65 #ifndef vtkSMArrayListDomain_h 66 #define vtkSMArrayListDomain_h 77 class vtkSMArrayListDomainInternals;
98 int IsArrayPartial(
unsigned int idx);
107 int GetFieldAssociation(
unsigned int idx);
126 int GetDomainAssociation(
unsigned int idx);
133 vtkGetMacro(AttributeType,
int);
167 virtual unsigned int AddInformationKey(
const char* location,
const char* name,
int strategy);
177 unsigned int RemoveInformationKey(
const char*
location,
const char*
name);
182 unsigned int GetNumberOfInformationKeys();
187 void RemoveAllInformationKeys();
193 const char* GetInformationKeyLocation(
unsigned int);
194 const char* GetInformationKeyName(
unsigned int);
195 int GetInformationKeyStrategy(
unsigned int);
209 static std::string ArrayNameFromMangledName(
const char* name);
235 virtual bool IsFilteredArray(
vtkPVDataInformation* info,
int association,
const char* arrayName);
241 vtkSetMacro(AttributeType,
int);
250 vtkGetStringMacro(InputDomainName);
251 vtkSetStringMacro(InputDomainName);
265 friend class vtkSMArrayListDomainInternals;
266 vtkSMArrayListDomainInternals* ALDInternals;
property representing pointer(s) to vtkObject(s)
virtual vtkPVDataInformation * GetExtraDataInformation()
HACK: Provides a temporary mechanism for subclasses to provide an "additional" vtkPVDataInformation i...
int AttributeType
Set to an attribute type defined in vtkDataSetAttributes.
domain to ensure that input has required types of arrays.
int ReadXMLAttributes(vtkSMProperty *prop, vtkPVXMLElement *element) override
virtual unsigned int AddInformationKey(const char *location, const char *name)
Adds a new InformationKey to the domain.
void Update(vtkSMProperty *) override
Update self checking the "unchecked" values of all required properties.
proxy for a VTK source on a server
static vtkSMStringListDomain * New()
bool PickFirstAvailableArrayByDefault
list of arrays obtained from input
int SetDefaultValues(vtkSMProperty *, bool use_unchecked_values) override
