vtkSMStringListDomain.h
23 #ifndef vtkSMStringListDomain_h
24 #define vtkSMStringListDomain_h
25
26 #include "vtkRemotingServerManagerModule.h" //needed for exports
27 #include "vtkSMDomain.h"
28 #include <vector> // needed for vector.
30 struct vtkSMStringListDomainInternals;
31
33 {
34 public:
35  static vtkSMStringListDomain* New();
37  void PrintSelf(ostream& os, vtkIndent indent) override;
38
45  int IsInDomain(vtkSMProperty* property) override;
46
50  int IsInDomain(const char* string, unsigned int& idx);
51
56  const char* GetString(unsigned int idx);
57
61  unsigned int GetNumberOfStrings();
62
67  void Update(vtkSMProperty*) override;
68
72  void SetAnimationValue(vtkSMProperty*, int, double) override;
73
75
78  vtkGetStringMacro(NoneString);
79  vtkSetStringMacro(NoneString);
81
83
93  int SetDefaultValues(vtkSMProperty*, bool use_unchecked_values) override;
94
95 protected:
97  ~vtkSMStringListDomain() override;
99
104  int ReadXMLAttributes(vtkSMProperty* prop, vtkPVXMLElement* element) override;
105
106  void ChildSaveState(vtkPVXMLElement* domainElement) override;
107
112  char* NoneString;
113
115
119  virtual void SetStrings(const std::vector<std::string>& strings);
120  const std::vector<std::string>& GetStrings();
122
123 private:
125  void operator=(const vtkSMStringListDomain&) = delete;
126
127  vtkSMStringListDomainInternals* SLInternals;
128 };
129
130 #endif
virtual void ChildSaveState(vtkPVXMLElement *domainElement)
Add the header and creates a new vtkPVXMLElement for the domain, fills it up with the common attribut...
char * NoneString
Default string always present in this string list.
virtual void SetAnimationValue(vtkSMProperty *, int vtkNotUsed(index), double vtkNotUsed(value))
Set the value of an element of a property from the animation editor.
Definition: vtkSMDomain.h:76
virtual void Update(vtkSMProperty *requestingProperty)
Update self based on the "unchecked" values of all required properties.
virtual int SetDefaultValues(vtkSMProperty *, bool vtkNotUsed(use_unchecked_values))
Definition: vtkSMDomain.h:91
represents the possible values a property can have
Definition: vtkSMDomain.h:37
virtual int ReadXMLAttributes(vtkSMProperty *prop, vtkPVXMLElement *elem)
virtual int IsInDomain(vtkSMProperty *vtkNotUsed(property))
Is the (unchecked) value of the property in the domain? Overwritten by sub-classes.
Definition: vtkSMDomain.h:64
static vtkSMDomain * New()
