void | Synchronize (vtkPVSession::ServerFlags from=vtkPVSession::RENDER_SERVER_ROOT, vtkPVSession::ServerFlags to=vtkPVSession::CLIENT) |
| Copies the Material library on the root node of server to the client by default. More...
void | LoadDefaultMaterials () |
| Reads default materials on the process. More...
void | LoadMaterials (const char *) |
| Reads and specified materials. More...
void | UpdateVTKObjects () override |
| Overridden to control load from server file system. More...
bool | IsDeprecated () |
bool | GetIsSubProxy () |
bool | HasGlobalID () |
bool | IsPrototype () |
virtual void | Modified () |
