int | SetDefaultValues (vtkSMProperty *, bool use_unchecked_values) override |
| Set the default values for the property. More...
void | Update (vtkSMProperty *requestingProperty) override |
| Overridden to fire DomainModified when the required property changes. More...
Public Member Functions inherited from vtkSMBooleanDomain |
int | IsInDomain (vtkSMProperty *property) override |
| Returns true if the property is a vtkSMIntVectorProperty. More...
void | SetAnimationValue (vtkSMProperty *property, int idx, double value) override |
| Set the value of an element of a property from the animation editor. More...
| Is the (unchecked) value of the property in the domain? Overwritten by sub-classes. More...
| A vtkSMProperty is often defined with a default value in the XML itself. More...
| Provides access to the vtkSMProperty on which this domain is hooked up. More...
| Helper method to get the number of input connections hence the number of available vtkPVDataInformation from input proxy connected to the required property with the given function. More...
| Returns a given required property of the given function. More...
| When the IsOptional flag is set, IsInDomain() always returns true. More...
| Helper methods to get vtkPVDataInformation from input proxy connected to the required property with the given function and provided input index. More...
virtual void | Modified () |
| vtkSMChartUseIndexForAxisDomain () |
| ~vtkSMChartUseIndexForAxisDomain () override |
Protected Member Functions inherited from vtkSMBooleanDomain |
| vtkSMBooleanDomain () |
| ~vtkSMBooleanDomain () override |
| vtkSMDomain () |
| ~vtkSMDomain () override |
| Load the state of the domain from the XML. More...
virtual int | ReadXMLAttributes (vtkSMProperty *prop, vtkPVXMLElement *elem) |
| Set the appropriate ivars from the xml element. More...
| Remove the given property from the required properties list. More...
| Add a new required property to this domain. More...
void | DomainModified () |
| Invokes DomainModifiedEvent. More...
void | InvokeModified () |
| Gets the number of required properties added. More...
| Set the domain's property. More...
| Add the header and creates a new vtkPVXMLElement for the domain, fills it up with the common attributes. More...
virtual void | ChildSaveState (vtkPVXMLElement *domainElement) |
| vtkSMSessionObject () |
| ~vtkSMSessionObject () override |
| vtkSMObject () |
| ~vtkSMObject () override |
| vtkObject () |
virtual | ~vtkObject () |
| vtkObjectBase () |
virtual | ~vtkObjectBase () |
| vtkObjectBase (const vtkObjectBase &) |
extends vtkSMBooleanDomain to pick a good default for properties such as "UseIndexForXAxis" on chart representations.
vtkSMChartUseIndexForAxisDomain extends vtkSMBooleanDomain to add logic to pick an appropriate default e.g. UseIndexForXAxis for bar and line charts needs to be set to 0 by default, if the XArrayName contains one of the known arrays such as "bin_extents", "arc_length", and set to 1 otherwise. This class encapsulates that logic.
Supported Required-Property functions:
- ArraySelection : (required) refers to the property that dictates the array selection.
Definition at line 26 of file vtkSMChartUseIndexForAxisDomain.h.
