Custom RenderViewProxy to override CreateDefaultRepresentation method so only the Multi-Slice representation will be available to the user.
const char * | IsSelectVisiblePointsAvailable () override |
| Similar to IsSelectionAvailable(), however, on failure returns the error message otherwise 0. More...
vtkSMRepresentationProxy * | CreateDefaultRepresentation (vtkSMProxy *proxy, int outputPort) override |
| Overridden to set initial default slices when a representation is created. More...
const char * | GetRepresentationType (vtkSMSourceProxy *producer, int outputPort) override |
| Overridden to forward the call to the internal root view proxy. More...
void | GetDataBounds (double bounds[6]) |
| Fetchs data bounds from the client-side object. More...
vtkSMRepresentationProxy * | Pick (int x, int y) |
| Convenience method to pick a location. More...
vtkSMRepresentationProxy * | PickBlock (int x, int y, unsigned int &flatIndex, int &rank) |
| Convenience method to pick a block in a multi-block data set. More...
bool | ConvertDisplayToPointOnSurface (const int display_position[2], double world_position[3], double world_normal[3], bool snapOnMeshPoint=false) |
| Given a location is display coordinates (pixels), tries to compute and return the world location and normal on a surface, if possible. More...
virtual bool | IsSelectionAvailable () |
| Checks if color depth is sufficient to support selection. More...
void | SynchronizeGeometryBounds () |
| Call SynchronizeGeometryBounds server side. More...
virtual void | ZoomTo (vtkSMProxy *representation, bool closest=false, double offsetRatio=0.9) |
| Convenience method for zooming to a representation. More...
void | SetupInteractor (vtkRenderWindowInteractor *iren) override |
| A client process need to set the interactor to enable interactivity. More...
vtkRenderWindowInteractor * | GetInteractor () override |
| Returns the interactor. More...
vtkRenderer * | GetRenderer () |
| Returns the client-side renderer (composited or 3D). More...
void | UpdateVTKObjects () override |
| Filter changes to the OSPRay rendering method, to transfer the pathtracing materials from client to server only when they are acutally needed. More...
void | SynchronizeCameraProperties () |
| This method calls UpdateInformation on the Camera Proxy and sets the Camera properties according to the info properties. More...
virtual bool | LastRenderWasInteractive () |
| Returns true if the most recent render indeed employed low-res rendering. More...
void | Update () override |
| Called vtkPVView::Update on the server-side. More...
bool | GetNeedsUpdate () override |
| We override that method to handle LOD and non-LOD NeedsUpdate in transparent manner. More...
bool | StreamingUpdate (bool render_if_needed) |
| Called to render a streaming pass. More...
| Overridden to check through the various representations that this view can create. More...
vtkRenderWindow * | GetRenderWindow () override |
| Returns the render window used by this view. More...
vtkSMViewProxyInteractorHelper * | GetInteractorHelper () |
| Provides access to the vtkSMViewProxyInteractorHelper object that handles the interaction/view sync. More...
vtkFloatArray * | CaptureDepthBuffer () |
| Access to the Z buffer. More...
virtual const char * | GetSelectionRepresentationProxyName () |
| Get the SelectionRepresentation proxy name. More...
virtual void | CopySelectionRepresentationProperties (vtkSMProxy *vtkNotUsed(fromSelectionRep), vtkSMProxy *vtkNotUsed(toSelectionRep)) |
| Function to copy selection representation properties. More...
void | ComputeVisibleBounds (vtkSMProxy *representation, double *bounds) |
| Compute the bounds of the visible data on the given representation. More...
bool | ClearSelectionCache (bool force=false) |
| Tries to clear the selection cache (if needed). More...
bool | SelectSurfaceCells (const int region[4], vtkCollection *selectedRepresentations, vtkCollection *selectionSources, bool multiple_selections=false, int modifier=0, bool select_blocks=false, const char *arrayName=nullptr) |
| Makes a new selection source proxy. More...
bool | SelectSurfacePoints (const int region[4], vtkCollection *selectedRepresentations, vtkCollection *selectionSources, bool multiple_selections=false, int modifier=0, bool select_blocks=false, const char *arrayName=nullptr) |
bool | SelectFrustumCells (const int region[4], vtkCollection *selectedRepresentations, vtkCollection *selectionSources, bool multiple_selections=false) |
bool | SelectFrustumPoints (const int region[4], vtkCollection *selectedRepresentations, vtkCollection *selectionSources, bool multiple_selections=false) |
bool | SelectPolygonPoints (vtkIntArray *polygon, vtkCollection *selectedRepresentations, vtkCollection *selectionSources, bool multiple_selections=false, int modifier=0, bool selectBlocks=false) |
bool | SelectPolygonCells (vtkIntArray *polygon, vtkCollection *selectedRepresentations, vtkCollection *selectionSources, bool multiple_selections=false, int modifier=0, bool selectBlocks=false) |
bool | ComputeVisibleScalarRange (const int region[4], int fieldAssociation, const char *scalarName, int component, double range[]) |
| Returns the range for visible elements in the current view. More...
bool | ComputeVisibleScalarRange (int fieldAssociation, const char *scalarName, int component, double range[]) |
void | ResetCamera (bool closest=false, double offsetRatio=0.9) |
| For backwards compatibility in Python scripts. More...
void | ResetCamera (double bounds[6], bool closest=false, double offsetRatio=0.9) |
void | ResetCamera (double xmin, double xmax, double ymin, double ymax, double zmin, double zmax, bool closest=false, double offsetRatio=0.9) |
virtual const char * | IsSelectVisibleCellsAvailable () |
vtkCamera * | GetActiveCamera () |
| Returns the client-side active camera object. More...
void | AdjustActiveCamera (const CameraAdjustmentType &, const double &) |
void | AdjustActiveCamera (const int &, const double &) |
void | AdjustAzimuth (const double &value) |
void | AdjustElevation (const double &value) |
void | AdjustRoll (const double &value) |
void | AdjustZoom (const double &value) |
void | ApplyIsometricView () |
void | ResetActiveCameraToDirection (const double &look_x, const double &look_y, const double &look_z, const double &up_x, const double &up_y, const double &up_z) |
void | ResetActiveCameraToPositiveX () |
void | ResetActiveCameraToNegativeX () |
void | ResetActiveCameraToPositiveY () |
void | ResetActiveCameraToNegativeY () |
void | ResetActiveCameraToPositiveZ () |
void | ResetActiveCameraToNegativeZ () |
virtual void | StillRender () |
| Renders the view using full resolution. More...
virtual void | InteractiveRender () |
| Renders the view using lower resolution is possible. More...
virtual bool | CanDisplayData (vtkSMSourceProxy *producer, int outputPort) |
| Returns true if the view can display the data produced by the producer's port. More...
virtual vtkSMRepresentationProxy * | FindRepresentation (vtkSMSourceProxy *producer, int outputPort) |
| Finds the representation proxy showing the data produced by the provided producer, if any. More...
vtkView * | GetClientSideView () |
| Returns the client-side vtkView, if any. More...
int | WriteImage (const char *filename, const char *writerName, int magnification=1) |
| Saves a screenshot of the view to disk. More...
int | WriteImage (const char *filename, const char *writerName, int magnificationX, int magnificationY) |
virtual bool | HasDirtyRepresentation () |
| Return true any internal representation is dirty. More...
virtual bool | MakeRenderWindowInteractor (bool quiet=false) |
| Creates a default render window interactor for the vtkRenderWindow and sets it up on the local process if the local process supports interaction. More...
virtual void | SetEnable (bool) |
| Enable/Disable a view. More...
virtual bool | GetEnable () |
virtual void | EnableOn () |
virtual void | EnableOff () |
vtkImageData * | CaptureWindow (int magnification) |
| Captures a image from this view. More...
vtkImageData * | CaptureWindow (int magnificationX, int magnificationY) |
virtual bool | HideOtherRepresentationsIfNeeded (vtkSMProxy *repr) |
| Method used to hide other representations if the view has a <ShowOneRepresentationAtATime/> hint. More...
virtual void | RepresentationVisibilityChanged (vtkSMProxy *repr, bool new_visibility) |
| Certain views maintain properties (or other state) that should be updated when visibility of representations is changed e.g. More...
bool | IsDeprecated () |
bool | GetIsSubProxy () |
bool | HasGlobalID () |
bool | IsPrototype () |
virtual void | Modified () |
| vtkSMMultiSliceViewProxy () |
| ~vtkSMMultiSliceViewProxy () override |
void | InitDefaultSlices (vtkSMSourceProxy *source, int opport, vtkSMRepresentationProxy *repr) |
| Use the center of the source to initialize the view with three orthogonal slices in x, y, z. More...
| vtkSMRenderViewProxy () |
| ~vtkSMRenderViewProxy () override |
void | RenderForImageCapture () override |
| Overridden to call this->InteractiveRender() if "UseInteractiveRenderingForScreenshots" is true. More...
void | UpdateLOD () |
| Calls UpdateLOD() on the vtkPVRenderView. More...
void | MarkDirty (vtkSMProxy *modifiedProxy) override |
| Overridden to ensure that we clean up the selection cache on the server side. More...
bool | SelectFrustumInternal (const int region[4], vtkCollection *selectedRepresentations, vtkCollection *selectionSources, bool multiple_selections, int fieldAssociation) |
bool | SelectPolygonInternal (vtkIntArray *polygon, vtkCollection *selectedRepresentations, vtkCollection *selectionSources, bool multiple_selections, int fieldAssociation, int modifier, bool selectBlocks) |
vtkTypeUInt32 | PreRender (bool interactive) override |
void | PostRender (bool interactive) override |
bool | FetchLastSelection (bool multiple_selections, vtkCollection *selectedRepresentations, vtkCollection *selectionSources, int modifier, bool selectBlocks) |
| Fetches the LastSelection from the data-server and then converts it to a selection source proxy and returns that. More...
void | CreateVTKObjects () override |
| Called at the end of CreateVTKObjects(). More...
bool | IsInSelectionMode () |
| Returns true if the proxy is in interaction mode that corresponds to making a selection i.e. More...
void | NewMasterCallback (vtkObject *src, unsigned long event, void *data) |
| vtkSMViewProxy () |
| ~vtkSMViewProxy () override |
virtual vtkImageData * | CaptureWindowInternal (int magnificationX, int magnificationY) |
| Capture an image from the view's render window. More...
virtual vtkTypeUInt32 | PreRender (bool vtkNotUsed(interactive)) |
| This method is called before executing code that could cause a render on the underlying vtkPVView. More...
virtual void | PostRender (bool vtkNotUsed(interactive)) |
virtual bool | IsContextReadyForRendering () |
| Subclasses should override this method and return false if the rendering context is not ready for rendering at this moment. More...
int | ReadXMLAttributes (vtkSMSessionProxyManager *pm, vtkPVXMLElement *element) override |
| Read attributes from an XML element. More...
bool | GetLocalProcessSupportsInteraction () |
| Convenience method to call vtkPVView::SafeDownCast(this->GetClientSideObject())->GetLocalProcessSupportsInteraction();. More...
virtual vtkSMDataDeliveryManagerProxy * | GetDeliveryManager () |
| Provides access to the delivery manager proxy, if any. More...
virtual void | SetDefaultRepresentationName (const char *) |
| vtkSMProxy () |
| ~vtkSMProxy () override |
void | ExecuteStream (const vtkClientServerStream &msg, bool ignore_errors=false, vtkTypeUInt32 location=0) |
| Invoke that takes a vtkClientServerStream as the argument. More...
virtual void | UpdateAndPushAnnotationState () |
virtual void | AddProperty (const char *name, vtkSMProperty *prop) |
| Add a property with the given key (name). More...
virtual void | MarkConsumersAsDirty (vtkSMProxy *modifiedProxy) |
| Calls MarkDirtyFromProducer on all consumers. More...
virtual void | MarkDirtyFromProducer (vtkSMProxy *modifiedProxy, vtkSMProxy *producer, vtkSMProperty *property) |
| MarkConsumersAsDirty calls this method on each consumer, instead of directly calling MarkDirty on the consumer. More...
void | MarkInputsAsDirty () |
| This method is called by vtkSMRepresentationProxy whenever the time request for the pipeline may have potentially changed. More...
| Cleanup code. More...
virtual void | SetPropertyModifiedFlag (const char *name, int flag) |
| Note on property modified flags: The modified flag of each property associated with a proxy is stored in the proxy object instead of in the property itself. More...
void | AddSubProxy (const char *name, vtkSMProxy *proxy, int overrideOK=0) |
| Add a sub-proxy. More...
void | RemoveSubProxy (const char *name) |
| Remove a sub-proxy. More...
vtkSMProxy * | GetSubProxy (const char *name) |
| Returns a sub-proxy. More...
vtkSMProxy * | GetSubProxy (unsigned int index) |
const char * | GetSubProxyName (unsigned int index) |
| Returns the name used to store sub-proxy. More...
const char * | GetSubProxyName (vtkSMProxy *) |
unsigned int | GetNumberOfSubProxies () |
| Returns the number of sub-proxies. More...
virtual void | AddConsumer (vtkSMProperty *property, vtkSMProxy *proxy) |
| Called by a proxy property, this adds the property,proxy pair to the list of consumers. More...
virtual void | RemoveConsumer (vtkSMProperty *property, vtkSMProxy *proxy) |
| Remove the property,proxy pair from the list of consumers. More...
virtual void | RemoveAllConsumers () |
| Remove all consumers. More...
void | AddProducer (vtkSMProperty *property, vtkSMProxy *proxy) |
| Called by an proxy/input property to add property, proxy pair to the list of producers. More...
void | RemoveProducer (vtkSMProperty *property, vtkSMProxy *proxy) |
| Remove the property,proxy pair from the list of producers. More...
virtual void | PostUpdateData (bool using_cache) |
| This method is called after the algorithm(s) (if any) associated with this proxy execute. More...
void | PostUpdateDataSelfOnly (bool using_cache) |
| This is called by PostUpdateData to only update state for this proxy without iterative over producers. More...
bool | WarnIfDeprecated () |
| If a proxy is deprecated, prints a warning. More...
bool | LoadPluginIfEnsured () |
| If a proxy need to ensure a plugin is loaded, make sure it is. More...
virtual void | UpdatePipelineInformation () |
| This method simply iterates over subproxies and calls UpdatePipelineInformation() on them. More...
void | LinkProperty (vtkSMProperty *inputProperty, vtkSMProperty *outputProperty) |
| Links properties such that when inputProperty's checked or unchecked values are changed, the outputProperty's corresponding values are also changed. More...
vtkSMPropertyGroup * | NewPropertyGroup (vtkPVXMLElement *propElement) |
| Parses the XML to create a new property group. More...
void | AppendPropertyGroup (vtkSMPropertyGroup *group) |
| Adds a property groups. More...
void | ExposeSubProxyProperty (const char *subproxy_name, const char *property_name, const char *exposed_name, int overrideOK=0) |
| Expose a subproxy property from the base proxy. More...
virtual void | ExecuteSubProxyEvent (vtkSMProxy *o, unsigned long event, void *data) |
| Handle events fired by subproxies. More...
virtual int | CreateSubProxiesAndProperties (vtkSMSessionProxyManager *pm, vtkPVXMLElement *element) |
virtual void | UpdatePropertyInformationInternal (vtkSMProperty *prop=nullptr) |
| Called to update the property information on the property. More...
void | RebuildStateForProperties () |
| vtkSMProxy tracks state of properties on this proxy in an internal State object. More...
virtual void | SetLogNameInternal (const char *name, bool propagate_to_subproxies, bool propagate_to_proxylistdomains) |
| Internal method used by SetLogName More...
bool | ArePropertiesModified () |
| Indicates if any properties are modified. More...
void | SetHints (vtkPVXMLElement *hints) |
void | SetDeprecated (vtkPVXMLElement *deprecated) |
void | SetEnsurePluginLoaded (vtkPVXMLElement *ensurePluginLoaded) |
| Set the "EnsurePluginLoaded" XML element that is used in LoadPluginIfEnsured. More...
void | SetXMLElement (vtkPVXMLElement *element) |
| vtkSMProxy (const vtkSMProxy &)=delete |
void | operator= (const vtkSMProxy &)=delete |
virtual const vtkClientServerStream & | GetLastResult () |
| Get the last result. More...
virtual const vtkClientServerStream & | GetLastResult (vtkTypeUInt32 location) |
virtual void | SetXMLGroup (const char *) |
virtual void | SetXMLLabel (const char *) |
virtual void | SetXMLSubProxyName (const char *) |
vtkSMProperty * | NewProperty (const char *name) |
| Creates a new property and initializes it by calling ReadXMLAttributes() with the right XML element. More...
vtkSMProperty * | NewProperty (const char *name, vtkPVXMLElement *propElement) |
void | SetupExposedProperties (const char *subproxy_name, vtkPVXMLElement *element) |
void | SetupSharedProperties (vtkSMProxy *subproxy, vtkPVXMLElement *element) |
virtual void | SetSIClassName (const char *) |
| SIClassName identifies the classname for the helper on the server side. More...
virtual char * | GetSIClassName () |
| vtkSMRemoteObject () |
| Default constructor. More...
| ~vtkSMRemoteObject () override |
| Destructor. More...
void | PushState (vtkSMMessage *msg) |
| Subclasses can call this method to send a message to its state object on the server processes specified. More...
bool | PullState (vtkSMMessage *msg) |
| Subclasses can call this method to pull the state from the state-object on the server processes specified. More...
void | SetGlobalID (vtkTypeUInt32 guid) |
| Set the GlobalUniqueId. More...
vtkTypeUInt32 | GetFilteredLocation () |
| vtkSMSessionObject () |
| ~vtkSMSessionObject () override |
| vtkSMObject () |
| ~vtkSMObject () override |
| vtkObject () |
virtual | ~vtkObject () |
| vtkObjectBase () |
virtual | ~vtkObjectBase () |
| vtkObjectBase (const vtkObjectBase &) |
