11 #ifndef vtkSIInputProperty_h 12 #define vtkSIInputProperty_h 29 vtkGetMacro(PortIndex,
int);
46 vtkSetMacro(PortIndex,
int);
ServerSide Property use to set Object array as method argument.
bool ReadXMLAttributes(vtkSIProxy *proxyhelper, vtkPVXMLElement *element) override
Parse the xml for the property.
vtkSIProxy is the server-implementation for a vtkSMProxy that helps the vtkSMProxy with managing/upda...
bool Push(vtkSMMessage *, int) override
static vtkSIProxyProperty * New()
