int range domain based on the number of components available in a particular data array.
void | Update (vtkSMProperty *prop) override |
| Updates the range based on the scalar range of the currently selected array. More...
Public Member Functions inherited from vtkSMEnumerationDomain |
int | IsInDomain (vtkSMProperty *property) override |
| Returns true if the value of the property is in the domain. More...
int | IsInDomain (int val, unsigned int &idx) |
| Returns true if the int is in the domain. More...
unsigned int | GetNumberOfEntries () |
| Returns the number of entries in the enumeration. More...
int | GetEntryValue (unsigned int idx) |
| Returns the integer value of an enumeration entry. More...
const char * | GetEntryText (unsigned int idx) |
| Returns the descriptive string of an enumeration entry. More...
const char * | GetEntryTextForValue (int value) |
| Returns the text for an enumeration value. More...
int | HasEntryText (const char *text) |
| Return 1 is the text is present in the enumeration, otherwise 0. More...
int | GetEntryValueForText (const char *text) |
| Get the value for an enumeration text. More...
int | GetEntryValue (const char *text, int &valid) |
| Given an entry text, return the integer value. More...
const char * | GetInfoText (unsigned int idx) |
| Returns the info text for an enumeration entry. More...
void | AddEntry (const char *text, int value, const char *info=nullptr) |
| Add a new enumeration entry. More...
void | RemoveAllEntries () |
| Clear all entries. More...
int | SetDefaultValues (vtkSMProperty *, bool use_unchecked_values) override |
| Overridden to ensure that the property's default value is valid for the enumeration, if not it will be set to the first enumeration value. More...
| Is the (unchecked) value of the property in the domain? Overwritten by sub-classes. More...
| Set the value of an element of a property from the animation editor. More...
| A vtkSMProperty is often defined with a default value in the XML itself. More...
| Provides access to the vtkSMProperty on which this domain is hooked up. More...
| Helper method to get the number of input connections hence the number of available vtkPVDataInformation from input proxy connected to the required property with the given function. More...
| Returns a given required property of the given function. More...
| When the IsOptional flag is set, IsInDomain() always returns true. More...
| Helper methods to get vtkPVDataInformation from input proxy connected to the required property with the given function and provided input index. More...
virtual void | Modified () |
| vtkSMNumberOfComponentsDomain () |
| ~vtkSMNumberOfComponentsDomain () override |
int | ReadXMLAttributes (vtkSMProperty *prop, vtkPVXMLElement *element) override |
| Set the appropriate ivars from the xml element. More...
void | Update (const char *arrayname, vtkSMSourceProxy *sp, vtkSMInputArrayDomain *iad, int outputport) |
| Internal update method doing the actual work. More...
Protected Member Functions inherited from vtkSMEnumerationDomain |
void | ChildSaveState (vtkPVXMLElement *domainElement) override |
| Add the header and creates a new vtkPVXMLElement for the domain, fills it up with the common attributes. More...
| vtkSMEnumerationDomain () |
| ~vtkSMEnumerationDomain () override |
| vtkSMDomain () |
| ~vtkSMDomain () override |
| Load the state of the domain from the XML. More...
| Remove the given property from the required properties list. More...
| Add a new required property to this domain. More...
void | DomainModified () |
| Invokes DomainModifiedEvent. More...
void | InvokeModified () |
| Gets the number of required properties added. More...
| Set the domain's property. More...
| vtkSMSessionObject () |
| ~vtkSMSessionObject () override |
| vtkSMObject () |
| ~vtkSMObject () override |
| vtkObject () |
virtual | ~vtkObject () |
| vtkObjectBase () |
virtual | ~vtkObjectBase () |
| vtkObjectBase (const vtkObjectBase &) |
vtkSMNumberOfComponentsDomain is used for properties that allow the user to choose the component number (or associated name) to process for the chosen array. It needs two required properties with following functions:
- Input – input property for the filter.
- ArraySelection – string vector property used to select the array. This domain will not work if either of the required properties is missing.
Definition at line 25 of file vtkSMNumberOfComponentsDomain.h.
