ServerSide Property use to set vtkOutputPort as method parameter. More...
#include <vtkSIInputProperty.h>
typedef vtkSIProxyProperty | Superclass |
typedef vtkSIProperty | Superclass |
virtual int | GetPortIndex () |
Controls which input port this property uses when making connections. More... | |
virtual bool | GetNullOnEmpty () |
virtual char * | GetCleanCommand () |
Command that can be used to remove inputs. More... | |
virtual char * | GetRemoveCommand () |
Remove command is the command called to remove the VTK object on the server-side. More... | |
The name assigned by the xml parser. More... | |
virtual char * | GetCommand () |
The command name used to set the value on the server object. More... | |
virtual bool | GetInformationOnly () |
Is InformationOnly is set to true, this property is used to get information from server instead of setting values. More... | |
virtual bool | GetRepeatable () |
If repeatable, a property can have 1 or more values of the same kind. More... | |
virtual void | SetIsInternal (bool) |
This ivar is configured when the xml file is read and is mainly useful to trigger a method call. More... | |
virtual bool | GetIsInternal () |
virtual void | Modified () |
static vtkSIInputProperty * | New () |
static vtkSIInputProperty * | SafeDownCast (vtkObject *o) |
static vtkSIProxyProperty * | New () |
static vtkSIProxyProperty * | SafeDownCast (vtkObject *o) |
static vtkSIProperty * | New () |
static vtkSIProperty * | SafeDownCast (vtkObject *o) |
static vtkObject * | New () |
vtkSIInputProperty () | |
~vtkSIInputProperty () override | |
bool | Push (vtkSMMessage *, int) override |
Push a new state to the underneath implementation. More... | |
bool | ReadXMLAttributes (vtkSIProxy *proxyhelper, vtkPVXMLElement *element) override |
Parse the xml for the property. More... | |
virtual void | SetPortIndex (int) |
vtkSIProxyProperty () | |
~vtkSIProxyProperty () override | |
virtual void | SetNullOnEmpty (bool) |
vtkObjectBase * | GetObjectBase (vtkTypeUInt32 globalId) |
bool | IsValidNull (vtkTypeUInt32 globalId) |
virtual void | SetCleanCommand (const char *) |
virtual void | SetRemoveCommand (const char *) |
vtkSIProperty () | |
~vtkSIProperty () override | |
vtkSIObject * | GetSIObject (vtkTypeUInt32 globalid) |
Convenience method to obtain a vtkSIObject subclass given its global id. More... | |
virtual bool | Pull (vtkSMMessage *) |
Pull the current state of the underneath implementation. More... | |
virtual void | SetCommand (const char *) |
void | SaveValueToCache (vtkSMMessage *proxyStateUpdate, int offset) |
bool | ProcessMessage (vtkClientServerStream &stream) |
Interprets the message. More... | |
const vtkClientServerStream & | GetLastResult () |
vtkObjectBase * | GetVTKObject () |
vtkObject () | |
virtual | ~vtkObject () |
vtkObjectBase () | |
virtual | ~vtkObjectBase () |
Protected Attributes | |
int | PortIndex |
bool | NullOnEmpty |
TypeArg | ArgumentType |
char * | CleanCommand |
char * | RemoveCommand |
char * | XMLName |
char * | Command |
bool | InformationOnly |
bool | Repeatable |
bool | IsInternal |
vtkWeakPointer< vtkSIProxy > | SIProxyObject |
bool | Debug |
vtkTimeStamp | MTime |
enum | TypeArg { VTK, SMProxy, SIProxy } |
For that we need the object on which we should get the Port and its port number.
Definition at line 17 of file vtkSIInputProperty.h.
Definition at line 21 of file vtkSIInputProperty.h.
Reimplemented from vtkSIProxyProperty.
Reimplemented in vtkSIXMLAnimationWriterRepresentationProperty.
By default, this is 0.
overrideprotectedvirtual |
protectedvirtual |
Definition at line 46 of file vtkSIInputProperty.h.
