union of proxies. More...
#include <vtkSMProxyListDomain.h>
struct | ProxyType |
Used to identify a proxy type. More... | |
typedef vtkSMDomain | Superclass |
enum | IsInDomainReturnCodes { NOT_APPLICABLE = -1, NOT_IN_DOMAIN = 0, IN_DOMAIN = 1 } |
const std::vector< ProxyType > & | GetProxyTypes () const |
Returns a vector of proxy types for the proxies in the domain. More... | |
unsigned int | GetNumberOfProxyTypes () |
Returns the number of proxies in the domain. More... | |
const char * | GetProxyGroup (unsigned int index) |
Returns the xml group name for the proxy at a given index. More... | |
const char * | GetProxyName (unsigned int index) |
Returns the xml type name for the proxy at a given index. More... | |
const char * | GetProxyName (vtkSMProxy *proxy) |
If the proxy is part of the domain, then this returns the name used for the proxy in the domain. More... | |
vtkSMProxy * | GetProxyWithName (const char *pname) |
Inverse of GetProxyName , returns the first proxy with the given name. More... | |
int | IsInDomain (vtkSMProperty *property) override |
This always returns true. More... | |
void | AddProxy (vtkSMProxy *) |
Add a proxy to the domain. More... | |
bool | HasProxy (vtkSMProxy *) |
Returns if the proxy is present in the domain. More... | |
unsigned int | GetNumberOfProxies () |
Get number of proxies in the domain. More... | |
vtkSMProxy * | GetProxy (unsigned int index) |
Get proxy at a given index. More... | |
vtkSMProxy * | FindProxy (const char *xmlgroup, const char *xmlname) |
Find a proxy in the domain of the given group and type. More... | |
int | RemoveProxy (vtkSMProxy *proxy) |
Removes the first occurrence of the proxy in the domain. More... | |
int | RemoveProxy (unsigned int index) |
Removes the proxy at the given index. More... | |
void | CreateProxies (vtkSMSessionProxyManager *pxm) |
Creates and populates the domain with the proxy-types. More... | |
int | SetDefaultValues (vtkSMProperty *prop, bool use_unchecked_values) override |
A vtkSMProperty is often defined with a default value in the XML itself. More... | |
void | SetLogName (const char *prefix) |
Sets log name for each of the proxy in the domain using the prefix provided. More... | |
virtual void | SetDefaultIndex (unsigned int) |
Set and Get the default proxy index. More... | |
virtual unsigned int | GetDefaultIndex () |
Is the (unchecked) value of the property in the domain? Overwritten by sub-classes. More... | |
virtual void | Update (vtkSMProperty *requestingProperty) |
Update self based on the "unchecked" values of all required properties. More... | |
Set the value of an element of a property from the animation editor. More... | |
Provides access to the vtkSMProperty on which this domain is hooked up. More... | |
Helper method to get the number of input connections hence the number of available vtkPVDataInformation from input proxy connected to the required property with the given function. More... | |
Returns a given required property of the given function. More... | |
When the IsOptional flag is set, IsInDomain() always returns true. More... | |
Helper methods to get vtkPVDataInformation from input proxy connected to the required property with the given function and provided input index. More... | |
virtual void | Modified () |
static vtkSMProxyListDomain * | New () |
static vtkSMProxyListDomain * | SafeDownCast (vtkObject *o) |
static vtkSMDomain * | New () |
static vtkSMDomain * | SafeDownCast (vtkObject *o) |
static vtkObject * | New () |
vtkSMProxyListDomain () | |
~vtkSMProxyListDomain () override | |
int | ReadXMLAttributes (vtkSMProperty *prop, vtkPVXMLElement *element) override |
Set the appropriate ivars from the xml element. More... | |
void | AddProxy (const char *group, const char *name) |
Adds a proxy type, used by ReadXMLAttributes(). More... | |
void | ChildSaveState (vtkPVXMLElement *propertyElement) override |
Save state for this domain. More... | |
int | LoadState (vtkPVXMLElement *domainElement, vtkSMProxyLocator *loader) override |
void | SetProxies (vtkSMProxy **proxies, unsigned int count) |
vtkSMDomain () | |
~vtkSMDomain () override | |
Load the state of the domain from the XML. More... | |
Remove the given property from the required properties list. More... | |
Add a new required property to this domain. More... | |
void | DomainModified () |
Invokes DomainModifiedEvent. More... | |
void | InvokeModified () |
Gets the number of required properties added. More... | |
Set the domain's property. More... | |
Add the header and creates a new vtkPVXMLElement for the domain, fills it up with the common attributes. More... | |
vtkSMSessionObject () | |
vtkSMObject () | |
~vtkSMObject () override | |
vtkObject () | |
virtual | ~vtkObject () |
vtkObjectBase () | |
virtual | ~vtkObjectBase () |
Protected Attributes | |
unsigned int | DefaultIndex = 0 |
char * | XMLName |
bool | IsOptional |
vtkSMDomainInternals * | Internals |
vtkWeakPointer< vtkSMSession > | Session |
Identifies the session id to which this object is related. More... | |
bool | Debug |
vtkTimeStamp | MTime |
Friends | |
class | vtkSMProxyProperty |
union of proxies.
This domain is a collection of proxies that can be assigned as the value to a vtkSMProxyProperty. The Server Manager configuration defines the proxy types that form this list, while the value of this domain is the list of instances of proxies. Example usage :
Definition at line 40 of file vtkSMProxyListDomain.h.
Definition at line 44 of file vtkSMProxyListDomain.h.
Reimplemented in vtkSMRangedTransferFunctionDomain.
const std::vector<ProxyType>& vtkSMProxyListDomain::GetProxyTypes | ( | ) | const |
unsigned int vtkSMProxyListDomain::GetNumberOfProxyTypes | ( | ) |
const char* vtkSMProxyListDomain::GetProxyName | ( | vtkSMProxy * | proxy | ) |
If the proxy
Returns nullptr otherwise.
vtkSMProxy* vtkSMProxyListDomain::GetProxyWithName | ( | const char * | pname | ) |
void vtkSMProxyListDomain::AddProxy | ( | vtkSMProxy * | ) |
bool vtkSMProxyListDomain::HasProxy | ( | vtkSMProxy * | ) |
unsigned int vtkSMProxyListDomain::GetNumberOfProxies | ( | ) |
vtkSMProxy* vtkSMProxyListDomain::GetProxy | ( | unsigned int | index | ) |
vtkSMProxy* vtkSMProxyListDomain::FindProxy | ( | const char * | xmlgroup, |
const char * | xmlname | ||
int vtkSMProxyListDomain::RemoveProxy | ( | vtkSMProxy * | proxy | ) |
in the domain.
Returns if the proxy was removed.
void vtkSMProxyListDomain::CreateProxies | ( | vtkSMSessionProxyManager * | pxm | ) |
Note that the newly created proxies won't be registered with the proxy manager.
However, many times, the default value must be determined at run time. To facilitate this, domains can override this method to compute and set the default value for the property. Note that unlike the compile-time default values, the application must explicitly call this method to initialize the property.
void vtkSMProxyListDomain::SetLogName | ( | const char * | prefix | ) |
overrideprotectedvirtual |
friend |
Definition at line 190 of file vtkSMProxyListDomain.h.
Definition at line 193 of file vtkSMProxyListDomain.h.
