vtkSMRepresentedArrayListDomain.h
18 #ifndef vtkSMRepresentedArrayListDomain_h
19 #define vtkSMRepresentedArrayListDomain_h
20
21 #include "vtkRemotingViewsModule.h" //needed for exports
22 #include "vtkSMArrayListDomain.h"
23 #include "vtkWeakPointer.h" // needed for vtkWeakPointer.
24
27 {
28 public:
31  void PrintSelf(ostream& os, vtkIndent indent) override;
32
36  void Update(vtkSMProperty*) override;
37
50  vtkGetMacro(UseTrueParentForRepresentatedDataInformation, bool);
52
53 protected:
56
60  int ReadXMLAttributes(vtkSMProperty* prop, vtkPVXMLElement* elem) override;
61
68  bool IsFilteredArray(vtkPVDataInformation* info, int association, const char* arrayName) override;
69
76
77  void SetRepresentationProxy(vtkSMRepresentationProxy*);
78  void OnRepresentationDataUpdated();
79
81  unsigned long ObserverId;
82
83  vtkSetMacro(UseTrueParentForRepresentatedDataInformation, bool);
85
86 private:
88  void operator=(const vtkSMRepresentedArrayListDomain&) = delete;
89 };
90
91 #endif
Proxy for a representations.
void Update(vtkSMProperty *prop) override
Updates the string list based on the available arrays.
virtual vtkPVDataInformation * GetExtraDataInformation()
HACK: Provides a temporary mechanism for subclasses to provide an "additional" vtkPVDataInformation i...
int ReadXMLAttributes(vtkSMProperty *prop, vtkPVXMLElement *element) override
provides meta data about a vtkDataObject subclass.
extends vtkSMArrayListDomain to add support for arrays from represented data information.
vtkWeakPointer< vtkSMRepresentationProxy > RepresentationProxy
static vtkSMArrayListDomain * New()
virtual bool IsFilteredArray(vtkPVDataInformation *info, int association, const char *arrayName)
Returns true if an array should be filtered out.
list of arrays obtained from input
