A property widget with a tool button for selecting a single color. More...
#include <pqColorSelectorPropertyWidget.h>
| pqColorSelectorPropertyWidget (vtkSMProxy *proxy, vtkSMProperty *property, bool withPalette, QWidget *parent=nullptr) | |
| ~pqColorSelectorPropertyWidget () override | |
| virtual void | apply () |
| virtual void | reset () |
| pqView * | view () const |
| bool | showLabel () const |
| virtual void | setReadOnly (bool readOnly) |
| Set widget in read-only mode. More... | |
| virtual void | select () |
| void | changeAvailable () |
| void | changeFinished () |
| void | restartRequired () |
| template<class T > | |
To use this widget for a property add the 'panel_widget="color_selector"' attribute to the property's XML. To use this widget for a property whose color might possibly come from the global color palette, add the 'panel_widget="color_selector_with_palette"' attribute to the property's XML.
Definition at line 19 of file pqColorSelectorPropertyWidget.h.
| pqColorSelectorPropertyWidget::pqColorSelectorPropertyWidget | ( | vtkSMProxy * | proxy, |
| vtkSMProperty * | property, | ||
| bool | withPalette, | ||
1.8.13 on Sun Dec 14 2025
