vtkSMInputProperty Class Reference
proxy representing inputs to a filter More...
#include <vtkSMInputProperty.h>
Inheritance diagram for vtkSMInputProperty:
Collaboration diagram for vtkSMInputProperty:
typedef vtkSMProxyProperty Superclass
- Public Types inherited from vtkSMProxyProperty
typedef vtkSMProperty Superclass
- Public Types inherited from vtkSMProperty
void AddUncheckedInputConnection (vtkSMProxy *proxy, unsigned int outputPort)
void SetUncheckedInputConnection (unsigned int idx, vtkSMProxy *proxy, unsigned int inputPort)
virtual void SetMultipleInput (int)
 Should be set to true if the "input port" this property represents can accept multiple inputs (for example, an append filter) More...
virtual int GetMultipleInput ()
void AddInputConnection (vtkSMProxy *proxy, unsigned int outputPort)
 Add a proxy to the list of input proxies. More...
void SetInputConnection (unsigned int idx, vtkSMProxy *proxy, unsigned int outputPort)
virtual void SetProxies (unsigned int numElements, vtkSMProxy *proxies[], unsigned int outputports[])
 Sets the value of the property to the list of proxies specified. More...
unsigned int GetOutputPortForConnection (unsigned int idx)
 Given an index for a connection (proxy), returns which output port is used to connect the pipeline. More...
unsigned int GetUncheckedOutputPortForConnection (unsigned int idx)
virtual void SetPortIndex (int)
 Controls which input port this property uses when making connections. More...
virtual int GetPortIndex ()
- Public Member Functions inherited from vtkSMProxyProperty
virtual void SetProxies (unsigned int numElements, vtkSMProxy *proxies[])
bool IsProxyAdded (vtkSMProxy *proxy)
 Returns if the given proxy is already added to the property. More...
virtual void RemoveAllUncheckedProxies ()
 Removes all unchecked proxies. More...
void ClearUncheckedElements () override
 Use this method to clear unchecked values set of this property. More...
unsigned int GetNumberOfProxies ()
 Returns the number of proxies. More...
unsigned int GetNumberOfUncheckedProxies ()
 Returns the number of unchecked proxies. More...
vtkSMProxyGetProxy (unsigned int idx)
 Return a proxy. More...
vtkSMProxyGetUncheckedProxy (unsigned int idx)
void Copy (vtkSMProperty *src) override
 Copy all property values. More...
void UpdateAllInputs () override
 Update all proxies referred by this property (if any). More...
bool IsValueDefault () override
 Returns true if the property's value is different from the default value. More...
void ResetToXMLDefaults () override
 For properties that support specifying defaults in XML configuration, this method will reset the property value to the default values specified in the XML. More...
virtual void AddProxy (vtkSMProxy *proxy)
 Add/remove/set a proxy to the list of proxies. More...
virtual void SetProxy (unsigned int idx, vtkSMProxy *proxy)
virtual void RemoveProxy (vtkSMProxy *proxy)
virtual void RemoveAllProxies ()
virtual void AddUncheckedProxy (vtkSMProxy *proxy)
 Add an unchecked proxy. More...
virtual void SetUncheckedProxy (unsigned int idx, vtkSMProxy *proxy)
void SetNumberOfProxies (unsigned int count)
 Set the number of proxies. More...
void SetNumberOfUncheckedProxies (unsigned int count)
- Public Member Functions inherited from vtkSMProperty
int IsInDomains ()
 Returns true if all values are in all domains, false otherwise. More...
int IsInDomains (vtkSMDomain **domain)
 Overload of IsInDomains() that provides a mechanism to return the first domain that fails the check. More...
void UnRegister (vtkObjectBase *obj) override
 Overloaded to break the reference loop caused by the internal domain iterator. More...
vtkSMDomainIteratorNewDomainIterator ()
 Creates, initializes and returns a new domain iterator. More...
vtkSMDomainGetDomain (const char *name)
 Returns a domain give a name. More...
vtkSMDomainFindDomain (const char *classname)
 Returns the first domain which is of the specified type. More...
template<class DomainType >
DomainType * FindDomain ()
 Same as FindDomain(classname), except the classname is deduced from the type. More...
unsigned int GetNumberOfDomains ()
 Returns the number of domains this property has. More...
void AddDomain (const char *name, vtkSMDomain *dom)
 Properties can have one or more domains. More...
virtual void AddLinkedProperty (vtkSMProperty *targetProperty)
 Add a link to a property whose value should be synchronized with this property value. More...
virtual void RemoveLinkedProperty (vtkSMProperty *targetProperty)
 Remove a link to a property added with AddLinkedProperty() More...
virtual void RemoveFromSourceLink ()
 Remove a link from the source property. More...
void ResetToDefault ()
 Simply calls this->ResetToDomainDefaults() and if that returns false, calls this->ResetToXMLDefaults(). More...
virtual bool ResetToDomainDefaults (bool use_unchecked_values=false)
 Iterates over all domains and call SetDefaultValues() on each domain until the first one returns true i.e. More...
vtkSMProxyGetParent ()
 Get the proxy to which this property belongs. More...
virtual bool IsStateIgnored ()
bool HasDomainsWithRequiredProperties ()
 Returns true if the property has a domain with required properties. More...
virtual void SetCommand (const char *)
 The command name used to set the value on the server object. More...
virtual char * GetCommand ()
virtual void SetImmediateUpdate (int)
 If ImmediateUpdate is true, the value of the property will be pushed to the server as soon as it is modified. More...
virtual int GetImmediateUpdate ()
virtual int GetInformationOnly ()
 Is InformationOnly is set to true, this property is used to get information from server instead of setting values. More...
virtual int GetIgnoreSynchronization ()
 If IgnoreSynchronization is set to true, this property is used to prevent that property from being updated when changed remotely by another collaborative client. More...
virtual vtkSMPropertyGetInformationProperty ()
 Get the associated information property. More...
virtual void SetAnimateable (int)
 Get/Set if the property is animateable. More...
virtual int GetAnimateable ()
virtual void SetIsInternal (int)
 Get/Set if the property is internal to server manager. More...
virtual int GetIsInternal ()
virtual void SetNoCustomDefault (int)
 Set/Get whether the property should ignore custom default settings. More...
virtual int GetNoCustomDefault ()
virtual void SetPanelVisibility (const char *)
 Set/Get the panel visibility for the property. More...
virtual char * GetPanelVisibility ()
virtual void SetPanelVisibilityDefaultForRepresentation (const char *)
 Set/Get the panel visibility to default if the current representation type matches representation. More...
virtual char * GetPanelVisibilityDefaultForRepresentation ()
virtual void SetPanelWidget (const char *)
 Set/Get the name of the custom panel widget to use for the property. More...
virtual char * GetPanelWidget ()
virtual void SetDisableSubTrace (const char *)
 Set/Get the tracing of sub property of this property. More...
virtual char * GetDisableSubTrace ()
virtual char * GetXMLLabel ()
 The label assigned by the xml parser. More...
virtual char * GetXMLName ()
 The name assigned by the xml parser. More...
virtual int GetRepeatable ()
 If repeatable, a property can have 1 or more values of the same kind. More...
 The server manager configuration XML may define <Hints/> element for a property. More...
void Modified () override
 Overridden to support blocking of modified events. More...
static vtkSMInputPropertyNew ()
static vtkSMInputPropertySafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSMProxyProperty
static vtkSMProxyPropertyNew ()
static vtkSMProxyPropertySafeDownCast (vtkObject *o)
static void EnableProxyCreation ()
 When we load ProxyManager state we want Proxy/InputProperty to be able to create the corresponding missing proxy. More...
static void DisableProxyCreation ()
static bool CanCreateProxy ()
- Static Public Member Functions inherited from vtkSMProperty
static vtkSMPropertyNew ()
static vtkSMPropertySafeDownCast (vtkObject *o)
static vtkSMObjectNew ()
static vtkObjectNew ()
static vtkObjectBaseNew ()
 vtkSMInputProperty ()
 ~vtkSMInputProperty () override
int ReadXMLAttributes (vtkSMProxy *parent, vtkPVXMLElement *element) override
vtkPVXMLElementAddProxyElementState (vtkPVXMLElement *propertyElement, unsigned int idx) override
 Fill state property/proxy XML element with output port attribute. More...
- Protected Member Functions inherited from vtkSMProxyProperty
 vtkSMProxyProperty ()
 ~vtkSMProxyProperty () override
void WriteTo (vtkSMMessage *msg) override
 Let the property write its content into the stream. More...
void ReadFrom (const vtkSMMessage *msg, int msg_offset, vtkSMProxyLocator *) override
 Let the property read and set its content from the stream. More...
void SaveStateValues (vtkPVXMLElement *propertyElement) override
 Generic method used to generate XML state. More...
int LoadState (vtkPVXMLElement *element, vtkSMProxyLocator *loader) override
 Updates state from an XML element. More...
void OnUpdateDataEvent ()
 Called when a producer fires the vtkCommand::UpdateDataEvent. More...
- Protected Member Functions inherited from vtkSMProperty
 vtkSMProperty ()
 ~vtkSMProperty () override
virtual void ReadFrom (const vtkSMMessage *, int vtkNotUsed(message_offset), vtkSMProxyLocator *)
 Internal. More...
void AddDependent (vtkSMDomain *dom)
 Internal. More...
void RemoveAllDependents ()
 Removes all dependents. More...
void UpdateDomains ()
 Calls Update() on all domains contained by the property as well as all dependent domains. More...
virtual void SaveState (vtkPVXMLElement *parent, const char *property_name, const char *uid, int saveDomains=1)
 Save the property state in XML. More...
virtual void SaveDomainState (vtkPVXMLElement *propertyElement, const char *uid)
 Save property domain. More...
virtual void SetInformationOnly (int)
virtual void SetIgnoreSynchronization (int)
void SetInformationProperty (vtkSMProperty *ip)
void SetDocumentation (vtkSMDocumentation *)
void SetParent (vtkSMProxy *proxy)
virtual void SetStateIgnored (bool)
virtual void StateIgnoredOn ()
virtual void StateIgnoredOff ()
bool SetBlockModifiedEvents (bool block)
 Block/unblock modified events, returns the current state of the block flag. More...
virtual bool GetPendingModifiedEvents ()
 Returns if any modified evetns are pending. More...
 vtkSMObject ()
 ~vtkSMObject () override
int MultipleInput
int PortIndex
- Protected Attributes inherited from vtkSMProxyProperty
vtkPPInternalsPPInternals
- Protected Attributes inherited from vtkSMProperty
vtkPVXMLElementHints
char * Command
vtkSMPropertyInternalsPInternals
int ImmediateUpdate
int Animateable
int IsInternal
int NoCustomDefault
char * XMLName
char * XMLLabel
char * PanelVisibility
char * PanelVisibilityDefaultForRepresentation
char * PanelWidget
char * DisableSubTrace
vtkSMDomainIteratorDomainIterator
int InformationOnly
int IgnoreSynchronization
vtkSMInformationHelper * InformationHelper
vtkSMPropertyInformationProperty
int Repeatable
vtkWeakPointer< vtkSMProxyProxy
bool StateIgnored
vtkSMPropertyLinkLinks
- Static Protected Attributes inherited from vtkSMProxyProperty
static bool CreateProxyAllowed
vtkSMInputProperty is a concrete sub-class of vtkSMProperty representing inputs to a filter (through vtkSMProxy). It is a special property that always calls AddInput on a vtkSMSourceProxy. The xml configuration for input proxy supports the following attributes: multiple_input: For an input port that connects multiple connections such as the input of an append filter. port_index: The input port to be used.
See also
vtkSMInputProperty vtkSMSourceProxy
Definition at line 28 of file vtkSMInputProperty.h.
Definition at line 32 of file vtkSMInputProperty.h.
◆ vtkSMInputProperty()
vtkSMInputProperty::vtkSMInputProperty ( )
◆ ~vtkSMInputProperty()
vtkSMInputProperty::~vtkSMInputProperty ( )
static vtkSMInputProperty* vtkSMInputProperty::New ( )
virtual const char* vtkSMInputProperty::GetClassName ( )
Reimplemented from vtkSMProxyProperty.
static int vtkSMInputProperty::IsTypeOf ( const char *  type)
virtual int vtkSMInputProperty::IsA ( const char *  type)
static vtkSMInputProperty* vtkSMInputProperty::SafeDownCast ( vtkObject o)
void vtkSMInputProperty::PrintSelf ( ostream &  os,
◆ SetMultipleInput()
virtual void vtkSMInputProperty::SetMultipleInput ( int  )
◆ GetMultipleInput()
virtual int vtkSMInputProperty::GetMultipleInput ( )
◆ AddInputConnection()
void vtkSMInputProperty::AddInputConnection ( vtkSMProxy proxy,
The outputPort controls which outputPort will be used in connecting the pipeline. The proxy is added with corresponding Add and Set methods and can be removed with RemoveXXX() methods as usual.
◆ SetInputConnection()
void vtkSMInputProperty::SetInputConnection ( unsigned int  idx,
vtkSMProxy proxy,
◆ AddUncheckedInputConnection()
void vtkSMInputProperty::AddUncheckedInputConnection ( vtkSMProxy proxy,
◆ SetUncheckedInputConnection()
void vtkSMInputProperty::SetUncheckedInputConnection ( unsigned int  idx,
vtkSMProxy proxy,
◆ SetProxies()
virtual void vtkSMInputProperty::SetProxies ( unsigned int  numElements,
vtkSMProxy proxies[],
◆ GetOutputPortForConnection()
unsigned int vtkSMInputProperty::GetOutputPortForConnection ( unsigned int  idx)
◆ GetUncheckedOutputPortForConnection()
unsigned int vtkSMInputProperty::GetUncheckedOutputPortForConnection ( unsigned int  idx)
◆ SetPortIndex()
virtual void vtkSMInputProperty::SetPortIndex ( int  )
By default, this is 0.
◆ GetPortIndex()
virtual int vtkSMInputProperty::GetPortIndex ( )
◆ ReadXMLAttributes()
int vtkSMInputProperty::ReadXMLAttributes ( vtkSMProxy parent,
vtkPVXMLElement element
overrideprotectedvirtual
Reimplemented from vtkSMProperty.
◆ AddProxyElementState()
vtkPVXMLElement* vtkSMInputProperty::AddProxyElementState ( vtkPVXMLElement propertyElement,
unsigned int  idx
◆ MultipleInput
int vtkSMInputProperty::MultipleInput
Definition at line 101 of file vtkSMInputProperty.h.
◆ PortIndex
int vtkSMInputProperty::PortIndex
Definition at line 102 of file vtkSMInputProperty.h.
