void | Update () override |
| Updates the data pipelines for all visible representations. More...
void | GetViews (vtkCollection *collection) |
| Get all the internal views. More...
vtkSMViewProxy * | GetRootView () |
| Returns the root view proxy. More...
void | MarkDirty (vtkSMProxy *modifiedProxy) override |
const char * | GetRepresentationType (vtkSMSourceProxy *producer, int outputPort) override |
| Overridden to forward the call to the internal root view proxy. More...
vtkRenderWindow * | GetRenderWindow () override |
| Returns the render-window used by the root view, if any. More...
vtkRenderWindowInteractor * | GetInteractor () override |
| Returns the interactor. More...
void | SetupInteractor (vtkRenderWindowInteractor *iren) override |
| To avoid misuse of this method for comparative views, this method will raise an error. More...
bool | MakeRenderWindowInteractor (bool quiet=false) override |
| Overridden to call MakeRenderWindowInteractor() on each of the internal views. More...
virtual void | StillRender () |
| Renders the view using full resolution. More...
virtual void | InteractiveRender () |
| Renders the view using lower resolution is possible. More...
virtual bool | CanDisplayData (vtkSMSourceProxy *producer, int outputPort) |
| Returns true if the view can display the data produced by the producer's port. More...
virtual vtkSMRepresentationProxy * | CreateDefaultRepresentation (vtkSMProxy *, int) |
| Create a default representation for the given source proxy. More...
virtual vtkSMRepresentationProxy * | FindRepresentation (vtkSMSourceProxy *producer, int outputPort) |
| Finds the representation proxy showing the data produced by the provided producer, if any. More...
vtkView * | GetClientSideView () |
| Returns the client-side vtkView, if any. More...
int | WriteImage (const char *filename, const char *writerName, int magnification=1) |
| Saves a screenshot of the view to disk. More...
int | WriteImage (const char *filename, const char *writerName, int magnificationX, int magnificationY) |
virtual bool | HasDirtyRepresentation () |
| Return true any internal representation is dirty. More...
virtual void | SetEnable (bool) |
| Enable/Disable a view. More...
virtual bool | GetEnable () |
virtual void | EnableOn () |
virtual void | EnableOff () |
vtkImageData * | CaptureWindow (int magnification) |
| Captures a image from this view. More...
vtkImageData * | CaptureWindow (int magnificationX, int magnificationY) |
virtual bool | GetNeedsUpdate () |
| Returns true if the subsequent call to Update() will result in an actual update. More...
virtual bool | HideOtherRepresentationsIfNeeded (vtkSMProxy *repr) |
| Method used to hide other representations if the view has a <ShowOneRepresentationAtATime/> hint. More...
virtual void | RepresentationVisibilityChanged (vtkSMProxy *repr, bool new_visibility) |
| Certain views maintain properties (or other state) that should be updated when visibility of representations is changed e.g. More...
bool | IsDeprecated () |
bool | GetIsSubProxy () |
bool | HasGlobalID () |
bool | IsPrototype () |
virtual void | Modified () |
