pqCTHArraySelectionDecorator is used by ExtractCTH filter (and similar filters) to ensure only 1 of the array-selection properties is set at any given time. More...
#include <pqCTHArraySelectionDecorator.h>
| pqCTHArraySelectionDecorator (vtkPVXMLElement *config, pqPropertyWidget *parent) | |
| ~pqCTHArraySelectionDecorator () override | |
Public Member Functions inherited from pqPropertyWidgetDecorator | |
| pqPropertyWidgetDecorator (vtkPVXMLElement *xml, pqPropertyWidget *parent) | |
| Constructor. More... | |
| ~pqPropertyWidgetDecorator () override | |
| pqPropertyWidget * | parentWidget () const |
| Returns the pqPropertyWidget parent. More... | |
| virtual bool | canShowWidget (bool show_advanced) const |
| Override this method to override the visibility of the widget in the panel. More... | |
| virtual bool | enableWidget () const |
| Override this method to override the enable state of the widget in the panel. More... | |
Signals inherited from pqPropertyWidgetDecorator | |
| void | visibilityChanged () |
| This signal is fired whenever the decorator has determined that the panel may need a refresh since the state of the system has changed which would deem changes in the widget visibility or enable state. More... | |
| void | enableStateChanged () |
Static Public Member Functions inherited from pqPropertyWidgetDecorator | |
| static pqPropertyWidgetDecorator * | create (vtkPVXMLElement *xml, pqPropertyWidget *parent) |
| Creates a new decorator, given the xml config and the parent pqPropertyWidget for the decorator. More... | |
Protected Member Functions inherited from pqPropertyWidgetDecorator | |
| vtkPVXMLElement * | xml () const |
When the user changes the state of a selection property, selections on other properties are cleared.
Definition at line 16 of file pqCTHArraySelectionDecorator.h.
| pqCTHArraySelectionDecorator::pqCTHArraySelectionDecorator | ( | vtkPVXMLElement * | config, |
| pqPropertyWidget * | parent | ||
1.8.13 on Sun Dec 14 2025
