proxy to save animation to images/video. More...
#include <vtkSMSaveAnimationProxy.h>
typedef vtkSMSaveScreenshotProxy | Superclass |
typedef vtkSMProxy | Superclass |
enum | ResetPropertiesMode { DEFAULT = 0, ONLY_XML = 1, ONLY_DOMAIN = 2 } |
enum | { COPY_PROXY_PROPERTY_VALUES_BY_REFERENCE = 0, COPY_PROXY_PROPERTY_VALUES_BY_CLONING } |
Flags used for the proxyPropertyCopyFlag argument to the Copy method. More... | |
typedef vtkSMRemoteObject | Superclass |
virtual bool | WriteAnimation (const char *filename, vtkTypeUInt32 location=vtkPVSession::CLIENT) |
Save animation as images/video. More... | |
void | UpdateDefaultsAndVisibilities (const char *filename) override |
Overridden to update visibility state of "FrameRate" property. More... | |
bool | WriteImage (const char *filename, vtkTypeUInt32 location=vtkPVSession::CLIENT, vtkPVXMLElement *stateXMLRoot=nullptr) |
Capture image. More... | |
vtkSmartPointer< vtkImageData > | CaptureImage () |
Capture the rendered image but doesn't save it out to any file. More... | |
std::string | GetFileFormatFilters () |
Convenience method to derive a QFileDialog friendly format string for extensions supported by this proxy. More... | |
Retrieve an annotation with a given key. More... | |
Remove a given annotation based on its key to the proxy. More... | |
Remove all proxy annotations. More... | |
Return true if a given annotation exists. More... | |
Return the number of available annotations. More... | |
Return the nth key of the available annotations. More... | |
Get/Set the location where the underlying VTK-objects are created. More... | |
Return the property with the given name. More... | |
Return a property of the given name from self or one of the sub-proxies. More... | |
Given a property pointer, returns the name that was used to add it to the proxy. More... | |
Update the VTK object on the server by pushing the values of all modified properties (un-modified properties are ignored). More... | |
Recreate the VTK object for this proxy. More... | |
Convenience method equivalent to UpdateProperty(name, 1). More... | |
Returns a new (initialized) iterator of the properties. More... | |
Returns the number of consumers. More... | |
Returns the consumer of given index. More... | |
Returns the corresponding property of the consumer of given index. More... | |
Returns the number of proxies this proxy depends on (uses or is connected to through the pipeline). More... | |
Returns a proxy this proxy depends on, given index. More... | |
Returns the property holding a producer proxy given an index. More... | |
Updates all property information by calling UpdateInformation() and populating the values. More... | |
Similar to UpdatePropertyInformation() but updates only the given property. More... | |
Marks all properties as modified. More... | |
Use this method to set all properties on this proxy to their default values. More... | |
Use this method to set all properties on this proxy to their default domains. More... | |
Use this method to set all properties on this proxy to their default domain or values. More... | |
Calls MarkDirty() and invokes ModifiedEvent. More... | |
bool | IsDeprecated () |
Returns true if the proxy has a deprecation tag. More... | |
Given a source proxy, makes this proxy point to the same server-side object (with a new id). More... | |
Dirty means this algorithm will execute during next update. More... | |
Returns the client side object associated with the VTKObjectID (if any). More... | |
Saves the state of the proxy. More... | |
The iterator is use to filter the property available on the given proxy. More... | |
Loads the proxy state from the XML element. More... | |
This method call UpdateVTKObjects on the current pipeline by starting at the sources. More... | |
bool | GetIsSubProxy () |
A proxy instance can be a sub-proxy for some other proxy. More... | |
If this instance is a sub-proxy, this method will return the proxy of which this instance is an immediate sub-proxy. More... | |
Call GetParentProxy() recursively till a proxy that is not a subproxy of any other proxy is found. More... | |
Allow to switch off any push of state change to the server for that particular object. More... | |
Enable the given remote object to communicate its state normally to the server location. More... | |
This method return the full object state that can be used to create that object from scratch. More... | |
This method is used to initialise the object to the given state If the definitionOnly Flag is set to True the proxy won't load the properties values and just setup the new proxy hierarchy with all subproxy globalID set. More... | |
Returns the number of property groups that the proxy contains. More... | |
A helper that makes up an default name if none is provided. More... | |
Return the property names that have values different from the otherProxy argument. More... | |
Update the value of one property (pushed to the server) if it is modified. More... | |
Returns the type of object managed by the proxy. More... | |
the type of object created by the proxy. More... | |
Copies values of all the properties and sub-proxies from src. More... | |
Returns the documentation for this proxy. More... | |
Returns if the VTK objects for this proxy have been created. More... | |
Gathers information about this proxy. More... | |
Allow user to set the remote object to be discard for Undo/Redo action. More... | |
Log name is a name for this proxy that will be used when logging status messages. More... | |
Override the SetSession so if the object already have an ID we automatically register it to the associated session. More... | |
bool | HasGlobalID () |
Allow the user to test if the RemoteObject has already a GlobalID without assigning a new one to it. More... | |
Let the session be aware that even if the Location is client only, the message should not be send to the server for a general broadcast. More... | |
Get the global unique id for this object. More... | |
bool | IsPrototype () |
virtual void | Modified () |
static vtkSMSaveAnimationProxy * | New () |
static vtkSMSaveAnimationProxy * | SafeDownCast (vtkObject *o) |
static vtkSMSaveScreenshotProxy * | New () |
static vtkSMSaveScreenshotProxy * | SafeDownCast (vtkObject *o) |
static vtkSmartPointer< vtkImageData > | CaptureImage (vtkSMViewProxy *view, const vtkVector2i &size) |
This method can be used to capture an image for a view for a specific resolution using default options. More... | |
static vtkSmartPointer< vtkImageData > | CaptureImage (vtkSMViewLayoutProxy *view, const vtkVector2i &size) |
This method can be used to capture an image for a layout for a specific resolution using default options. More... | |
static vtkVector2i | GetScaleFactorsAndSize (const vtkVector2i &targetSize, vtkVector2i &size, bool *approximate=nullptr) |
Compute scale factors and new size for target resolution. More... | |
static int | ComputeMagnification (const vtkVector2i &targetSize, vtkVector2i &size) |
Compute a single magnification factor to reach targetSize using a box that fits within size . More... | |
static vtkSMProxy * | New () |
static vtkSMProxy * | SafeDownCast (vtkObject *o) |
static vtkSMRemoteObject * | SafeDownCast (vtkObject *o) |
static vtkObject * | New () |
vtkSMSaveAnimationProxy () | |
~vtkSMSaveAnimationProxy () override | |
virtual bool | WriteAnimationInternal (const char *filename, vtkTypeUInt32 location=vtkPVSession::CLIENT) |
Write animation on local process. More... | |
bool | Prepare () override |
Prepares for saving animation. More... | |
bool | Cleanup () override |
This restores the state after saving the animation. More... | |
virtual bool | EnforceSizeRestrictions (const char *filename) |
Change "ImageResolution" property as needed for the file format requested. More... | |
vtkSMViewLayoutProxy * | GetLayout () |
vtkSMViewProxy * | GetView () |
vtkSMSaveScreenshotProxy * | GetScreenshotHelper () |
vtkSMProxy * | GetAnimationScene () |
vtkSMSaveScreenshotProxy () | |
~vtkSMSaveScreenshotProxy () override | |
std::pair< vtkSmartPointer< vtkImageData >, vtkSmartPointer< vtkImageData > > | CapturePreppedImages () |
When StereoMode is set to VTK_STEREO_EMULATE, both eyes are captures. More... | |
vtkSMProxy * | GetFormatProxy (const std::string &filename) |
Select the format proxy to match the given extension. More... | |
std::string | GetStereoFileName (const std::string &filename, bool left) |
Adds a stereo filename suffix to the given filename. More... | |
virtual void | SetUseFloatingPointBuffers (bool) |
vtkSMProxy () | |
~vtkSMProxy () override | |
void | ExecuteStream (const vtkClientServerStream &msg, bool ignore_errors=false, vtkTypeUInt32 location=0) |
Invoke that takes a vtkClientServerStream as the argument. More... | |
virtual void | UpdateAndPushAnnotationState () |
virtual void | AddProperty (const char *name, vtkSMProperty *prop) |
Add a property with the given key (name). More... | |
virtual void | MarkConsumersAsDirty (vtkSMProxy *modifiedProxy) |
virtual void | MarkDirtyFromProducer (vtkSMProxy *modifiedProxy, vtkSMProxy *producer, vtkSMProperty *property) |
MarkConsumersAsDirty calls this method on each consumer, instead of directly calling MarkDirty on the consumer. More... | |
void | MarkInputsAsDirty () |
This method is called by vtkSMRepresentationProxy whenever the time request for the pipeline may have potentially changed. More... | |
virtual void | CreateVTKObjects () |
Given a class name (by setting VTKClassName) and server ids (by setting ServerIDs), this methods instantiates the objects on the server(s) More... | |
Cleanup code. More... | |
virtual void | SetPropertyModifiedFlag (const char *name, int flag) |
Note on property modified flags: The modified flag of each property associated with a proxy is stored in the proxy object instead of in the property itself. More... | |
void | AddSubProxy (const char *name, vtkSMProxy *proxy, int overrideOK=0) |
Add a sub-proxy. More... | |
void | RemoveSubProxy (const char *name) |
Remove a sub-proxy. More... | |
vtkSMProxy * | GetSubProxy (const char *name) |
Returns a sub-proxy. More... | |
vtkSMProxy * | GetSubProxy (unsigned int index) |
const char * | GetSubProxyName (unsigned int index) |
Returns the name used to store sub-proxy. More... | |
const char * | GetSubProxyName (vtkSMProxy *) |
unsigned int | GetNumberOfSubProxies () |
Returns the number of sub-proxies. More... | |
virtual void | AddConsumer (vtkSMProperty *property, vtkSMProxy *proxy) |
Called by a proxy property, this adds the property,proxy pair to the list of consumers. More... | |
virtual void | RemoveConsumer (vtkSMProperty *property, vtkSMProxy *proxy) |
Remove the property,proxy pair from the list of consumers. More... | |
virtual void | RemoveAllConsumers () |
Remove all consumers. More... | |
void | AddProducer (vtkSMProperty *property, vtkSMProxy *proxy) |
Called by an proxy/input property to add property, proxy pair to the list of producers. More... | |
void | RemoveProducer (vtkSMProperty *property, vtkSMProxy *proxy) |
Remove the property,proxy pair from the list of producers. More... | |
virtual void | PostUpdateData (bool using_cache) |
This method is called after the algorithm(s) (if any) associated with this proxy execute. More... | |
void | PostUpdateDataSelfOnly (bool using_cache) |
This is called by PostUpdateData to only update state for this proxy without iterative over producers. More... | |
bool | WarnIfDeprecated () |
If a proxy is deprecated, prints a warning. More... | |
bool | LoadPluginIfEnsured () |
If a proxy need to ensure a plugin is loaded, make sure it is. More... | |
virtual void | UpdatePipelineInformation () |
This method simply iterates over subproxies and calls UpdatePipelineInformation() on them. More... | |
void | LinkProperty (vtkSMProperty *inputProperty, vtkSMProperty *outputProperty) |
Links properties such that when inputProperty's checked or unchecked values are changed, the outputProperty's corresponding values are also changed. More... | |
vtkSMPropertyGroup * | NewPropertyGroup (vtkPVXMLElement *propElement) |
Parses the XML to create a new property group. More... | |
void | AppendPropertyGroup (vtkSMPropertyGroup *group) |
Adds a property groups. More... | |
void | ExposeSubProxyProperty (const char *subproxy_name, const char *property_name, const char *exposed_name, int overrideOK=0) |
Expose a subproxy property from the base proxy. More... | |
virtual void | ExecuteSubProxyEvent (vtkSMProxy *o, unsigned long event, void *data) |
Handle events fired by subproxies. More... | |
virtual int | CreateSubProxiesAndProperties (vtkSMSessionProxyManager *pm, vtkPVXMLElement *element) |
virtual void | UpdatePropertyInformationInternal (vtkSMProperty *prop=nullptr) |
Called to update the property information on the property. More... | |
void | RebuildStateForProperties () |
vtkSMProxy tracks state of properties on this proxy in an internal State object. More... | |
virtual void | SetLogNameInternal (const char *name, bool propagate_to_subproxies, bool propagate_to_proxylistdomains) |
Internal method used by SetLogName More... | |
bool | ArePropertiesModified () |
Indicates if any properties are modified. More... | |
void | SetHints (vtkPVXMLElement *hints) |
void | SetDeprecated (vtkPVXMLElement *deprecated) |
void | SetEnsurePluginLoaded (vtkPVXMLElement *ensurePluginLoaded) |
Set the "EnsurePluginLoaded" XML element that is used in LoadPluginIfEnsured. More... | |
void | SetXMLElement (vtkPVXMLElement *element) |
vtkSMProxy (const vtkSMProxy &)=delete | |
void | operator= (const vtkSMProxy &)=delete |
virtual const vtkClientServerStream & | GetLastResult () |
Get the last result. More... | |
virtual const vtkClientServerStream & | GetLastResult (vtkTypeUInt32 location) |
virtual void | SetXMLGroup (const char *) |
virtual void | SetXMLLabel (const char *) |
virtual void | SetXMLSubProxyName (const char *) |
vtkSMProperty * | NewProperty (const char *name) |
Creates a new property and initializes it by calling ReadXMLAttributes() with the right XML element. More... | |
vtkSMProperty * | NewProperty (const char *name, vtkPVXMLElement *propElement) |
virtual int | ReadXMLAttributes (vtkSMSessionProxyManager *pm, vtkPVXMLElement *element) |
Read attributes from an XML element. More... | |
void | SetupExposedProperties (const char *subproxy_name, vtkPVXMLElement *element) |
void | SetupSharedProperties (vtkSMProxy *subproxy, vtkPVXMLElement *element) |
virtual void | SetSIClassName (const char *) |
SIClassName identifies the classname for the helper on the server side. More... | |
virtual char * | GetSIClassName () |
vtkSMRemoteObject () | |
Default constructor. More... | |
~vtkSMRemoteObject () override | |
Destructor. More... | |
void | PushState (vtkSMMessage *msg) |
Subclasses can call this method to send a message to its state object on the server processes specified. More... | |
bool | PullState (vtkSMMessage *msg) |
Subclasses can call this method to pull the state from the state-object on the server processes specified. More... | |
void | SetGlobalID (vtkTypeUInt32 guid) |
Set the GlobalUniqueId. More... | |
vtkTypeUInt32 | GetFilteredLocation () |
vtkSMSessionObject () | |
vtkSMObject () | |
~vtkSMObject () override | |
vtkObject () | |
virtual | ~vtkObject () |
vtkObjectBase () | |
virtual | ~vtkObjectBase () |
Friends | |
class | vtkSMSaveAnimationProxyNS::Friendship |
vtkSMSaveAnimationProxy is a proxy that helps with saving animation to images or video. The properties on this proxy provide various options that user can configure when saving animations. Once those properties are setup, one calls vtkSMSaveAnimationProxy::WriteAnimation` to save out the animation.
Definition at line 26 of file vtkSMSaveAnimationProxy.h.
Definition at line 30 of file vtkSMSaveAnimationProxy.h.
Reimplemented from vtkSMSaveScreenshotProxy.
The properties on this proxy provide all the necessary information to save the animation.
protectedvirtual |
overrideprotectedvirtual |
protectedvirtual |
friend |
Definition at line 79 of file vtkSMSaveAnimationProxy.h.
