pqCalculatorWidget is a property-widget that can shows a calculator-like UI for the property. More...
#include <pqCalculatorWidget.h>
| pqCalculatorWidget (vtkSMProxy *proxy, vtkSMProperty *property, QWidget *parent=nullptr) | |
| ~pqCalculatorWidget () override | |
| virtual void | apply () |
| virtual void | reset () |
| pqView * | view () const |
| bool | showLabel () const |
| virtual void | setReadOnly (bool readOnly) |
| Set widget in read-only mode. More... | |
| virtual void | select () |
Protected Slots | |
| void | variableChosen (QAction *action) |
| called when the user selects a variable from the scalars/vectors menus. More... | |
| void | buttonPressed (const QString &) |
| called when user clicks one of the function buttons More... | |
| void | updateVariableNames () |
| updates the variables in the menus. More... | |
| void | updateVariables (const QString &mode) |
| void | updateButtons () |
| Update button labels based on which function parser is active. More... | |
| void | changeAvailable () |
| void | changeFinished () |
| void | restartRequired () |
| template<class T > | |
It is designed to be used with vtkPVArrayCalculator (or similar) filters. It allows users to enter expressions to compute derived quantities. To determine the list of input arrays available.
CAVEATS: Currently, this widget expects two additional properties on the proxy: "Input", that provides the input and "AttributeMode", which corresponds to the chosen attribute type. This code can be revised to use RequiredProperties on the domain to make it reuseable, if needed.
Definition at line 20 of file pqCalculatorWidget.h.
| pqCalculatorWidget::pqCalculatorWidget | ( | vtkSMProxy * | proxy, |
| vtkSMProperty * | property, | ||
protectedslot |
protectedslot |
protectedslot |
protectedslot |
protectedslot |
1.8.13 on Sun Dec 14 2025
