deserializes proxies from their XML states. More...
#include <vtkSMDeserializerXML.h>
typedef vtkSMDeserializer | Superclass |
void | SetSession (vtkSMSession *session) |
Convenience method for setting the SessionProxyManager. More... | |
vtkSMSession * | GetSession () |
Provides access to the session. More... | |
vtkSMSessionProxyManager * | GetSessionProxyManager () |
Get/Set the proxy manager on which this deserializer is expected to operate. More... | |
void | SetSessionProxyManager (vtkSMSessionProxyManager *) |
virtual void | Modified () |
static vtkSMDeserializerXML * | New () |
static vtkSMDeserializerXML * | SafeDownCast (vtkObject *o) |
static vtkSMDeserializer * | SafeDownCast (vtkObject *o) |
static vtkObject * | New () |
vtkSMDeserializerXML () | |
~vtkSMDeserializerXML () override | |
vtkSMProxy * | NewProxy (vtkTypeUInt32 id, vtkSMProxyLocator *locator) override |
Create a new proxy with the id if possible. More... | |
virtual vtkPVXMLElement * | LocateProxyElement (vtkTypeUInt32 id) |
Locate the XML for the proxy with the given id. More... | |
virtual int | LoadProxyState (vtkPVXMLElement *element, vtkSMProxy *, vtkSMProxyLocator *locator) |
TEMPORARY. More... | |
vtkSMProxy * | CreateProxy (const char *xmlgroup, const char *xmlname, const char *subProxyName=nullptr) override |
Create a new proxy of the given group and name. More... | |
virtual void | CreatedNewProxy (vtkTypeUInt32 id, vtkSMProxy *proxy) |
Called after a new proxy has been created. More... | |
vtkSMDeserializer () | |
~vtkSMDeserializer () override | |
vtkObject () | |
virtual | ~vtkObject () |
vtkObjectBase () | |
virtual | ~vtkObjectBase () |
Friends | |
class | vtkSMProxyLocator |
vtkWeakPointer< vtkSMSessionProxyManager > | SessionProxyManager |
bool | Debug |
vtkTimeStamp | MTime |
vtkSMDeserializer is used to deserialize proxies from their XML states. This is the base class of deserialization classes that load XMLs to restore servermanager state (or part thereof).
Definition at line 22 of file vtkSMDeserializerXML.h.
Definition at line 26 of file vtkSMDeserializerXML.h.
Reimplemented from vtkSMDeserializer.
Reimplemented in vtkSMStateLoader, vtkSMCompoundProxyDefinitionLoader, vtkSMDeserializerXMLCache, and vtkSMInsituStateLoader.
Reimplemented in vtkSMStateLoader, and vtkSMDeserializerXMLCache.
overrideprotectedvirtual |
if possible.
Implements vtkSMDeserializer.
protectedvirtual |
Reimplemented in vtkSMStateLoader, vtkSMDeserializerXMLCache, and vtkSMCompoundProxyDefinitionLoader.
protectedvirtual |
TEMPORARY.
Used to load the state on the proxy. This is only for the sake of the lookmark state loader until we get the chance to clean it up. DON'T override this method.
Default implementation simply asks the proxy manager to create a new proxy of the requested type.
Reimplemented in vtkSMStateLoader.
protectedvirtual |
Gives the subclasses an opportunity to perform certain tasks such as registering proxies etc. Default implementation is empty.
friend |
Definition at line 34 of file vtkSMDeserializerXML.h.
