int | IsInDomain (vtkSMProperty *property) override |
| Returns true if the value of the property is in the domain. More...
std::vector< double > | GetValues () |
| Returns the vector of values. More...
bool | GetValuesExists () |
| Returns if Values is non empty. More...
void | Update (vtkSMProperty *property) override |
| Updates this from the property. More...
| Is the (unchecked) value of the property in the domain? Overwritten by sub-classes. More...
| Set the value of an element of a property from the animation editor. More...
| A vtkSMProperty is often defined with a default value in the XML itself. More...
| Provides access to the vtkSMProperty on which this domain is hooked up. More...
| Helper method to get the number of input connections hence the number of available vtkPVDataInformation from input proxy connected to the required property with the given function. More...
| Returns a given required property of the given function. More...
| When the IsOptional flag is set, IsInDomain() always returns true. More...
| Helper methods to get vtkPVDataInformation from input proxy connected to the required property with the given function and provided input index. More...
virtual void | Modified () |
| vtkSMDiscreteDoubleDomain () |
| ~vtkSMDiscreteDoubleDomain () override |
int | ReadXMLAttributes (vtkSMProperty *prop, vtkPVXMLElement *element) override |
| Reads the "values" property, with a maximum of 256 values. More...
| vtkSMDomain () |
| ~vtkSMDomain () override |
| Load the state of the domain from the XML. More...
| Remove the given property from the required properties list. More...
| Add a new required property to this domain. More...
void | DomainModified () |
| Invokes DomainModifiedEvent. More...
void | InvokeModified () |
| Gets the number of required properties added. More...
| Set the domain's property. More...
| Add the header and creates a new vtkPVXMLElement for the domain, fills it up with the common attributes. More...
virtual void | ChildSaveState (vtkPVXMLElement *domainElement) |
| vtkSMSessionObject () |
| ~vtkSMSessionObject () override |
| vtkSMObject () |
| ~vtkSMObject () override |
| vtkObject () |
virtual | ~vtkObject () |
| vtkObjectBase () |
virtual | ~vtkObjectBase () |
| vtkObjectBase (const vtkObjectBase &) |
set of double
vtkSMDiscreteDoubleDomain represents a set of double values. It supports a maximum of 256 values.
Values are specified in xml as follow:
<DiscreteDoubleDomain values='val1 val2 ... valX' />
Definition at line 26 of file vtkSMDiscreteDoubleDomain.h.
