Class used to broadcast message from one client to the others. More...
#include <vtkSMCollaborationManager.h>
enum | EventType { CollaborationNotification = 12345, UpdateUserName = 12346, UpdateUserList = 12347, UpdateMasterUser = 12348, FollowUserCamera = 12349, CameraChanged = 12350, LastMessageUpdated = 12351 } |
typedef vtkSMRemoteObject | Superclass |
vtkTypeUInt32 | GetGlobalID () override |
Get the global unique id for this object. More... | |
Override the session setting in order to update only once our current local user id. More... | |
virtual void | PromoteToMaster (int clientId) |
This method is used promote a new Master user. More... | |
virtual void | FollowUser (int clientId) |
Share the decision that user should follow that given user if master or follow someone else on your own. More... | |
int | GetFollowedUser () |
Return the local followed user. More... | |
virtual bool | IsMaster () |
Return true if the current client is the master. More... | |
virtual int | GetMasterId () |
Return the userId of the current master. More... | |
bool | GetDisableFurtherConnections () |
Return true if further connections are disabled. More... | |
virtual int | GetUserId () |
Return the id of the current client. More... | |
virtual int | GetUserId (int index) |
Return the id of the nth connected client. More... | |
virtual const char * | GetUserLabel (int userID) |
return the name of the provided userId More... | |
virtual void | SetUserLabel (const char *userName) |
Update ou local user name. More... | |
virtual void | SetUserLabel (int userId, const char *userName) |
Update any user name. More... | |
virtual int | GetNumberOfConnectedClients () |
return the number of currently connected clients. More... | |
void | UpdateUserInformations () |
Request an update of the user list from the server. More... | |
int | GetServerConnectID () |
Return the server connect id if this is the master. More... | |
int | GetConnectID () |
Return the client connect id. More... | |
void | SendToOtherClients (vtkSMMessage *msg) |
Send message to other clients which will trigger Observer. More... | |
This method return the state of the connected clients. More... | |
This method is used to either load its internal connected clients information or to forward messages across clients. More... | |
void | DisableFurtherConnections (bool disable) |
Enable or disable further connections to the server. More... | |
void | SetConnectID (int connectID) |
Change the connect-id. More... | |
const char * | GetLastReceivedMessage () const |
Allow to get the last received message from the chat. More... | |
Override the SetSession so if the object already have an ID we automatically register it to the associated session. More... | |
bool | HasGlobalID () |
Allow the user to test if the RemoteObject has already a GlobalID without assigning a new one to it. More... | |
virtual void | EnableLocalPushOnly () |
Allow to switch off any push of state change to the server for that particular object. More... | |
virtual void | DisableLocalPushOnly () |
Enable the given remote object to communicate its state normally to the server location. More... | |
Let the session be aware that even if the Location is client only, the message should not be send to the server for a general broadcast. More... | |
virtual void | SetLocation (vtkTypeUInt32) |
Get/Set the location where the underlying VTK-objects are created. More... | |
virtual void | PrototypeOn () |
Allow user to set the remote object to be discard for Undo/Redo action. More... | |
virtual void | PrototypeOff () |
bool | IsPrototype () |
virtual void | SetPrototype (bool) |
virtual void | Modified () |
static vtkTypeUInt32 | GetReservedGlobalID () |
Return the GlobalID that should be used to refer to the TimeKeeper. More... | |
static vtkSMCollaborationManager * | New () |
static vtkSMCollaborationManager * | SafeDownCast (vtkObject *o) |
static vtkSMRemoteObject * | SafeDownCast (vtkObject *o) |
static vtkObject * | New () |
vtkSMCollaborationManager () | |
Default constructor. More... | |
~vtkSMCollaborationManager () override | |
Destructor. More... | |
vtkSMRemoteObject () | |
~vtkSMRemoteObject () override | |
void | PushState (vtkSMMessage *msg) |
Subclasses can call this method to send a message to its state object on the server processes specified. More... | |
bool | PullState (vtkSMMessage *msg) |
Subclasses can call this method to pull the state from the state-object on the server processes specified. More... | |
void | SetGlobalID (vtkTypeUInt32 guid) |
Set the GlobalUniqueId. More... | |
vtkTypeUInt32 | GetFilteredLocation () |
vtkSMSessionObject () | |
vtkSMObject () | |
~vtkSMObject () override | |
vtkObject () | |
virtual | ~vtkObject () |
vtkObjectBase () | |
virtual | ~vtkObjectBase () |
Protected Attributes inherited from vtkSMRemoteObject | |
vtkTypeUInt32 | GlobalID |
vtkTypeUInt32 | Location |
bool | Prototype |
bool | ClientOnlyLocationFlag |
vtkWeakPointer< vtkSMSession > | Session |
Identifies the session id to which this object is related. More... | |
bool | Debug |
vtkTimeStamp | MTime |
This class allow to trigger protobuf messages on all the clients that are connected to the server. Those clients can attach listeners and handle those message in the way they want. The message sender do not receive its message again, only other clients do.
To listen collaboration notification messages you should have a code that look like that:
collaborationManager->AddObserver( vtkSMCollaborationManager::CollaborationNotification, callback);
void callback(vtkObject* src, unsigned long event, void* method, void* data) { vtkSMMessage* msg = reinterpret_cast<vtkSMMessage*>(data); => do what you want with the message }
Definition at line 36 of file vtkSMCollaborationManager.h.
Definition at line 45 of file vtkSMCollaborationManager.h.
Enumerator | |
CollaborationNotification | |
UpdateUserName | |
UpdateUserList | |
UpdateMasterUser | |
FollowUserCamera | |
CameraChanged | |
LastMessageUpdated |
Definition at line 143 of file vtkSMCollaborationManager.h.
Destructor.
Reimplemented from vtkSMRemoteObject.
If none is set and the session is valid, a new global id will be assigned automatically.
Reimplemented from vtkSMSessionObject.
Master/Slave user doesn't buy you anything here. It just provide you the information, and it is your call to prevent slaves users to do or achieve some actions inside your client. When you call that method a SMMessage is also propagated to the other client so they could follow who is the Master without fetching the information again.
int vtkSMCollaborationManager::GetFollowedUser | ( | ) |
bool vtkSMCollaborationManager::GetDisableFurtherConnections | ( | ) |
In the list you will find yourself as well.
This size is used to bound the GetUserId() method.
void vtkSMCollaborationManager::UpdateUserInformations | ( | ) |
(A pull request is done)
int vtkSMCollaborationManager::GetServerConnectID | ( | ) |
Else return -1.
int vtkSMCollaborationManager::GetConnectID | ( | ) |
void vtkSMCollaborationManager::SendToOtherClients | ( | vtkSMMessage * | msg | ) |
void vtkSMCollaborationManager::DisableFurtherConnections | ( | bool | disable | ) |
Already connected clients stay connected.
void vtkSMCollaborationManager::SetConnectID | ( | int | connectID | ) |
connectID | the new connect-id for the server. |
const char* vtkSMCollaborationManager::GetLastReceivedMessage | ( | ) | const |
Easy API to be wrapped and used in python scripting.
