vtkSIProxyProperty.h
13 #ifndef vtkSIProxyProperty_h
14 #define vtkSIProxyProperty_h
15
16 #include "vtkRemotingServerManagerModule.h" //needed for exports
17 #include "vtkSIProperty.h"
18
20 {
21 public:
22  static vtkSIProxyProperty* New();
24  void PrintSelf(ostream& os, vtkIndent indent) override;
25
27
32  vtkGetStringMacro(CleanCommand);
36
42  vtkGetStringMacro(RemoveCommand);
45  // When set to true, the property will push a nullptr i.e. 0 when there are no
46  // proxies in the property. Not used when CleanCommand or RemoveCommand is
47  // set. Default is false.
48  vtkGetMacro(NullOnEmpty, bool);
49
50 protected:
52  ~vtkSIProxyProperty() override;
53
57  bool Push(vtkSMMessage*, int) override;
58
62  bool ReadXMLAttributes(vtkSIProxy* proxyhelper, vtkPVXMLElement* element) override;
63
65
70  vtkSetStringMacro(CleanCommand);
71  char* CleanCommand;
73
75
81  vtkSetStringMacro(RemoveCommand);
82  char* RemoveCommand;
84
85  // When set to true, the property will push a nullptr i.e. 0 when there are no
86  // proxies in the property. Not used when CleanCommand or RemoveCommand is
87  // set. Default is false.
88  vtkSetMacro(NullOnEmpty, bool);
89  bool NullOnEmpty;
90
91  enum TypeArg
92  {
93  VTK,
95  SIProxy
96  };
97
98  // Proxy type: VTK (default), SMProxy, Kernel,
99  // In the XML we expect argument_type="VTK" (default value if not set)
100  // argument_type="SMProxy"
101  // argument_type="SIProxy"
103
104  // Base on the ArgumentType will return either the VTK object or the SMProxy object
105  vtkObjectBase* GetObjectBase(vtkTypeUInt32 globalId);
106
107  // Allow to detect if a nullptr argument is really meant to be nullptr
108  bool IsValidNull(vtkTypeUInt32 globalId);
109
110 private:
111  vtkSIProxyProperty(const vtkSIProxyProperty&) = delete;
112  void operator=(const vtkSIProxyProperty&) = delete;
113  class InternalCache;
114  InternalCache* Cache;
115
116  class vtkObjectCache;
117  vtkObjectCache* ObjectCache;
118
119  bool SkipValidCheck;
120 };
121
122 #endif
static vtkSIProperty * New()
ServerSide Property use to set Object array as method argument.
virtual bool Push(vtkSMMessage *, int)
vtkSIProxy is the server-implementation for a vtkSMProxy that helps the vtkSMProxy with managing/upda...
Definition: vtkSIProxy.h:22
char * RemoveCommand
Remove command is the command called to remove the VTK object on the server-side. ...
virtual bool ReadXMLAttributes(vtkSIProxy *proxyhelper, vtkPVXMLElement *element)
Parse the xml for the property.
Basic ServerImplementation property used to call a method with no argument on a VTK object...
Definition: vtkSIProperty.h:24
char * CleanCommand
Command that can be used to remove inputs.
