void | SetVisibility (int) |
| Don't use directly. More...
void | SetOpacity (double) |
void | SetSourceProxy (vtkSMProxy *proxy) |
bool | IsDeprecated () |
bool | GetIsSubProxy () |
bool | HasGlobalID () |
bool | IsPrototype () |
virtual void | Modified () |
