int | IsInDomain (vtkSMProperty *property) override |
| Returns true if the value of the property is in the domain. More...
int | IsInDomain (vtkSMSourceProxy *proxy, int outputport=0) |
| Returns true if all parts of the source proxy are in the domain. More...
std::string | GetDomainDescription () const |
| An experimental API to provide a user-friendly text describing this domain. More...
int | ParseXMLAttributes (vtkPVXMLElement *element) |
| Parse XML attributes and store in the appropriate ivars Used by ReadXMLAttributes but can be used independently. More...
| Is the (unchecked) value of the property in the domain? Overwritten by sub-classes. More...
virtual void | Update (vtkSMProperty *requestingProperty) |
| Update self based on the "unchecked" values of all required properties. More...
| Set the value of an element of a property from the animation editor. More...
| A vtkSMProperty is often defined with a default value in the XML itself. More...
| Provides access to the vtkSMProperty on which this domain is hooked up. More...
| Helper method to get the number of input connections hence the number of available vtkPVDataInformation from input proxy connected to the required property with the given function. More...
| Returns a given required property of the given function. More...
| When the IsOptional flag is set, IsInDomain() always returns true. More...
| Helper methods to get vtkPVDataInformation from input proxy connected to the required property with the given function and provided input index. More...
virtual void | Modified () |
| vtkSMDataTypeDomain () |
| ~vtkSMDataTypeDomain () override |
int | ReadXMLAttributes (vtkSMProperty *prop, vtkPVXMLElement *element) override |
| Set the appropriate ivars from the xml element. More...
| vtkSMDomain () |
| ~vtkSMDomain () override |
| Load the state of the domain from the XML. More...
| Remove the given property from the required properties list. More...
| Add a new required property to this domain. More...
void | DomainModified () |
| Invokes DomainModifiedEvent. More...
void | InvokeModified () |
| Gets the number of required properties added. More...
| Set the domain's property. More...
| Add the header and creates a new vtkPVXMLElement for the domain, fills it up with the common attributes. More...
virtual void | ChildSaveState (vtkPVXMLElement *domainElement) |
| vtkSMSessionObject () |
| ~vtkSMSessionObject () override |
| vtkSMObject () |
| ~vtkSMObject () override |
| vtkObject () |
virtual | ~vtkObject () |
| vtkObjectBase () |
virtual | ~vtkObjectBase () |
| vtkObjectBase (const vtkObjectBase &) |
restricts the input proxies to one or more data types
vtkSMDataTypeDomain restricts the input proxies to one or more data types. These data types are specified in the XML with the <DataType>
element. VTK class names are used. It is possible to specify a superclass (i.e. vtkDataSet) for a more general domain. Works with vtkSMSourceProxy only. Valid XML elements are:
* * <DataType value=""> where value is the classname for the data type
* for example: vtkDataSet, vtkImageData,...
Optional XML attributes for composite datasets only:
child_match
: Value can be "any" or "all". This is used if specific types of child datasets are required. "any" indicates that composite datasets with any child matching the nested data types are in the domain. "all" indicates that all the child datasets must match the nested data types(can be mix-match). Example: <DataType
value=
"vtkCompositeDataSet" child_match=
"any">
<DataType value="vtkImageData" />
</DataType>
<DataType value="vtkMultiBlockDataSet" child_match="all">
<DataType value="vtkUnstructuredGrid" />
</DataType>
The first element accepts vtkCompositeDataSet with at least one child dataset of vtkImageData. The second element accepts vtkMultiBlockDataSet with all the child datasets being either vtkImageData or vtkUnstructuredGrid.
- See also
- vtkSMDomain vtkSMSourceProxy
Definition at line 51 of file vtkSMDataTypeDomain.h.
