int | SetDefaultValues (vtkSMProperty *, bool use_unchecked_values) override |
| Since this domain relies on an information only property to get the default status, we override this method to copy the values the info property as the default array selection. More...
Public Member Functions inherited from vtkSMStringListDomain |
int | IsInDomain (vtkSMProperty *property) override |
| Returns true if the value of the property is in the domain. More...
int | IsInDomain (const char *string, unsigned int &idx) |
| Returns true if the string is in the domain. More...
const char * | GetString (unsigned int idx) |
| Returns a string in the domain. More...
unsigned int | GetNumberOfStrings () |
| Returns the number of strings in the domain. More...
void | Update (vtkSMProperty *) override |
| Update self checking the "unchecked" values of all required properties. More...
void | SetAnimationValue (vtkSMProperty *, int, double) override |
| Set the value of an element of a property from the animation editor. More...
virtual char * | GetNoneString () |
| Return the string that is used as "none_string" in XML configuration. More...
virtual void | SetNoneString (const char *) |
| A vtkSMProperty is often defined with a default value in the XML itself. More...
| Is the (unchecked) value of the property in the domain? Overwritten by sub-classes. More...
| Provides access to the vtkSMProperty on which this domain is hooked up. More...
| Helper method to get the number of input connections hence the number of available vtkPVDataInformation from input proxy connected to the required property with the given function. More...
| Returns a given required property of the given function. More...
| When the IsOptional flag is set, IsInDomain() always returns true. More...
| Helper methods to get vtkPVDataInformation from input proxy connected to the required property with the given function and provided input index. More...
virtual vtkPVDataInformation * | GetInputSubsetDataInformation (const char *selector, const char *assemblyName, const char *function, unsigned int index=0) |
virtual void | Modified () |
