35 struct vtkSMDomainInternals;
99 vtkGetStringMacro(XMLName);
109 vtkGetMacro(IsOptional,
bool);
123 const char*
function,
unsigned int index = 0);
125 unsigned int compositeIndex,
const char*
function,
127 const char* selector,
const char* assemblyName,
const char*
function,
135 virtual unsigned int GetNumberOfInputConnections(
const char*
function);
199 void AddRequiredProperty(
vtkSMProperty* prop,
const char*
function);
208 vtkSetMacro(IsOptional,
bool);
224 void DomainModified();
230 unsigned int GetNumberOfRequiredProperties();
282 unsigned int DeferDomainModifiedEventsCount;
283 bool PendingDomainModifiedEvents;
superclass for any server manager classes that are related to a session
IsInDomainReturnCodes
Return values for IsInDomain calls.
virtual void SetAnimationValue(vtkSMProperty *, int vtkNotUsed(index), double vtkNotUsed(value))
Set the value of an element of a property from the animation editor.
virtual int SetDefaultValues(vtkSMProperty *, bool vtkNotUsed(use_unchecked_values))
represents the possible values a property can have
virtual int IsInDomain(vtkSMProperty *vtkNotUsed(property))
Is the (unchecked) value of the property in the domain? Overwritten by sub-classes.
vtkSMDomainInternals * Internals
helper to defer firing of vtkCommand::DomainModifiedEvent.
virtual int LoadState(vtkPVXMLElement *vtkNotUsed(domainElement), vtkSMProxyLocator *vtkNotUsed(loader))
Load the state of the domain from the XML.
static vtkSMSessionObject * New()
