a given required property of the given function. More...
| When the IsOptional flag is set, IsInDomain() always returns true. More...
| Helper methods to get vtkPVDataInformation from input proxy connected to the required property with the given function and provided input index. More...
virtual void | Modified () |
| vtkSMDimensionsDomain () |
| ~vtkSMDimensionsDomain () override |
void | Update (vtkSMProxyProperty *pp, vtkSMIntVectorProperty *ivp) |
int | GetDirection (vtkSMIntVectorProperty *ivp) |
void | GetExtent (vtkSMProxyProperty *pp, int extent[6]) |
Protected Member Functions inherited from vtkSMIntRangeDomain |
| vtkSMIntRangeDomain () |
| ~vtkSMIntRangeDomain () override |
| vtkSMDomain () |
| ~vtkSMDomain () override |
| Load the state of the domain from the XML. More...
virtual int | ReadXMLAttributes (vtkSMProperty *prop, vtkPVXMLElement *elem) |
| Set the appropriate ivars from the xml element. More...
| Remove the given property from the required properties list. More...
| Add a new required property to this domain. More...
void | DomainModified () |
| Invokes DomainModifiedEvent. More...
void | InvokeModified () |
| Gets the number of required properties added. More...
| Set the domain's property. More...
| Add the header and creates a new vtkPVXMLElement for the domain, fills it up with the common attributes. More...
virtual void | ChildSaveState (vtkPVXMLElement *domainElement) |
| vtkSMSessionObject () |
| ~vtkSMSessionObject () override |
| vtkSMObject () |
| ~vtkSMObject () override |
| vtkObject () |
virtual | ~vtkObject () |
| vtkObjectBase () |
virtual | ~vtkObjectBase () |
| vtkObjectBase (const vtkObjectBase &) |
int range domain based on the data dimensions.
vtkSMDimensionsDomain is a subclass of vtkSMIntRangeDomain. It relies on two required properties: "Input", "Direction". "Input" is generally an vtkSMInputProperty which provides the information about the data extents. "Direction" is an option required property which helps determine the direction (VTK_XY_PLANE, VTK_YZ_PLANE or VTK_XZ_PLANE). If "Direction" is not provided then the property must be a 3 element property while when Direction is provided the property must be a 1 element property.
Supported Required-Property functions:
Input
: points to a property that provides the data producer.
Direction:
points to a property that provides the value for the selected direction.
Definition at line 30 of file vtkSMDimensionsDomain.h.
