void | Update (vtkSMProperty *) override |
| Overridden to get list of materials from materiallibrary singleton. More...
Public Member Functions inherited from vtkSMStringListDomain |
int | IsInDomain (vtkSMProperty *property) override |
| Returns true if the value of the property is in the domain. More...
int | IsInDomain (const char *string, unsigned int &idx) |
| Returns true if the string is in the domain. More...
const char * | GetString (unsigned int idx) |
| Returns a string in the domain. More...
unsigned int | GetNumberOfStrings () |
| Returns the number of strings in the domain. More...
void | SetAnimationValue (vtkSMProperty *, int, double) override |
| Set the value of an element of a property from the animation editor. More...
virtual char * | GetNoneString () |
| Return the string that is used as "none_string" in XML configuration. More...
virtual void | SetNoneString (const char *) |
int | SetDefaultValues (vtkSMProperty *, bool use_unchecked_values) override |
| A vtkSMProperty is often defined with a default value in the XML itself. More...
| Is the (unchecked) value of the property in the domain? Overwritten by sub-classes. More...
| Provides access to the vtkSMProperty on which this domain is hooked up. More...
| Helper method to get the number of input connections hence the number of available vtkPVDataInformation from input proxy connected to the required property with the given function. More...
| Returns a given required property of the given function. More...
| When the IsOptional flag is set, IsInDomain() always returns true. More...
| Helper methods to get vtkPVDataInformation from input proxy connected to the required property with the given function and provided input index. More...
virtual vtkPVDataInformation * | GetInputSubsetDataInformation (const char *selector, const char *assemblyName, const char *function, unsigned int index=0) |
virtual void | Modified () |
| vtkSMMaterialDomain () |
| ~vtkSMMaterialDomain () override |
int | ReadXMLAttributes (vtkSMProperty *prop, vtkPVXMLElement *element) override |
| Set the appropriate ivars from the xml element. More...
void | CallMeSometime () |
Protected Member Functions inherited from vtkSMStringListDomain |
void | ChildSaveState (vtkPVXMLElement *domainElement) override |
| Add the header and creates a new vtkPVXMLElement for the domain, fills it up with the common attributes. More...
virtual void | SetStrings (const std::vector< std::string > &strings) |
| Call to set the strings. More...
const std::vector< std::string > & | GetStrings () |
| vtkSMStringListDomain () |
| ~vtkSMStringListDomain () override |
| vtkSMDomain () |
| ~vtkSMDomain () override |
| Load the state of the domain from the XML. More...
| Remove the given property from the required properties list. More...
| Add a new required property to this domain. More...
void | DomainModified () |
| Invokes DomainModifiedEvent. More...
void | InvokeModified () |
| Gets the number of required properties added. More...
| Set the domain's property. More...
| vtkSMSessionObject () |
| ~vtkSMSessionObject () override |
| vtkSMObject () |
| ~vtkSMObject () override |
| vtkObject () |
virtual | ~vtkObject () |
| vtkObjectBase () |
virtual | ~vtkObjectBase () |
| vtkObjectBase (const vtkObjectBase &) |
Manages the list of OSPRay materials choosable to draw with.
This class is a link between the global MaterialLibrary and the choices available on the display section of the Property Panel. When ParaView has no materials loaded, the list is simply "None" and not useable. When materials are loaded, the list lets the user pick None, any one for whole actor colors, or 'Value Indexed' which says that each block and cell gets to make its own choice via the indexed lookup table annotation names.
Definition at line 24 of file vtkSMMaterialDomain.h.
