vtkSMDataAssemblyDomain.h
86 #ifndef vtkSMDataAssemblyDomain_h
87 #define vtkSMDataAssemblyDomain_h
88
89 #include "vtkRemotingServerManagerModule.h" // needed for exports
90 #include "vtkSMDomain.h"
91 #include "vtkSmartPointer.h" // needed for vtkSmartPointer
92
93 #include <string> // for std::string
94
95 class vtkDataAssembly;
97 {
98 public:
99  static vtkSMDataAssemblyDomain* New();
101  void PrintSelf(ostream& os, vtkIndent indent) override;
102
106  const char* GetDataAssemblyName() const
107  {
108  return this->Name.empty() ? nullptr : this->Name.c_str();
109  }
110
114  vtkDataAssembly* GetDataAssembly() const;
115
116  void Update(vtkSMProperty* requestingProperty) override;
117
118  int SetDefaultValues(vtkSMProperty* prop, bool use_unchecked_values) override;
119
120 protected:
122  ~vtkSMDataAssemblyDomain() override;
123
124 private:
126  void operator=(const vtkSMDataAssemblyDomain&) = delete;
127
128  void ChooseAssembly(const std::string& name, vtkDataAssembly* assembly);
129  void FetchAssembly(int tag);
130
136  int ReadXMLAttributes(vtkSMProperty* prop, vtkPVXMLElement* element) override;
137
138  int LastTag = 0;
139
141  std::string AssemblyXMLContents;
142  std::string Name;
143  int EntityType = -1;
144 };
145
146 #endif
virtual void Update(vtkSMProperty *requestingProperty)
Update self based on the "unchecked" values of all required properties.
virtual int SetDefaultValues(vtkSMProperty *, bool vtkNotUsed(use_unchecked_values))
Definition: vtkSMDomain.h:91
name
represents the possible values a property can have
Definition: vtkSMDomain.h:37
virtual int ReadXMLAttributes(vtkSMProperty *prop, vtkPVXMLElement *elem)
const char * GetDataAssemblyName() const
Returns the name for the chosen assembly, if any.
a domain that uses vtkDataAssembly
static vtkSMDomain * New()
