int | IsInDomain (vtkSMProperty *property) override |
| Returns true if the property is a vtkSMIntVectorProperty. More...
void | SetAnimationValue (vtkSMProperty *property, int idx, double value) override |
| Set the value of an element of a property from the animation editor. More...
| Is the (unchecked) value of the property in the domain? Overwritten by sub-classes. More...
virtual void | Update (vtkSMProperty *requestingProperty) |
| Update self based on the "unchecked" values of all required properties. More...
| A vtkSMProperty is often defined with a default value in the XML itself. More...
| Provides access to the vtkSMProperty on which this domain is hooked up. More...
| Helper method to get the number of input connections hence the number of available vtkPVDataInformation from input proxy connected to the required property with the given function. More...
| Returns a given required property of the given function. More...
| When the IsOptional flag is set, IsInDomain() always returns true. More...
| Helper methods to get vtkPVDataInformation from input proxy connected to the required property with the given function and provided input index. More...
virtual void | Modified () |
| vtkSMBooleanDomain () |
| ~vtkSMBooleanDomain () override |
| vtkSMDomain () |
| ~vtkSMDomain () override |
| Load the state of the domain from the XML. More...
virtual int | ReadXMLAttributes (vtkSMProperty *prop, vtkPVXMLElement *elem) |
| Set the appropriate ivars from the xml element. More...
| Remove the given property from the required properties list. More...
| Add a new required property to this domain. More...
void | DomainModified () |
| Invokes DomainModifiedEvent. More...
void | InvokeModified () |
| Gets the number of required properties added. More...
| Set the domain's property. More...
| Add the header and creates a new vtkPVXMLElement for the domain, fills it up with the common attributes. More...
virtual void | ChildSaveState (vtkPVXMLElement *domainElement) |
| vtkSMSessionObject () |
| ~vtkSMSessionObject () override |
| vtkSMObject () |
| ~vtkSMObject () override |
| vtkObject () |
virtual | ~vtkObject () |
| vtkObjectBase () |
virtual | ~vtkObjectBase () |
| vtkObjectBase (const vtkObjectBase &) |
a domain with two values: true or false
vtkSMBooleanDomain does not really restrict the values of the property that contains it. All integer values are valid. Rather, it is used to specified that the property represents a true/false state. This domains works with only vtkSMIntVectorProperty.
- See also
- vtkSMDomain vtkSMIntVectorProperty
Definition at line 21 of file vtkSMBooleanDomain.h.
