ServerSide Property use to set Object array as method argument. More...
#include <vtkSIProxyProperty.h>
typedef vtkSIProperty | Superclass |
virtual bool | GetNullOnEmpty () |
virtual char * | GetCleanCommand () |
Command that can be used to remove inputs. More... | |
virtual char * | GetRemoveCommand () |
Remove command is the command called to remove the VTK object on the server-side. More... | |
The name assigned by the xml parser. More... | |
virtual char * | GetCommand () |
The command name used to set the value on the server object. More... | |
virtual bool | GetInformationOnly () |
Is InformationOnly is set to true, this property is used to get information from server instead of setting values. More... | |
virtual bool | GetRepeatable () |
If repeatable, a property can have 1 or more values of the same kind. More... | |
virtual void | SetIsInternal (bool) |
This ivar is configured when the xml file is read and is mainly useful to trigger a method call. More... | |
virtual bool | GetIsInternal () |
virtual void | Modified () |
static vtkSIProxyProperty * | New () |
static vtkSIProxyProperty * | SafeDownCast (vtkObject *o) |
static vtkSIProperty * | New () |
static vtkSIProperty * | SafeDownCast (vtkObject *o) |
static vtkObject * | New () |
Protected Types | |
enum | TypeArg { VTK, SMProxy, SIProxy } |
vtkSIProxyProperty () | |
~vtkSIProxyProperty () override | |
bool | Push (vtkSMMessage *, int) override |
Push a new state to the underneath implementation. More... | |
bool | ReadXMLAttributes (vtkSIProxy *proxyhelper, vtkPVXMLElement *element) override |
Parse the xml for the property. More... | |
virtual void | SetNullOnEmpty (bool) |
vtkObjectBase * | GetObjectBase (vtkTypeUInt32 globalId) |
bool | IsValidNull (vtkTypeUInt32 globalId) |
vtkSIProperty () | |
~vtkSIProperty () override | |
vtkSIObject * | GetSIObject (vtkTypeUInt32 globalid) |
Convenience method to obtain a vtkSIObject subclass given its global id. More... | |
virtual bool | Pull (vtkSMMessage *) |
Pull the current state of the underneath implementation. More... | |
virtual void | SetCommand (const char *) |
void | SaveValueToCache (vtkSMMessage *proxyStateUpdate, int offset) |
bool | ProcessMessage (vtkClientServerStream &stream) |
Interprets the message. More... | |
const vtkClientServerStream & | GetLastResult () |
vtkObjectBase * | GetVTKObject () |
vtkObject () | |
virtual | ~vtkObject () |
vtkObjectBase () | |
virtual | ~vtkObjectBase () |
Protected Attributes | |
bool | NullOnEmpty |
TypeArg | ArgumentType |
char * | XMLName |
char * | Command |
bool | InformationOnly |
bool | Repeatable |
bool | IsInternal |
vtkWeakPointer< vtkSIProxy > | SIProxyObject |
bool | Debug |
vtkTimeStamp | MTime |
char * | CleanCommand |
virtual void | SetCleanCommand (const char *) |
char * | RemoveCommand |
virtual void | SetRemoveCommand (const char *) |
Those object could be either SMProxy instance or their SIProxy instance or the VTK object managed by the SIProxy instance. The type of object is specified inside the XML definition of the property with the attribute argument_type=[VTK, SMProxy, SIProxy].
Definition at line 19 of file vtkSIProxyProperty.h.
Definition at line 23 of file vtkSIProxyProperty.h.
Enumerator | |
VTK | |
SMProxy | |
SIProxy |
Definition at line 91 of file vtkSIProxyProperty.h.
Reimplemented in vtkSIXMLAnimationWriterRepresentationProperty, and vtkSIInputProperty.
If set, this command is called before the main Command is called with all the arguments.
If set, CleanCommand is ignored. Instead for every proxy that was absent from the proxies previously pushed, the RemoveCommand is invoked.
overrideprotectedvirtual |
protectedvirtual |
protectedvirtual |
protectedvirtual |
Definition at line 70 of file vtkSIProxyProperty.h.
Definition at line 81 of file vtkSIProxyProperty.h.
Definition at line 88 of file vtkSIProxyProperty.h.
Definition at line 102 of file vtkSIProxyProperty.h.
