virtual vtkSMRenderViewProxy * | GetRenderView () |
| Get/Set the (render) View Module from which we are writing the geometry. More...
void | SetRenderView (vtkSMRenderViewProxy *) |
virtual void | SetAnimationScene (vtkSMProxy *) |
| Convenience method to set the proxy. More...
bool | Save () |
| Begin the saving. More...
virtual void | SetAnimationScene (vtkSMAnimationScene *) |
| Get/Set the animation scene that this writer will write. More...
virtual vtkSMAnimationScene * | GetAnimationScene () |
virtual void | SetFileName (const char *) |
| Get/Set the filename. More...
virtual char * | GetFileName () |
virtual void | SetStartFileCount (int) |
| Get/Set the start file count. More...
virtual int | GetStartFileCount () |
virtual void | SetPlaybackTimeWindow (double, double) |
| Get/Set time window that we want to write If PlaybackTimeWindow[0] > PlaybackTimeWindow[1] that mean that we want to export the full time range available. More...
void | SetPlaybackTimeWindow (double [2]) |
virtual double * | GetPlaybackTimeWindow () |
virtual void | GetPlaybackTimeWindow (double &, double &) |
virtual void | GetPlaybackTimeWindow (double [2]) |
virtual void | SetStride (int) |
| Set/Get The stride which is used to extract the next frame. More...
virtual int | GetStride () |
virtual void | Modified () |
