int SetDefaultValues(vtkSMProperty *, bool use_unchecked_values) override
Overridden to ensure that the property's default value is valid for the enumeration, if not it will be set to the first enumeration value.
list of integers with associated strings
enumeration domain to select array association or attribute type.
int ReadXMLAttributes(vtkSMProperty *prop, vtkPVXMLElement *element) override
static vtkSMEnumerationDomain * New()
bool EnableFieldDataSelection
void Update(vtkSMProperty *property) override
Update self based on the "unchecked" values of all required properties.
