enumeration domain to select array association or attribute type. More...
#include <vtkSMFieldDataDomain.h>
typedef vtkSMEnumerationDomain | Superclass |
typedef vtkSMDomain | Superclass |
enum | IsInDomainReturnCodes { NOT_APPLICABLE = -1, NOT_IN_DOMAIN = 0, IN_DOMAIN = 1 } |
int | SetDefaultValues (vtkSMProperty *, bool use_unchecked_values) override |
Overridden to ensure that the property's default value is valid for the enumeration, if not it will be set to the first enumeration value. More... | |
void | Update (vtkSMProperty *property) override |
Updates the available field data based on the input dataset type, if possible. More... | |
int | IsInDomain (vtkSMProperty *property) override |
Returns true if the value of the property is in the domain. More... | |
int | IsInDomain (int val, unsigned int &idx) |
Returns true if the int is in the domain. More... | |
unsigned int | GetNumberOfEntries () |
Returns the number of entries in the enumeration. More... | |
int | GetEntryValue (unsigned int idx) |
Returns the integer value of an enumeration entry. More... | |
const char * | GetEntryText (unsigned int idx) |
Returns the descriptive string of an enumeration entry. More... | |
const char * | GetEntryTextForValue (int value) |
Returns the text for an enumeration value. More... | |
int | HasEntryText (const char *text) |
Return 1 is the text is present in the enumeration, otherwise 0. More... | |
int | GetEntryValueForText (const char *text) |
Get the value for an enumeration text. More... | |
int | GetEntryValue (const char *text, int &valid) |
Given an entry text, return the integer value. More... | |
const char * | GetInfoText (unsigned int idx) |
Returns the info text for an enumeration entry. More... | |
void | AddEntry (const char *text, int value, const char *info=nullptr) |
Add a new enumeration entry. More... | |
void | RemoveAllEntries () |
Clear all entries. More... | |
Is the (unchecked) value of the property in the domain? Overwritten by sub-classes. More... | |
Set the value of an element of a property from the animation editor. More... | |
A vtkSMProperty is often defined with a default value in the XML itself. More... | |
Provides access to the vtkSMProperty on which this domain is hooked up. More... | |
Helper method to get the number of input connections hence the number of available vtkPVDataInformation from input proxy connected to the required property with the given function. More... | |
Returns a given required property of the given function. More... | |
When the IsOptional flag is set, IsInDomain() always returns true. More... | |
Helper methods to get vtkPVDataInformation from input proxy connected to the required property with the given function and provided input index. More... | |
virtual void | Modified () |
static vtkSMFieldDataDomain * | New () |
static vtkSMFieldDataDomain * | SafeDownCast (vtkObject *o) |
static const char * | GetAttributeTypeAsString (int attrType) |
Convenience method to return the string for an attribute type. More... | |
static const char * | GetElementTypeAsString (int attrType) |
Convenience method to return the string for an element type. More... | |
static vtkSMEnumerationDomain * | New () |
static vtkSMEnumerationDomain * | SafeDownCast (vtkObject *o) |
static vtkSMDomain * | New () |
static vtkSMDomain * | SafeDownCast (vtkObject *o) |
static vtkObject * | New () |
vtkSMFieldDataDomain () | |
~vtkSMFieldDataDomain () override | |
int | ReadXMLAttributes (vtkSMProperty *prop, vtkPVXMLElement *elem) override |
Set the appropriate ivars from the xml element. More... | |
void | ChildSaveState (vtkPVXMLElement *domainElement) override |
Add the header and creates a new vtkPVXMLElement for the domain, fills it up with the common attributes. More... | |
vtkSMEnumerationDomain () | |
~vtkSMEnumerationDomain () override | |
vtkSMDomain () | |
~vtkSMDomain () override | |
Load the state of the domain from the XML. More... | |
Remove the given property from the required properties list. More... | |
Add a new required property to this domain. More... | |
void | DomainModified () |
Invokes DomainModifiedEvent. More... | |
void | InvokeModified () |
Gets the number of required properties added. More... | |
Set the domain's property. More... | |
vtkSMSessionObject () | |
vtkSMObject () | |
~vtkSMObject () override | |
vtkObject () | |
virtual | ~vtkObject () |
vtkObjectBase () | |
virtual | ~vtkObjectBase () |
Protected Attributes | |
bool | EnableFieldDataSelection |
bool | UseElementTypes |
char * | XMLName |
bool | IsOptional |
vtkSMDomainInternals * | Internals |
vtkWeakPointer< vtkSMSession > | Session |
Identifies the session id to which this object is related. More... | |
bool | Debug |
vtkTimeStamp | MTime |
vtkSMFieldDataDomain can be used on a vtkSMIntVectorProperty that is intended to specify the attribute type (vtkDataObject::AttributeTypes
) or field association (vtkDataObject::FieldAssociations
By default, vtkDataObject::Field
(or vtkDataObject::FIELD_ASSOCIATION_NONE) is not added to the domain. If you want to support field data, then use enable_field_data="1"
attribute in the XML configuration.
By default, the domain is assumed to represent field associations and hence the enumeration text is populated as "Point Data", "Cell Data", etc. To use element types for text, add attribute use_element_types="1"
to the XML. In that case, the domain is populated with "Point", "Cell", etc.
vtkSMFieldDataDomain tries to respect the provided default_values. eg default_values=1
correspond to vtkDataObject::CELL
If it is non-positive or not available, it will pick the default value to be the first attribute type that has non empty arrays and non-zero tuples. If all attributes have no tuples, then the first attribute with non empty arrays is selected. If all attributes have no arrays, then vtkSMEnumerationDomain picks the default. For this to work, the domain must be provided an Input
property as a required property for function "Input".
Previously (5.6 and earlier), vtkSMFieldDataDomain was added to vtkSMStringVectorProperty instances that allowed user to choose the array to process. This is no longer needed or supported. Simply remove the vtkSMFieldDataDomain from the XML for such properties.
The domain provided ability to limit the attribute types to the data type of the input dataset. This was clumsy since it did not correctly handle cases where data type changes or non empty attribute types changed. Hence we've dropped support for that. Simply remove disable_update_domain_entries
and force_point_cell_data
attributes from the XML for this domain since they are no longer supported.
Definition at line 53 of file vtkSMFieldDataDomain.h.
Definition at line 57 of file vtkSMFieldDataDomain.h.
Reimplemented from vtkSMEnumerationDomain.
Will return nullptr for unsupported or invalid type.
The provided property is not used.
overrideprotectedvirtual |
Definition at line 95 of file vtkSMFieldDataDomain.h.
Definition at line 97 of file vtkSMFieldDataDomain.h.
