vtkSMViewProxy.h
20 #ifndef vtkSMViewProxy_h
21 #define vtkSMViewProxy_h
22
23 #include "vtkCommand.h" // needed for vtkCommand.
24 #include "vtkRemotingViewsModule.h" //needed for exports
25 #include "vtkSMProxy.h"
26
27 class vtkImageData;
28 class vtkRenderer;
29 class vtkRenderWindow;
33 class vtkSMSourceProxy;
34 class vtkView;
35
37 {
38 class WindowToImageFilter;
39 class CaptureHelper;
40 }
41
43 {
44 public:
45  static vtkSMViewProxy* New();
46  vtkTypeMacro(vtkSMViewProxy, vtkSMProxy);
47  void PrintSelf(ostream& os, vtkIndent indent) override;
48
50
53  vtkSetMacro(Enable, bool);
54  vtkGetMacro(Enable, bool);
55  vtkBooleanMacro(Enable, bool);
57
61  virtual void StillRender();
62
66  virtual void InteractiveRender();
67
71  virtual void Update();
72
78  virtual bool CanDisplayData(vtkSMSourceProxy* producer, int outputPort);
79
88  virtual vtkSMRepresentationProxy* CreateDefaultRepresentation(vtkSMProxy*, int);
89
99  virtual const char* GetRepresentationType(vtkSMSourceProxy* producer, int outputPort);
100
105  virtual vtkSMRepresentationProxy* FindRepresentation(vtkSMSourceProxy* producer, int outputPort);
106
108
113  vtkImageData* CaptureWindow(int magnification)
114  {
115  return this->CaptureWindow(magnification, magnification);
116  }
117  vtkImageData* CaptureWindow(int magnificationX, int magnificationY);
119
122  vtkView* GetClientSideView();
123
128  int WriteImage(const char* filename, const char* writerName, int magnification = 1);
129  int WriteImage(
130  const char* filename, const char* writerName, int magnificationX, int magnificationY);
131
137  virtual bool HasDirtyRepresentation() { return this->GetNeedsUpdate(); }
138
140
145  vtkGetMacro(NeedsUpdate, bool);
147
156  virtual vtkRenderWindow* GetRenderWindow() { return nullptr; }
157
163  virtual vtkRenderWindowInteractor* GetInteractor() { return nullptr; }
164
174  virtual void SetupInteractor(vtkRenderWindowInteractor* iren) { (void)iren; }
175
183  virtual bool MakeRenderWindowInteractor(bool quiet = false);
184
186
189  static void SetTransparentBackground(bool val);
190  static bool GetTransparentBackground();
192
194
203  virtual bool HideOtherRepresentationsIfNeeded(vtkSMProxy* repr);
205  {
206  return self ? self->HideOtherRepresentationsIfNeeded(repr) : false;
207  }
209
211
224  virtual void RepresentationVisibilityChanged(vtkSMProxy* repr, bool new_visibility);
226  vtkSMViewProxy* self, vtkSMProxy* repr, bool new_visibility)
227  {
228  if (self)
229  {
230  self->RepresentationVisibilityChanged(repr, new_visibility);
231  }
232  }
234
238  static vtkSMViewProxy* FindView(vtkSMProxy* repr, const char* reggroup = "views");
239
240  enum
241  {
246  PrepareContextForRendering = vtkCommand::UserEvent + 1,
247  };
248
249 protected:
250  vtkSMViewProxy();
251  ~vtkSMViewProxy() override;
252
263  virtual vtkImageData* CaptureWindowInternal(int magnificationX, int magnificationY);
264
269  virtual void RenderForImageCapture() { this->StillRender(); }
270
281  virtual vtkTypeUInt32 PreRender(bool vtkNotUsed(interactive)) { return this->GetLocation(); }
282
283  virtual void PostRender(bool vtkNotUsed(interactive)) {}
284
294  virtual bool IsContextReadyForRendering();
295
299  void CreateVTKObjects() override;
300
304  int ReadXMLAttributes(vtkSMSessionProxyManager* pm, vtkPVXMLElement* element) override;
305
310  bool GetLocalProcessSupportsInteraction();
311
315  vtkGetObjectMacro(DeliveryManager, vtkSMDataDeliveryManagerProxy);
316
317  vtkSetStringMacro(DefaultRepresentationName);
319
320  bool Enable;
321
322 private:
323  vtkSMViewProxy(const vtkSMViewProxy&) = delete;
324  void operator=(const vtkSMViewProxy&) = delete;
325
326  bool InRender;
327
328  vtkSMDataDeliveryManagerProxy* DeliveryManager;
329  static bool TransparentBackground;
330
331  // Actual logic for taking a screenshot.
332  vtkImageData* CaptureWindowSingle(int magnificationX, int magnificationY);
333
334  friend class vtkSMViewProxyNS::WindowToImageFilter;
335  friend class vtkSMViewProxyNS::CaptureHelper;
336 };
337
338 #endif
Proxy for a representations.
vtkImageData * CaptureWindow(int magnification)
Captures a image from this view.
Superclass for all view proxies.
char * DefaultRepresentationName
virtual vtkRenderWindow * GetRenderWindow()
Return the vtkRenderWindow used by this view, if any.
virtual vtkRenderWindowInteractor * GetInteractor()
Returns the interactor.
This method is called before executing code that could cause a render on the underlying vtkPVView...
This method is called whenever the view wants to render to during image capture.
proxy for a VTK source on a server
The vtkSMSessionProxyManager is esponsible for creating and managing proxies for a given session...
static bool HideOtherRepresentationsIfNeeded(vtkSMViewProxy *self, vtkSMProxy *repr)
Method used to hide other representations if the view has a <ShowOneRepresentationAtATime/> hint...
Return true any internal representation is dirty.
Definition: vtkSMProxy.h:140
server-manager class for vtkPVDataDeliveryManager.
virtual void SetupInteractor(vtkRenderWindowInteractor *iren)
A client process need to set the interactor to enable interactivity.
static void RepresentationVisibilityChanged(vtkSMViewProxy *self, vtkSMProxy *repr, bool new_visibility)
Certain views maintain properties (or other state) that should be updated when visibility of represen...
