This is a pqPropertyWidget subclass that presents a widget to edit the color of a representation and other related functionality. More...
#include <pqColorEditorPropertyWidget.h>
| typedef pqPropertyWidget | Superclass |
| pqColorEditorPropertyWidget (vtkSMProxy *proxy, QWidget *parent=nullptr, int selectedPropertiesType=0) | |
| ~pqColorEditorPropertyWidget () override | |
| virtual void | apply () |
| virtual void | reset () |
| pqView * | view () const |
| bool | showLabel () const |
| virtual void | setReadOnly (bool readOnly) |
| Set widget in read-only mode. More... | |
| virtual void | select () |
| void | changeAvailable () |
| void | changeFinished () |
| void | restartRequired () |
| template<class T > | |
It's used as the "widget" for ColorEditor/BlockColorEditor property group.
Definition at line 16 of file pqColorEditorPropertyWidget.h.
Definition at line 20 of file pqColorEditorPropertyWidget.h.
| pqColorEditorPropertyWidget::pqColorEditorPropertyWidget | ( | vtkSMProxy * | proxy, |
| QWidget * | parent = nullptr, |
| int | selectedPropertiesType = 0 |
1.8.13 on Sat Dec 13 2025
