const char * | GetDataAssemblyName () const |
| Returns the name for the chosen assembly, if any. More...
vtkDataAssembly * | GetDataAssembly () const |
| Provides access to the data assembly. More...
void | Update (vtkSMProperty *requestingProperty) override |
| Update self based on the "unchecked" values of all required properties. More...
int | SetDefaultValues (vtkSMProperty *prop, bool use_unchecked_values) override |
| Is the (unchecked) value of the property in the domain? Overwritten by sub-classes. More...
| Set the value of an element of a property from the animation editor. More...
| A vtkSMProperty is often defined with a default value in the XML itself. More...
| Provides access to the vtkSMProperty on which this domain is hooked up. More...
| Helper method to get the number of input connections hence the number of available vtkPVDataInformation from input proxy connected to the required property with the given function. More...
| Returns a given required property of the given function. More...
| When the IsOptional flag is set, IsInDomain() always returns true. More...
| Helper methods to get vtkPVDataInformation from input proxy connected to the required property with the given function and provided input index. More...
virtual void | Modified () |
| vtkSMDataAssemblyDomain () |
| ~vtkSMDataAssemblyDomain () override |
| vtkSMDomain () |
| ~vtkSMDomain () override |
| Load the state of the domain from the XML. More...
| Remove the given property from the required properties list. More...
| Add a new required property to this domain. More...
void | DomainModified () |
| Invokes DomainModifiedEvent. More...
void | InvokeModified () |
| Gets the number of required properties added. More...
| Set the domain's property. More...
| Add the header and creates a new vtkPVXMLElement for the domain, fills it up with the common attributes. More...
virtual void | ChildSaveState (vtkPVXMLElement *domainElement) |
| vtkSMSessionObject () |
| ~vtkSMSessionObject () override |
| vtkSMObject () |
| ~vtkSMObject () override |
| vtkObject () |
virtual | ~vtkObject () |
| vtkObjectBase () |
virtual | ~vtkObjectBase () |
| vtkObjectBase (const vtkObjectBase &) |
a domain that uses vtkDataAssembly
vtkSMDataAssemblyDomain is intended for vtkSMStringVectorProperty that uses vtkDataAssembly to qualify values. For example, the "Paths" property on vtkExtractBlockUsingDataAssembly
filter that lets the user select paths to extract uses this domain.
Example usage in a ServerManager XML is as follows:
<SourceProxy ...>
<StringVectorProperty clean_command="ClearNodePaths"
command="AddNodePath"
name="Paths"
number_of_elements_per_command="1"
panel_visibility="default"
repeat_command="1"
animateable="0">
<DataAssemblyDomain name="data_assembly" (optional)entity_type=3>
<RequiredProperties>
<Property function="Input" name="Input" />
</RequiredProperties>
</DataAssemblyDomain>
<Documentation>
This property lists the paths for blocks to extract.
</Documentation>
</StringVectorProperty>
</SourceProxy>
vtkSMDataAssemblyDomain can also be used on readers. In that case, it uses vtkPVDataAssemblyInformation to obtain the data assembly from the reader. The following snippet shows how this domain can be used on a reader. Note, the 'Tag' required property is essential to use this domain on a reader. It is used to determine when to fetch the vtkDataAssembly from the reader.
<SourceProxy ...>
<IntVectorProperty name="AssemblyTag"
command="GetAssemblyTag"
information_only="1">
<Documentation>
This is simply an int that changes whenever a new assembly is built
by the reader. This can be used to determine if the assembly should be fetched from
the reader whenever the reader is updated.
</Documentation>
</IntVectorProperty>
<StringVectorProperty name="AssemmblySelectors"
command="AddSelector"
clean_command="ClearSelectors"
repeat_command="1"
panel_widget="data_assembly_editor" >
<DataAssemblyDomain name="data_assembly">
<Property function="Tag" name="AssemblyTag" />
<Documentation>
Specify the selectors for the data assembly chosen using **Assembly**
to choose the blocks to extract from the input dataset.
</Documentation>
<Hints>
<PropertyWidgetDecorator type="GenericDecorator"
mode="visibility"
property="AssemblyTag"
value="0"
inverse="1" />
</Hints>
</SourceProxy>
Definition at line 96 of file vtkSMDataAssemblyDomain.h.
