vtkSIXMLAnimationWriterRepresentationProperty extends vtkSIInputProperty to add push-API specific to vtkXMLPVAnimationWriter to add representations while assigning them unique names consistently across all processes. More...
#include <vtkSIXMLAnimationWriterRepresentationProperty.h>
typedef vtkSIInputProperty | Superclass |
typedef vtkSIProxyProperty | Superclass |
typedef vtkSIProperty | Superclass |
virtual int | GetPortIndex () |
Controls which input port this property uses when making connections. More... | |
virtual bool | GetNullOnEmpty () |
virtual char * | GetCleanCommand () |
Command that can be used to remove inputs. More... | |
virtual char * | GetRemoveCommand () |
Remove command is the command called to remove the VTK object on the server-side. More... | |
The name assigned by the xml parser. More... | |
virtual char * | GetCommand () |
The command name used to set the value on the server object. More... | |
virtual bool | GetInformationOnly () |
Is InformationOnly is set to true, this property is used to get information from server instead of setting values. More... | |
virtual bool | GetRepeatable () |
If repeatable, a property can have 1 or more values of the same kind. More... | |
virtual void | SetIsInternal (bool) |
This ivar is configured when the xml file is read and is mainly useful to trigger a method call. More... | |
virtual bool | GetIsInternal () |
virtual void | Modified () |
vtkSIXMLAnimationWriterRepresentationProperty () | |
~vtkSIXMLAnimationWriterRepresentationProperty () override | |
bool | Push (vtkSMMessage *, int) override |
Overridden to call AddRepresentation on the vtkXMLPVAnimationWriter instance with correct API. More... | |
vtkSIInputProperty () | |
~vtkSIInputProperty () override | |
Push a new state to the underneath implementation. More... | |
bool | ReadXMLAttributes (vtkSIProxy *proxyhelper, vtkPVXMLElement *element) override |
Parse the xml for the property. More... | |
virtual void | SetPortIndex (int) |
vtkSIProxyProperty () | |
~vtkSIProxyProperty () override | |
virtual void | SetNullOnEmpty (bool) |
vtkObjectBase * | GetObjectBase (vtkTypeUInt32 globalId) |
bool | IsValidNull (vtkTypeUInt32 globalId) |
virtual void | SetCleanCommand (const char *) |
virtual void | SetRemoveCommand (const char *) |
vtkSIProperty () | |
~vtkSIProperty () override | |
vtkSIObject * | GetSIObject (vtkTypeUInt32 globalid) |
Convenience method to obtain a vtkSIObject subclass given its global id. More... | |
virtual bool | Pull (vtkSMMessage *) |
Pull the current state of the underneath implementation. More... | |
virtual void | SetCommand (const char *) |
void | SaveValueToCache (vtkSMMessage *proxyStateUpdate, int offset) |
bool | ProcessMessage (vtkClientServerStream &stream) |
Interprets the message. More... | |
const vtkClientServerStream & | GetLastResult () |
vtkObjectBase * | GetVTKObject () |
vtkObject () | |
virtual | ~vtkObject () |
vtkObjectBase () | |
virtual | ~vtkObjectBase () |
enum | TypeArg { VTK, SMProxy, SIProxy } |
int | PortIndex |
bool | NullOnEmpty |
TypeArg | ArgumentType |
char * | CleanCommand |
char * | RemoveCommand |
char * | XMLName |
char * | Command |
bool | InformationOnly |
bool | Repeatable |
bool | IsInternal |
vtkWeakPointer< vtkSIProxy > | SIProxyObject |
bool | Debug |
vtkTimeStamp | MTime |
Definition at line 17 of file vtkSIXMLAnimationWriterRepresentationProperty.h.
Definition at line 22 of file vtkSIXMLAnimationWriterRepresentationProperty.h.
Reimplemented from vtkSIInputProperty.
overrideprotectedvirtual |
