#include <pqArrayStatusPropertyWidget.h>
| pqArrayStatusPropertyWidget (vtkSMProxy *proxy, vtkSMPropertyGroup *group, QWidget *parent=nullptr) | |
| pqArrayStatusPropertyWidget (vtkSMProxy *proxy, vtkSMProperty *property, QWidget *parent=nullptr) | |
| ~pqArrayStatusPropertyWidget () override | |
| virtual void | apply () |
| virtual void | reset () |
| pqView * | view () const |
| bool | showLabel () const |
| virtual void | setReadOnly (bool readOnly) |
| Set widget in read-only mode. More... | |
| virtual void | select () |
Friends | |
| class | pqInternals |
| void | changeAvailable () |
| void | changeFinished () |
| void | restartRequired () |
| template<class T > | |
Definition at line 14 of file pqArrayStatusPropertyWidget.h.
| pqArrayStatusPropertyWidget::pqArrayStatusPropertyWidget | ( | vtkSMProxy * | proxy, |
| vtkSMPropertyGroup * | group, | ||
| vtkSMProperty * | property, | ||
friend |
Definition at line 31 of file pqArrayStatusPropertyWidget.h.
1.8.13 on Sun Dec 14 2025
