A generic filter that can reduce any type of dataset using any reduction algorithm.
void | SetController (vtkMultiProcessController *) |
| Get/Set the MPI controller used for gathering. More...
virtual void | SetReductionMode (int) |
| Get/Set the Reduction Mode. More...
virtual int | GetReductionMode () |
virtual void | SetReductionProcessId (int) |
| Get/Set the node to reduce to, default is 0. More...
virtual int | GetReductionProcessId () |
void | SetPreGatherHelper (vtkAlgorithm *) |
| Get/Set the pre-reduction helper. More...
void | SetPreGatherHelperName (const char *) |
virtual vtkAlgorithm * | GetPreGatherHelper () |
void | SetPostGatherHelper (vtkAlgorithm *) |
| Get/Set the reduction helper. More...
void | SetPostGatherHelperName (const char *) |
virtual vtkAlgorithm * | GetPostGatherHelper () |
virtual void | SetPassThrough (int) |
| Get/Set the PassThrough flag which (when set to a nonnegative number N) tells the filter to produce results that come from node N only. More...
virtual int | GetPassThrough () |
virtual void | SetGenerateProcessIds (int) |
| When set, a new array vtkOriginalProcessIds will be added to the output of the the pre-gather helper (or input, if no pre-gather helper is set). More...
virtual int | GetGenerateProcessIds () |
vtkDataObjectAlgorithm * | NewInstance () const |
virtual void | SetOutput (vtkDataObject *d) |
virtual int | ProcessRequest (vtkInformation *, vtkInformationVector **, vtkInformationVector *) |
int | HasExecutive () |
void | RemoveAllInputs () |
virtual void | Update () |
void | ReleaseDataFlagOn () |
int * | GetUpdateExtent () |
int | GetUpdatePiece () |
virtual void | Modified () |
| vtkReductionFilter () |
| ~vtkReductionFilter () override |
int | FillInputPortInformation (int port, vtkInformation *info) override |
int | RequestDataObject (vtkInformation *request, vtkInformationVector **inputVector, vtkInformationVector *outputVector) override |
int | RequestData (vtkInformation *request, vtkInformationVector **inputVector, vtkInformationVector *outputVector) override |
virtual void | Reduce (vtkDataObject *input, vtkDataObject *output) |
| Core function of the filter. More...
vtkDataObject * | PreProcess (vtkDataObject *input) |
void | PostProcess (vtkDataObject *output, vtkSmartPointer< vtkDataObject > inputs[], unsigned int num_inputs) |
int | GatherSelection (vtkSelection *sendData, std::vector< vtkSmartPointer< vtkDataObject >> &receiveData, int destProcessId) |
| Gather for vtkSelection sendData is a vtkSelection while receiveData is a vector of NumberOfProcesses vtkSelections. More...
virtual vtkObjectBase * | NewInstanceInternal () const |
| vtkDataObjectAlgorithm () |
| ~vtkDataObjectAlgorithm () |
virtual int | RequestInformation (vtkInformation *request, vtkInformationVector **inputVector, vtkInformationVector *outputVector) |
virtual int | FillOutputPortInformation (int port, vtkInformation *info) |
virtual int | RequestUpdateExtent (vtkInformation *, vtkInformationVector **, vtkInformationVector *) |
| vtkAlgorithm () |
| ~vtkAlgorithm () |
virtual void | SetNumberOfInputPorts (int n) |
virtual void | SetNumberOfOutputPorts (int n) |
int | InputPortIndexInRange (int index, const char *action) |
int | OutputPortIndexInRange (int index, const char *action) |
int | GetInputArrayAssociation (int idx, vtkInformationVector **inputVector) |
virtual vtkExecutive * | CreateDefaultExecutive () |
void | ReportReferences (vtkGarbageCollector *) VTK_OVERRIDE |
virtual void | SetNumberOfInputConnections (int port, int n) |
int | GetInputArrayAssociation (int idx, int connection, vtkInformationVector **inputVector) |
int | GetInputArrayAssociation (int idx, vtkDataObject *input) |
vtkDataArray * | GetInputArrayToProcess (int idx, vtkInformationVector **inputVector) |
vtkDataArray * | GetInputArrayToProcess (int idx, vtkInformationVector **inputVector, int &association) |
vtkDataArray * | GetInputArrayToProcess (int idx, int connection, vtkInformationVector **inputVector) |
vtkDataArray * | GetInputArrayToProcess (int idx, int connection, vtkInformationVector **inputVector, int &association) |
vtkDataArray * | GetInputArrayToProcess (int idx, vtkDataObject *input) |
vtkDataArray * | GetInputArrayToProcess (int idx, vtkDataObject *input, int &association) |
vtkAbstractArray * | GetInputAbstractArrayToProcess (int idx, vtkInformationVector **inputVector) |
vtkAbstractArray * | GetInputAbstractArrayToProcess (int idx, vtkInformationVector **inputVector, int &association) |
vtkAbstractArray * | GetInputAbstractArrayToProcess (int idx, int connection, vtkInformationVector **inputVector) |
vtkAbstractArray * | GetInputAbstractArrayToProcess (int idx, int connection, vtkInformationVector **inputVector, int &association) |
vtkAbstractArray * | GetInputAbstractArrayToProcess (int idx, vtkDataObject *input) |
vtkAbstractArray * | GetInputAbstractArrayToProcess (int idx, vtkDataObject *input, int &association) |
vtkInformation * | GetInputArrayFieldInformation (int idx, vtkInformationVector **inputVector) |
virtual void | SetNthInputConnection (int port, int index, vtkAlgorithmOutput *input) |
void | SetInputDataInternal (int port, vtkDataObject *input) |
void | AddInputDataInternal (int port, vtkDataObject *input) |
virtual void | SetErrorCode (unsigned long) |
| vtkObject () |
virtual | ~vtkObject () |
| vtkObjectBase () |
virtual | ~vtkObjectBase () |
| vtkObjectBase (const vtkObjectBase &) |
A generic filter that can reduce any type of dataset using any reduction algorithm. Actual reduction is performed by running the PreGatherHelper and PostGatherHelper algorithms. The PreGatherHelper runs on each node in parallel. Next the intermediate results are gathered to the root node. Then the root node then runs the PostGatherHelper algorithm to produce a single result. The PostGatherHelper must be an algorithm that takes multiple input connections and produces a single reduced output.
In addition to doing reduction the PassThrough variable lets you choose to pass through the results of any one node instead of aggregating all of them together.
Definition at line 32 of file vtkReductionFilter.h.
