void | Update (vtkSMProperty *requestingProperty) override |
| Update self based on the "unchecked" values of all required properties. More...
int | SetDefaultValues (vtkSMProperty *, bool use_unchecked_values) override |
virtual void | SetBackwardCompatibilityMode (bool) |
| When set to true, the domain will use the old functionality setting the assembly default value. More...
virtual bool | GetBackwardCompatibilityMode () |
virtual void | BackwardCompatibilityModeOn () |
virtual void | BackwardCompatibilityModeOff () |
Public Member Functions inherited from vtkSMStringListDomain |
int | IsInDomain (vtkSMProperty *property) override |
| Returns true if the value of the property is in the domain. More...
int | IsInDomain (const char *string, unsigned int &idx) |
| Returns true if the string is in the domain. More...
const char * | GetString (unsigned int idx) |
| Returns a string in the domain. More...
unsigned int | GetNumberOfStrings () |
| Returns the number of strings in the domain. More...
void | Update (vtkSMProperty *) override |
| Update self checking the "unchecked" values of all required properties. More...
void | SetAnimationValue (vtkSMProperty *, int, double) override |
| Set the value of an element of a property from the animation editor. More...
virtual char * | GetNoneString () |
| Return the string that is used as "none_string" in XML configuration. More...
virtual void | SetNoneString (const char *) |
| A vtkSMProperty is often defined with a default value in the XML itself. More...
| Is the (unchecked) value of the property in the domain? Overwritten by sub-classes. More...
| Provides access to the vtkSMProperty on which this domain is hooked up. More...
| Helper method to get the number of input connections hence the number of available vtkPVDataInformation from input proxy connected to the required property with the given function. More...
| Returns a given required property of the given function. More...
| When the IsOptional flag is set, IsInDomain() always returns true. More...
| Helper methods to get vtkPVDataInformation from input proxy connected to the required property with the given function and provided input index. More...
virtual vtkPVDataInformation * | GetInputSubsetDataInformation (const char *selector, const char *assemblyName, const char *function, unsigned int index=0) |
virtual void | Modified () |
| vtkSMDataAssemblyListDomain () |
| ~vtkSMDataAssemblyListDomain () override |
Protected Member Functions inherited from vtkSMStringListDomain |
int | ReadXMLAttributes (vtkSMProperty *prop, vtkPVXMLElement *element) override |
| Set the appropriate ivars from the xml element. More...
void | ChildSaveState (vtkPVXMLElement *domainElement) override |
| Add the header and creates a new vtkPVXMLElement for the domain, fills it up with the common attributes. More...
virtual void | SetStrings (const std::vector< std::string > &strings) |
| Call to set the strings. More...
const std::vector< std::string > & | GetStrings () |
| vtkSMStringListDomain () |
| ~vtkSMStringListDomain () override |
| vtkSMDomain () |
| ~vtkSMDomain () override |
| Load the state of the domain from the XML. More...
| Remove the given property from the required properties list. More...
| Add a new required property to this domain. More...
void | DomainModified () |
| Invokes DomainModifiedEvent. More...
void | InvokeModified () |
| Gets the number of required properties added. More...
| Set the domain's property. More...
| vtkSMSessionObject () |
| ~vtkSMSessionObject () override |
| vtkSMObject () |
| ~vtkSMObject () override |
| vtkObject () |
virtual | ~vtkObject () |
| vtkObjectBase () |
virtual | ~vtkObjectBase () |
| vtkObjectBase (const vtkObjectBase &) |
domain listing available assembly types in the input
vtkSMDataAssemblyListDomain is a string-list domain subclass that populates the list with names of assemblies available in the input.
Example usage is as follows:
<SourceProxy ...>
<StringVectorProperty name="BlockAssembly"
command="SetSelectorAssembly"
number_of_elements="1">
<DataAssemblyListDomain name="data_assembly_list">
<RequiredProperties>
<Property function="Input" name="Input" />
</RequiredProperties>
</DataAssemblyListDomain>
</StringVectorProperty>
</SourceProxy>
Definition at line 33 of file vtkSMDataAssemblyListDomain.h.
