#include <pqAnnotationsModel.h>
Inherits QAbstractTableModel.
| enum | ColumnRoles { VISIBILITY = 0, COLOR, OPACITY, VALUE, LABEL, NUMBER_OF_COLUMNS, COLOR_DATA = NUMBER_OF_COLUMNS, OPACITY_DATA } |
| pqAnnotationsModel (QObject *parentObject=nullptr) | |
| ~pqAnnotationsModel () override | |
| int | columnCount () const |
| Return the number of columns. More... | |
| void | setVisibilityDomain (vtkSMStringListDomain *domain) |
| bool | hasColors () const |
| void | reorder (std::vector< int > newOrder) |
| Reorders the list of annotations, following the indexes given by newOrder. More... | |
| Qt::ItemFlags | flags (const QModelIndex &idx) const override |
| Reimplements QAbstractTableModel. More... | |
| int | rowCount (const QModelIndex &prnt=QModelIndex()) const override |
| int | columnCount (const QModelIndex &) const override |
| bool | setData (const QModelIndex &idx, const QVariant &value, int role=Qt::EditRole) override |
| QVariant | data (const QModelIndex &idx, int role=Qt::DisplayRole) const override |
| bool | setHeaderData (int section, Qt::Orientation orientation, const QVariant &value, int role) override |
| QVariant | headerData (int section, Qt::Orientation orientation, int role) const override |
| Qt::DropActions | supportedDropActions () const override |
| QStringList | mimeTypes () const override |
| QMimeData * | mimeData (const QModelIndexList &indexes) const override |
| bool | dropMimeData (const QMimeData *mime_data, Qt::DropAction action, int row, int column, const QModelIndex &parentIdx) override |
| QModelIndex | addAnnotation (const QModelIndex &after=QModelIndex()) |
| Add/remove annotations. More... | |
| QModelIndex | removeAnnotations (const QModelIndexList &toRemove=QModelIndexList()) |
| void | removeAllAnnotations () |
| void | setAnnotations (const std::vector< std::pair< QString, QString >> &newAnnotations, bool quiet=false) |
| Set/Get the value-annotation pairs. More... | |
| std::vector< std::pair< QString, QString > > | annotations () const |
| void | setVisibilities (const std::vector< std::pair< QString, int >> &newVisibilities) |
| Set/Get the visibilities. More... | |
| std::vector< std::pair< QString, int > > | visibilities () const |
| void | setIndexedColors (const std::vector< QColor > &newColors) |
| Set/Get the colors. More... | |
| std::vector< QColor > | indexedColors () const |
| void | setIndexedOpacities (const std::vector< double > &newOpacities) |
| Set/Get IndexedOpacities. More... | |
| std::vector< double > | indexedOpacities () const |
| void | setGlobalOpacity (double opacity) |
| Set/Get the global opacity value. More... | |
| double | globalOpacity () const |
| void | setSelectedOpacity (QList< int > rows, double opacity) |
| Set the opacity for the given rows. More... | |
| void | setSupportsReorder (bool reorder) |
| Set/Get SupportsReorder. More... | |
| bool | supportsReorder () const |
Protected Attributes | |
| double | GlobalOpacity = 1.0 |
| vtkSmartPointer< vtkSMStringListDomain > | VisibilityDomain |
| bool | SupportsReorder = false |
Definition at line 24 of file pqAnnotationsModel.h.
| Enumerator | |
| VISIBILITY | |
| COLOR | |
| OPACITY | |
| VALUE | |
| LABEL | |
| NUMBER_OF_COLUMNS | |
| COLOR_DATA | |
| OPACITY_DATA | |
Definition at line 33 of file pqAnnotationsModel.h.
| pqAnnotationsModel::pqAnnotationsModel | ( | QObject * | parentObject = nullptr | ) |
Definition at line 67 of file pqAnnotationsModel.h.
| void pqAnnotationsModel::setVisibilityDomain | ( | vtkSMStringListDomain * | domain | ) |
| QModelIndex pqAnnotationsModel::addAnnotation | ( | const QModelIndex & | after = QModelIndex() | ) |
| QModelIndex pqAnnotationsModel::removeAnnotations | ( | const QModelIndexList & | toRemove = QModelIndexList() | ) |
| void pqAnnotationsModel::removeAllAnnotations | ( | ) |
| void pqAnnotationsModel::setAnnotations | ( | const std::vector< std::pair< QString, QString >> & | newAnnotations, |
| bool | quiet = false |
Emit dataChanged signal, unless quiet is true.
| std::vector<std::pair<QString, QString> > pqAnnotationsModel::annotations | ( | ) | const |
| void pqAnnotationsModel::setVisibilities | ( | const std::vector< std::pair< QString, int >> & | newVisibilities | ) |
| std::vector<std::pair<QString, int> > pqAnnotationsModel::visibilities | ( | ) | const |
| void pqAnnotationsModel::setIndexedColors | ( | const std::vector< QColor > & | newColors | ) |
Set/Get the colors.
| std::vector<QColor> pqAnnotationsModel::indexedColors | ( | ) | const |
Set/Get the colors.
| bool pqAnnotationsModel::hasColors | ( | ) | const |
| void pqAnnotationsModel::setIndexedOpacities | ( | const std::vector< double > & | newOpacities | ) |
| std::vector<double> pqAnnotationsModel::indexedOpacities | ( | ) | const |
Default is 1.0. GlobalOpacity corresponds to a cached value only used to draw the global opacity swatch. The opacity value of each items is modified using the setHeaderData method. Note that setHeaderData can also modify the GlobalOpacity value.
Definition at line 124 of file pqAnnotationsModel.h.
Definition at line 125 of file pqAnnotationsModel.h.
| void pqAnnotationsModel::setSupportsReorder | ( | bool | reorder | ) |
Default is false.
| bool pqAnnotationsModel::supportsReorder | ( | ) | const |
Default is false.
| void pqAnnotationsModel::reorder | ( | std::vector< int > | newOrder | ) |
Definition at line 149 of file pqAnnotationsModel.h.
Definition at line 150 of file pqAnnotationsModel.h.
Definition at line 151 of file pqAnnotationsModel.h.
1.8.13 on Sun Dec 14 2025
