pqCameraManipulatorWidget used on "Camera2DManipulators" and "Camera3DManipulators" property on a RenderView proxy.
#include <pqCameraManipulatorWidget.h>
template<class T > |
static QString | getXMLName (T *object) |
| Description: This static utility method returns the XML name for an object as a QString. More...
static QString | getTooltip (vtkSMProperty *property) |
| Returns the tooltip to use for the property. More...
static int | hintsWidgetHeightNumberOfRows (vtkPVXMLElement *hints, int defaultValue=10) |
| Helper method to return value from WidgetHeight XML hint, if any. More...
static std::vector< std::string > | parseComponentLabels (vtkPVXMLElement *hints, unsigned int elemCount=0) |
| Parse a XML element as a list of label to use for this widget. More...
void | addPropertyLink (QObject *qobject, const char *qproperty, const char *qsignal, vtkSMProperty *smproperty, int smindex=-1) |
void | addPropertyLink (QObject *qobject, const char *qproperty, const char *qsignal, vtkSMProxy *smproxy, vtkSMProperty *smproperty, int smindex=-1) |
void | removePropertyLink (QObject *qobject, const char *qproperty, const char *qsignal, vtkSMProperty *smproperty, int smindex=-1) |
void | removePropertyLink (QObject *qobject, const char *qproperty, const char *qsignal, vtkSMProxy *smproxy, vtkSMProperty *smproperty, int smindex=-1) |
void | setShowLabel (bool show) |
void | setChangeAvailableAsChangeFinished (bool status) |
| For most pqPropertyWidget subclasses a changeAvailable() signal, corresponds to a changeFinished() signal. More...
void | addDecorator (pqPropertyWidgetDecorator *) |
| Register a decorator. More...
void | removeDecorator (pqPropertyWidgetDecorator *) |
| Unregisters a decorator. More...
pqPropertyLinks & | links () |
| Provides access to the pqPropertyLinks instance. More...
Definition at line 14 of file pqCameraManipulatorWidget.h.
◆ pqCameraManipulatorWidget()
pqCameraManipulatorWidget::pqCameraManipulatorWidget |
vtkSMProxy * |
proxy, |
vtkSMProperty * |
smproperty, |
QWidget * |
parent = nullptr |
◆ ~pqCameraManipulatorWidget()
pqCameraManipulatorWidget::~pqCameraManipulatorWidget |
◆ manipulatorTypes()
QList<QVariant> pqCameraManipulatorWidget::manipulatorTypes |
const |
returns a list for the selected manipulator types.
This has exactly 9 items always.
◆ setManipulatorTypes
void pqCameraManipulatorWidget::setManipulatorTypes |
const QList< QVariant > & |
value | ) |
slot |
Set the manipulator types selection.
This must have exactly 9 items or less. Any missing items are treated as "None".
◆ manipulatorTypesChanged
void pqCameraManipulatorWidget::manipulatorTypesChanged |
signal |
◆ manipulatorTypes
readwrite |
