extends vtkSMArrayListDomain to add support for arrays from represented data information. More...
#include <vtkSMRepresentedArrayListDomain.h>
typedef vtkSMArrayListDomain | Superclass |
enum | InformationKeyStrategy { NEED_KEY, REJECT_KEY } |
typedef vtkSMStringListDomain | Superclass |
typedef vtkSMDomain | Superclass |
enum | IsInDomainReturnCodes { NOT_APPLICABLE = -1, NOT_IN_DOMAIN = 0, IN_DOMAIN = 1 } |
void | Update (vtkSMProperty *) override |
Update the domain. More... | |
virtual bool | GetUseTrueParentForRepresentatedDataInformation () |
Set this to true (default) to let this domain use the represented-data-information from the outer most representation proxy. More... | |
int | IsArrayPartial (unsigned int idx) |
Returns true if the array with the given idx is partial false otherwise. More... | |
int | GetFieldAssociation (unsigned int idx) |
Get field association for the array. More... | |
int | GetDomainAssociation (unsigned int idx) |
Get the true field association for the array. More... | |
int | SetDefaultValues (vtkSMProperty *, bool use_unchecked_values) override |
A vtkSMProperty is often defined with a default value in the XML itself. More... | |
unsigned int | RemoveInformationKey (const char *location, const char *name) |
Removes an InformationKey from this domain. More... | |
unsigned int | GetNumberOfInformationKeys () |
Returns the number of InformationKeys in this domain. More... | |
void | RemoveAllInformationKeys () |
Removes all InformationKeys from this domain. More... | |
virtual int | GetAttributeType () |
Return the attribute type. More... | |
virtual unsigned int | AddInformationKey (const char *location, const char *name, int strategy) |
Adds a new InformationKey to the domain. More... | |
virtual unsigned int | AddInformationKey (const char *location, const char *name) |
const char * | GetInformationKeyLocation (unsigned int) |
Returns the location/name/strategy of a given InformationKey. More... | |
const char * | GetInformationKeyName (unsigned int) |
int | GetInformationKeyStrategy (unsigned int) |
int | IsInDomain (vtkSMProperty *property) override |
Returns true if the value of the property is in the domain. More... | |
int | IsInDomain (const char *string, unsigned int &idx) |
Returns true if the string is in the domain. More... | |
const char * | GetString (unsigned int idx) |
Returns a string in the domain. More... | |
unsigned int | GetNumberOfStrings () |
Returns the number of strings in the domain. More... | |
void | SetAnimationValue (vtkSMProperty *, int, double) override |
Set the value of an element of a property from the animation editor. More... | |
virtual char * | GetNoneString () |
Return the string that is used as "none_string" in XML configuration. More... | |
virtual void | SetNoneString (const char *) |
Is the (unchecked) value of the property in the domain? Overwritten by sub-classes. More... | |
Provides access to the vtkSMProperty on which this domain is hooked up. More... | |
Helper method to get the number of input connections hence the number of available vtkPVDataInformation from input proxy connected to the required property with the given function. More... | |
Returns a given required property of the given function. More... | |
When the IsOptional flag is set, IsInDomain() always returns true. More... | |
Helper methods to get vtkPVDataInformation from input proxy connected to the required property with the given function and provided input index. More... | |
virtual void | Modified () |
static vtkSMRepresentedArrayListDomain * | New () |
static vtkSMRepresentedArrayListDomain * | SafeDownCast (vtkObject *o) |
static vtkSMArrayListDomain * | New () |
static vtkSMArrayListDomain * | SafeDownCast (vtkObject *o) |
static std::string | CreateMangledName (vtkPVArrayInformation *arrayInfo, int component) |
returns the mangled name for the component index that is passed in. More... | |
static std::string | ArrayNameFromMangledName (const char *name) |
static int | ComponentIndexFromMangledName (vtkPVArrayInformation *info, const char *name) |
static vtkSMStringListDomain * | New () |
static vtkSMStringListDomain * | SafeDownCast (vtkObject *o) |
static vtkSMDomain * | New () |
static vtkSMDomain * | SafeDownCast (vtkObject *o) |
static vtkObject * | New () |
vtkSMRepresentedArrayListDomain () | |
~vtkSMRepresentedArrayListDomain () override | |
int | ReadXMLAttributes (vtkSMProperty *prop, vtkPVXMLElement *elem) override |
Overridden to process "use_true_parent". More... | |
bool | IsFilteredArray (vtkPVDataInformation *info, int association, const char *arrayName) override |
Returns true if an array should be filtered out based on its name or number of tuples (for field data arrays). More... | |
vtkPVDataInformation * | GetExtraDataInformation () override |
HACK: Provides a temporary mechanism for subclasses to provide an "additional" vtkPVDataInformation instance to get available arrays list from. More... | |
void | SetRepresentationProxy (vtkSMRepresentationProxy *) |
void | OnRepresentationDataUpdated () |
virtual void | SetUseTrueParentForRepresentatedDataInformation (bool) |
vtkSMArrayListDomain () | |
~vtkSMArrayListDomain () override | |
virtual char * | GetInputDomainName () |
InputDomainName refers to a input property domain that describes the type of array is needed by this property. More... | |
virtual void | SetInputDomainName (const char *) |
virtual void | SetAttributeType (int) |
Set to an attribute type defined in vtkDataSetAttributes. More... | |
void | ChildSaveState (vtkPVXMLElement *domainElement) override |
Add the header and creates a new vtkPVXMLElement for the domain, fills it up with the common attributes. More... | |
virtual void | SetStrings (const std::vector< std::string > &strings) |
Call to set the strings. More... | |
const std::vector< std::string > & | GetStrings () |
vtkSMStringListDomain () | |
~vtkSMStringListDomain () override | |
vtkSMDomain () | |
~vtkSMDomain () override | |
Load the state of the domain from the XML. More... | |
Remove the given property from the required properties list. More... | |
Add a new required property to this domain. More... | |
void | DomainModified () |
Invokes DomainModifiedEvent. More... | |
void | InvokeModified () |
Gets the number of required properties added. More... | |
Set the domain's property. More... | |
vtkSMSessionObject () | |
vtkSMObject () | |
~vtkSMObject () override | |
vtkObject () | |
virtual | ~vtkObject () |
vtkObjectBase () | |
virtual | ~vtkObjectBase () |
Protected Attributes | |
vtkWeakPointer< vtkSMRepresentationProxy > | RepresentationProxy |
unsigned long | ObserverId |
bool | UseTrueParentForRepresentatedDataInformation |
char * | InputDomainName |
bool | PickFirstAvailableArrayByDefault |
int | AttributeType |
char * | NoneString |
Default string always present in this string list. More... | |
char * | XMLName |
bool | IsOptional |
vtkSMDomainInternals * | Internals |
vtkWeakPointer< vtkSMSession > | Session |
Identifies the session id to which this object is related. More... | |
bool | Debug |
vtkTimeStamp | MTime |
Representations often add new arrays on top of the ones provided by the inputs to the representations. In that case, the domains for properties that allow users to pick one of those newly added arrays need to show those arrays e.g. "ColorArrayName" property of geometry representations. This domain extends vtkSMArrayListDomain to add arrays from represented data for representations. If the chosen attribute type is not present on the data, no array (or none_string if available) will be chosen.
Definition at line 26 of file vtkSMRepresentedArrayListDomain.h.
Definition at line 30 of file vtkSMRepresentedArrayListDomain.h.
Reimplemented from vtkSMArrayListDomain.
Update the domain.
This ensures that for composite representations where user is provided with a selection between multiple representations, the represented array list domain fills its values up based on the currently active representation type, rather than the representation subproxy from which the property was exposed. In XML, use 'use_true_parent' attribute on the domain element to set this value.
overrideprotectedvirtual |
This implementation returns true if the array name matches an expression in the vtkPVColorArrayListSettings singleton.
protectedvirtual |
Definition at line 80 of file vtkSMRepresentedArrayListDomain.h.
Definition at line 81 of file vtkSMRepresentedArrayListDomain.h.
Definition at line 83 of file vtkSMRepresentedArrayListDomain.h.
