Utility class to load state from XML. More...
#include <vtkSMStateLoader.h>
typedef vtkSMDeserializerXML | Superclass |
typedef vtkSMDeserializer | Superclass |
int | LoadState (vtkPVXMLElement *rootElement, bool keepOriginalId=false) |
Load the state from the given root element. More... | |
void | SetProxyLocator (vtkSMProxyLocator *loc) |
Get/Set the proxy locator to use. More... | |
virtual vtkSMProxyLocator * | GetProxyLocator () |
virtual void | SetKeepIdMapping (int) |
Allow the loader to keep the mapping between the id from the loaded state to the current proxy attributed id. More... | |
virtual int | GetKeepIdMapping () |
virtual void | KeepIdMappingOn () |
virtual void | KeepIdMappingOff () |
void | SetSession (vtkSMSession *session) |
Convenience method for setting the SessionProxyManager. More... | |
vtkSMSession * | GetSession () |
Provides access to the session. More... | |
vtkSMSessionProxyManager * | GetSessionProxyManager () |
Get/Set the proxy manager on which this deserializer is expected to operate. More... | |
void | SetSessionProxyManager (vtkSMSessionProxyManager *) |
virtual void | Modified () |
static vtkSMStateLoader * | New () |
static vtkSMStateLoader * | SafeDownCast (vtkObject *o) |
static vtkSMDeserializerXML * | New () |
static vtkSMDeserializerXML * | SafeDownCast (vtkObject *o) |
static vtkSMDeserializer * | SafeDownCast (vtkObject *o) |
static vtkObject * | New () |
virtual int | LoadStateInternal (vtkPVXMLElement *rootElement) |
The rootElement must be the <ServerManagerState/> xml element. More... | |
void | CreatedNewProxy (vtkTypeUInt32 id, vtkSMProxy *proxy) override |
Called after a new proxy is created. More... | |
vtkSMProxy * | CreateProxy (const char *xmlgroup, const char *xmlname, const char *subProxyName=nullptr) override |
Overridden so that when new views are to be created, we create views suitable for the connection. More... | |
virtual int | HandleProxyCollection (vtkPVXMLElement *collectionElement) |
virtual void | HandleCustomProxyDefinitions (vtkPVXMLElement *element) |
int | HandleLinks (vtkPVXMLElement *linksElement) |
virtual int | BuildProxyCollectionInformation (vtkPVXMLElement *) |
virtual bool | UpdateRegistrationInfo (std::string &group, std::string &name, vtkSMProxy *proxy) |
Update a proxy's registration group and name before it gets registered. More... | |
vtkPVXMLElement * | LocateProxyElement (vtkTypeUInt32 id) override |
Return the xml element for the state of the proxy with the given id. More... | |
vtkPVXMLElement * | LocateProxyElementInternal (vtkPVXMLElement *root, vtkTypeUInt32 id) |
Used by LocateProxyElement(). More... | |
virtual bool | VerifyXMLVersion (vtkPVXMLElement *rootElement) |
Checks the root element for version. More... | |
vtkSMProxy * | LocateExistingProxyUsingRegistrationName (vtkTypeUInt32 id) |
Returns the first proxy already registered using any of the registration (group, name) assigned to the proxy with the given id in the state file. More... | |
virtual void | RegisterProxy (vtkTypeUInt32 id, vtkSMProxy *proxy) |
This method scans through the internal data structure built during BuildProxyCollectionInformation() and registers the proxy. More... | |
virtual void | RegisterProxyInternal (const char *group, const char *name, vtkSMProxy *proxy) |
vtkSMDeserializerXML () | |
~vtkSMDeserializerXML () override | |
vtkSMProxy * | NewProxy (vtkTypeUInt32 id, vtkSMProxyLocator *locator) override |
Create a new proxy with the id if possible. More... | |
virtual int | LoadProxyState (vtkPVXMLElement *element, vtkSMProxy *, vtkSMProxyLocator *locator) |
TEMPORARY. More... | |
vtkSMDeserializer () | |
~vtkSMDeserializer () override | |
vtkObject () | |
virtual | ~vtkObject () |
vtkObjectBase () | |
virtual | ~vtkObjectBase () |
Protected Attributes | |
vtkPVXMLElement * | ServerManagerStateElement |
vtkSMProxyLocator * | ProxyLocator |
int | KeepIdMapping |
vtkWeakPointer< vtkSMSessionProxyManager > | SessionProxyManager |
bool | Debug |
vtkTimeStamp | MTime |
vtkTypeUInt32 * | GetMappingArray (int &size) |
Return an array of ids. More... | |
vtkSMStateLoader () | |
~vtkSMStateLoader () override | |
vtkSMStateLoader can load server manager state from a given vtkPVXMLElement. This element is usually populated by a vtkPVXMLParser.
Definition at line 28 of file vtkSMStateLoader.h.
Definition at line 32 of file vtkSMStateLoader.h.
The ids are stored in the following order and the size of the array is provided as argument. [key, value, key, value, ...] The array is kept internally using a std::vector
Reimplemented from vtkSMDeserializerXML.
Reimplemented in vtkSMInsituStateLoader.
int vtkSMStateLoader::LoadState | ( | vtkPVXMLElement * | rootElement, |
bool | keepOriginalId = false |
void vtkSMStateLoader::SetProxyLocator | ( | vtkSMProxyLocator * | loc | ) |
Default is vtkSMProxyLocator will be used.
vtkTypeUInt32* vtkSMStateLoader::GetMappingArray | ( | int & | size | ) |
protectedvirtual |
xml element.
If rootElement is not a <ServerManagerState/>
element, then we try to locate the first <ServerManagerState/>
nested element and load that. Load the state from the given root element.
overrideprotectedvirtual |
The main responsibility of this method is to ensure that proxy gets a GlobalId (either automatically or using the id from the state if LoadState() was called with keepOriginalId
set to true). It also called vtkSMProxy::UpdateVTKObjects() and vtkSMProxy::UpdatePipelineInformation() (if applicable) to ensure that the state loaded on the proxy is "pushed" and any info properties updated. We also create a list to track the order in which proxies are created. This order is a dependency order too and hence helps us register proxies in order of dependencies.
protectedvirtual |
protectedvirtual |
protectedvirtual |
protectedvirtual |
The DS keeps info about each proxy ID and the groups and names the proxy should be registered as (as indicated in the state file).
protectedvirtual |
protectedvirtual |
Default implementation handles helper group group names. Returns false to skip registering the proxy.
[in,out] | group | proxy registration group |
[in,out] | name | proxy registration name |
[in] | proxy | proxy being registered |
This is used by NewProxy() when the proxy with the given id is not located in the internal CreatedProxies map.
Recursively tries to locate the proxy state element for the proxy.
protectedvirtual |
If failed, return false.
Definition at line 153 of file vtkSMStateLoader.h.
Definition at line 154 of file vtkSMStateLoader.h.
Definition at line 155 of file vtkSMStateLoader.h.
