list of strings More...
#include <vtkSMStringListDomain.h>
typedef vtkSMDomain | Superclass |
enum | IsInDomainReturnCodes { NOT_APPLICABLE = -1, NOT_IN_DOMAIN = 0, IN_DOMAIN = 1 } |
int | IsInDomain (vtkSMProperty *property) override |
Returns true if the value of the property is in the domain. More... | |
int | IsInDomain (const char *string, unsigned int &idx) |
Returns true if the string is in the domain. More... | |
const char * | GetString (unsigned int idx) |
Returns a string in the domain. More... | |
unsigned int | GetNumberOfStrings () |
Returns the number of strings in the domain. More... | |
void | Update (vtkSMProperty *) override |
Update self checking the "unchecked" values of all required properties. More... | |
void | SetAnimationValue (vtkSMProperty *, int, double) override |
Set the value of an element of a property from the animation editor. More... | |
virtual char * | GetNoneString () |
Return the string that is used as "none_string" in XML configuration. More... | |
virtual void | SetNoneString (const char *) |
Is the (unchecked) value of the property in the domain? Overwritten by sub-classes. More... | |
A vtkSMProperty is often defined with a default value in the XML itself. More... | |
Provides access to the vtkSMProperty on which this domain is hooked up. More... | |
Helper method to get the number of input connections hence the number of available vtkPVDataInformation from input proxy connected to the required property with the given function. More... | |
Returns a given required property of the given function. More... | |
When the IsOptional flag is set, IsInDomain() always returns true. More... | |
Helper methods to get vtkPVDataInformation from input proxy connected to the required property with the given function and provided input index. More... | |
virtual vtkPVDataInformation * | GetInputSubsetDataInformation (const char *selector, const char *assemblyName, const char *function, unsigned int index=0) |
virtual void | Modified () |
static vtkSMStringListDomain * | New () |
static vtkSMStringListDomain * | SafeDownCast (vtkObject *o) |
static vtkSMDomain * | New () |
static vtkSMDomain * | SafeDownCast (vtkObject *o) |
static vtkObject * | New () |
int | ReadXMLAttributes (vtkSMProperty *prop, vtkPVXMLElement *element) override |
Set the appropriate ivars from the xml element. More... | |
void | ChildSaveState (vtkPVXMLElement *domainElement) override |
Add the header and creates a new vtkPVXMLElement for the domain, fills it up with the common attributes. More... | |
virtual void | SetStrings (const std::vector< std::string > &strings) |
Call to set the strings. More... | |
const std::vector< std::string > & | GetStrings () |
vtkSMDomain () | |
~vtkSMDomain () override | |
Load the state of the domain from the XML. More... | |
Remove the given property from the required properties list. More... | |
Add a new required property to this domain. More... | |
void | DomainModified () |
Invokes DomainModifiedEvent. More... | |
void | InvokeModified () |
Gets the number of required properties added. More... | |
Set the domain's property. More... | |
vtkSMSessionObject () | |
vtkSMObject () | |
~vtkSMObject () override | |
vtkObject () | |
virtual | ~vtkObject () |
vtkObjectBase () | |
virtual | ~vtkObjectBase () |
Protected Attributes | |
char * | NoneString |
Default string always present in this string list. More... | |
char * | XMLName |
bool | IsOptional |
vtkSMDomainInternals * | Internals |
vtkWeakPointer< vtkSMSession > | Session |
Identifies the session id to which this object is related. More... | |
bool | Debug |
vtkTimeStamp | MTime |
int | SetDefaultValues (vtkSMProperty *, bool use_unchecked_values) override |
vtkSMStringListDomain () | |
~vtkSMStringListDomain () override | |
list of strings
vtkSMStringListDomain represents a domain consisting of a list of strings. It only works with vtkSMStringVectorProperty.
Supported attributes:
none_string:
(optional) when specified, this string appears as the first entry in the domain the list and can be used to show "None", or "Not available" etc.Valid XML elements are:
* * <String value=""> *
Definition at line 32 of file vtkSMStringListDomain.h.
Definition at line 36 of file vtkSMStringListDomain.h.
However, many times, the default value must be determined at run time. To facilitate this, domains can override this method to compute and set the default value for the property. Note that unlike the compile-time default values, the application must explicitly call this method to initialize the property. Returns 1 if the domain updated the property.
Reimplemented in vtkSMArrayListDomain, vtkSMChartSeriesSelectionDomain, vtkSMChartSeriesListDomain, vtkSMDataAssemblyListDomain, vtkSMArraySelectionDomain, vtkSMRepresentationTypeDomain, vtkSMPropArrayListDomain, vtkSMRepresentedArrayListDomain, vtkSMMaterialDomain, vtkSMInputFileNameDomain, vtkSMFileListDomain, and vtkSMRendererDomain.
Reimplemented in vtkSMChartSeriesSelectionDomain, vtkSMChartSeriesListDomain, vtkSMRepresentationTypeDomain, vtkSMRepresentedArrayListDomain, vtkSMMaterialDomain, and vtkSMRendererDomain.
The property has to be a vtkSMStringVectorProperty. If all vector values are in the domain, it returns 1. It returns 0 otherwise.
The pointer may become invalid once the domain has been modified.
unsigned int vtkSMStringListDomain::GetNumberOfStrings | ( | ) |
Reimplemented in vtkSMChartSeriesSelectionDomain, vtkSMChartSeriesListDomain, vtkSMRepresentedArrayListDomain, vtkSMMaterialDomain, and vtkSMRendererDomain.
overrideprotectedvirtual |
The newly created element will also be added to the parent element as a child node. Subclasses can override ChildSaveState() method to fill it up with subclass specific values.
protectedvirtual |
Will fire DomainModifiedEvent if the domain values have indeed changed.
When selected, it is equivalent with not selecting any string.
Definition at line 112 of file vtkSMStringListDomain.h.
