vtkAppendReduceFilter Class Reference
Reduction Filter that uses vtkAppendDataSets as PostGatherHelper. More...
#include <vtkAppendReduceFilter.h>
Inheritance diagram for vtkAppendReduceFilter:
Collaboration diagram for vtkAppendReduceFilter:
typedef vtkReductionFilter Superclass
- Public Types inherited from vtkReductionFilter
enum  ReductionModeType { REDUCE_ALL_TO_ONE = 0, MOVE_ALL_TO_ONE = 1, REDUCE_ALL_TO_ALL = 2 }
enum  Tags { TRANSMIT_DATA_OBJECT = 23484 }
typedef enum vtkReductionFilter::ReductionModeType ReductionModeType
enum  DesiredOutputPrecision
virtual void SetMergePoints (bool)
 Get/Set if the filter should merge coincidental points Defaults to Off. More...
virtual bool GetMergePoints ()
virtual void SetTolerance (double)
 Get/Set the tolerance to use to find coincident points when MergePoints is true. More...
virtual double GetTolerance ()
- Public Member Functions inherited from vtkReductionFilter
void SetController (vtkMultiProcessController *)
 Get/Set the MPI controller used for gathering. More...
virtual void SetReductionMode (int)
 Get/Set the Reduction Mode. More...
virtual int GetReductionMode ()
virtual void SetReductionProcessId (int)
 Get/Set the node to reduce to, default is 0. More...
virtual int GetReductionProcessId ()
void SetPreGatherHelper (vtkAlgorithm *)
 Get/Set the pre-reduction helper. More...
void SetPreGatherHelperName (const char *)
virtual vtkAlgorithmGetPreGatherHelper ()
void SetPostGatherHelper (vtkAlgorithm *)
 Get/Set the reduction helper. More...
void SetPostGatherHelperName (const char *)
virtual vtkAlgorithmGetPostGatherHelper ()
virtual void SetPassThrough (int)
 Get/Set the PassThrough flag which (when set to a nonnegative number N) tells the filter to produce results that come from node N only. More...
virtual int GetPassThrough ()
virtual void SetGenerateProcessIds (int)
 When set, a new array vtkOriginalProcessIds will be added to the output of the the pre-gather helper (or input, if no pre-gather helper is set). More...
virtual int GetGenerateProcessIds ()
vtkDataObjectAlgorithmNewInstance () const
vtkDataObjectGetInput ()
vtkDataObjectGetInput (int port)
vtkDataObjectGetOutput ()
vtkDataObjectGetOutput (int)
int HasExecutive ()
vtkExecutiveGetExecutive ()
int GetNumberOfInputPorts ()
int GetNumberOfOutputPorts ()
void RemoveAllInputs ()
virtual double GetProgress ()
virtual void Update ()
void ReleaseDataFlagOn ()
void ReleaseDataFlagOff ()
intGetUpdateExtent ()
intGetUpdateExtent (int port)
int GetUpdatePiece ()
int GetUpdatePiece (int port)
int GetUpdateGhostLevel ()
static vtkAppendReduceFilterNew ()
static vtkAppendReduceFilterSafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkReductionFilter
static vtkReductionFilterNew ()
static vtkReductionFilterSafeDownCast (vtkObject *o)
static vtkDataObjectAlgorithmNew ()
static vtkDataObjectAlgorithmSafeDownCast (vtkObjectBase *o)
static vtkAlgorithmNew ()
static vtkObjectNew ()
static vtkObjectBaseNew ()
 vtkAppendReduceFilter ()
 ~vtkAppendReduceFilter () override
void Reduce (vtkDataObject *input, vtkDataObject *output) override
 Core function of the filter. More...
- Protected Member Functions inherited from vtkReductionFilter
 vtkReductionFilter ()
 ~vtkReductionFilter () override
int RequestDataObject (vtkInformation *request, vtkInformationVector **inputVector, vtkInformationVector *outputVector) override
vtkDataObjectPreProcess (vtkDataObject *input)
void PostProcess (vtkDataObject *output, vtkSmartPointer< vtkDataObject > inputs[], unsigned int num_inputs)
int GatherSelection (vtkSelection *sendData, std::vector< vtkSmartPointer< vtkDataObject >> &receiveData, int destProcessId)
 Gather for vtkSelection sendData is a vtkSelection while receiveData is a vector of NumberOfProcesses vtkSelections. More...
 vtkDataObjectAlgorithm ()
 ~vtkDataObjectAlgorithm ()
 vtkAlgorithm ()
 ~vtkAlgorithm ()
virtual vtkExecutiveCreateDefaultExecutive ()
 SINGLE_PRECISION
 DOUBLE_PRECISION
 DEFAULT_PRECISION
int AbortExecute
- Protected Attributes inherited from vtkReductionFilter
vtkAlgorithmPreGatherHelper
vtkAlgorithmPostGatherHelper
vtkMultiProcessControllerController
int PassThrough
int GenerateProcessIds
int ReductionMode
int ReductionProcessId
double Progress
char * ProgressText
unsigned long ErrorCode
This filter specializes vtkReductionFilter to use vtkAppendDataSets as PostGatherHelper and expose its MergePoints and Tolerance properties to Paraview
Definition at line 17 of file vtkAppendReduceFilter.h.
Definition at line 22 of file vtkAppendReduceFilter.h.
◆ vtkAppendReduceFilter()
vtkAppendReduceFilter::vtkAppendReduceFilter ( )
◆ ~vtkAppendReduceFilter()
vtkAppendReduceFilter::~vtkAppendReduceFilter ( )
static vtkAppendReduceFilter* vtkAppendReduceFilter::New ( )
virtual const char* vtkAppendReduceFilter::GetClassName ( )
Reimplemented from vtkReductionFilter.
static int vtkAppendReduceFilter::IsTypeOf ( const char *  type)
virtual int vtkAppendReduceFilter::IsA ( const char *  type)
static vtkAppendReduceFilter* vtkAppendReduceFilter::SafeDownCast ( vtkObject o)
void vtkAppendReduceFilter::PrintSelf ( ostream &  os,
◆ SetMergePoints()
virtual void vtkAppendReduceFilter::SetMergePoints ( bool  )
See also
vtkAppendFilter::MergePoints
◆ GetMergePoints()
virtual bool vtkAppendReduceFilter::GetMergePoints ( )
See also
◆ SetTolerance()
virtual void vtkAppendReduceFilter::SetTolerance ( double  )
Default is 0.0.
This is simply passed on to the internal vtkLocator used to merge points.
See also
vtkLocator::SetTolerance.
◆ GetTolerance()
virtual double vtkAppendReduceFilter::GetTolerance ( )
Default is 0.0.
See also
◆ Reduce()
void vtkAppendReduceFilter::Reduce ( vtkDataObject input,
vtkDataObject output
overrideprotectedvirtual
Performs the actual reduction by running the PreGatherHelper and PostGatherHelper algorithms. Must be virtual to allow behavior changes by specialized subclasses.
