virtual void | OnStartInteraction () |
| These method forward the representation state of the client side widget representation to the server. More...
virtual void | OnEndInteraction () |
virtual void | OnInteraction () |
bool | IsDeprecated () |
bool | GetIsSubProxy () |
bool | HasGlobalID () |
bool | IsPrototype () |
virtual void | Modified () |
