1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTKExtensions/Misc 3 # Set the install prefix 4 if(NOT DEFINED CMAKE_INSTALL_PREFIX)
5 set(CMAKE_INSTALL_PREFIX
"/usr/local")
7 string(REGEX REPLACE
"/$" "" CMAKE_INSTALL_PREFIX
"${CMAKE_INSTALL_PREFIX}")
12 string(REGEX REPLACE
"${BUILD_TYPE}")
"Release")
17 message(STATUS
23 message(STATUS
"${COMPONENT}")
"0")
37 set(CMAKE_CROSSCOMPILING
"FALSE")
42 set(CMAKE_OBJDUMP
"/usr/bin/objdump")
46 file(INSTALL DESTINATION
"vtkPVVTKExtensionsMisc-hierarchy.txt" FILES
"/builds/gitlab-kitware-sciviz-ci/build/lib64/vtk/hierarchy/ParaView/vtkPVVTKExtensionsMisc-hierarchy.txt")
51 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsMisc-pv6.0.so.6.0
" 52 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsMisc-pv6.0.so.1
" 54 if(EXISTS "${file}
") 58 RPATH "\$ORIGIN:/usr/lib64/openmpi/lib
" TYPE SHARED_LIBRARY FILES 62 "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkPVVTKExtensionsMisc-pv6.0.so.6.0
" 63 "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkPVVTKExtensionsMisc-pv6.0.so.1
" 66 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsMisc-pv6.0.so.6.0
" 67 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsMisc-pv6.0.so.1
" 69 if(EXISTS "${file}
") 73 OLD_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib:
" 74 NEW_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib
" "${file}
" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkPVVTKExtensionsMisc-pv6.0.so
" OR NOT CMAKE_INSTALL_COMPONENT) 90 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-6.0
" TYPE FILE FILES 96 "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/Misc/
vtkMinMax.h
" 99 "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/Misc/
vtkPVBox.h
" 101 "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/Misc/
vtkPVCone.h
" 102 "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/Misc/
vtkPVCylinder.h
" 103 "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/Misc/
vtkPVFrustum.h
" 107 "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/Misc/
vtkPVPlane.h
" 108 "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/Misc/
vtkPVTransform.h
" 115 if(CMAKE_INSTALL_COMPONENT STREQUAL "development
" OR NOT CMAKE_INSTALL_COMPONENT) 116 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-6.0
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/VTKExtensions/Misc/vtkPVVTKExtensionsMiscModule.h
") 119 if(CMAKE_INSTALL_COMPONENT STREQUAL "spdx
" OR NOT CMAKE_INSTALL_COMPONENT) 120 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/doc/ParaView/spdx
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/VTKExtensions/Misc/vtkPVVTKExtensionsMisc.spdx
") Finds the min, max, or sum of all of its input data attributes.
extends vtkFrustum to add ParaView specific API.
filter used to generate text annotation for the current project.
Reduction Filter that uses vtkAppendDataSets as PostGatherHelper.
used to merge rows in tables.
extends vtkBox to add ParaView specific API.
vtkPVChangeOfBasisHelper is designed for ORNL-SNS use-cases where we needed to add support for differ...
Filter adds arrays to empty partitions.
appends rectliner grids together.
used to merge rows in tables from composite datasets.
Reduces cell/point attribute data with different modes to combine cell/point data.
extends vtkPlane to add Offset parameter.
extends vtkCone to add ParaView specific behavior.
extends vtkCylinder to add ParaView specific API.
Serialize/deserialize vtkSelection to/from xml.
A generic filter that can reduce any type of dataset using any reduction algorithm.
