Public Member Functions | Protected Slots | List of all members
pqCommandPropertyWidget Class Reference
pqCommandPropertyWidget is used for vtkSMProperty instances (not one of its subclasses). More...
#include <pqCommandPropertyWidget.h>
Inheritance diagram for pqCommandPropertyWidget:
Collaboration diagram for pqCommandPropertyWidget:
 pqCommandPropertyWidget (vtkSMProperty *property, vtkSMProxy *proxy, QWidget *parent=nullptr)
 ~pqCommandPropertyWidget () override
 ~pqPropertyWidget () override
virtual void apply ()
virtual void reset ()
pqViewview () const
vtkSMProxyproxy () const
vtkSMPropertyproperty () const
bool showLabel () const
virtual void setReadOnly (bool readOnly)
 Set widget in read-only mode. More...
virtual void select ()
virtual void deselect ()
bool isSelected () const
Protected Slots
virtual void buttonClicked ()
 called when the button is clicked by the user. More...
void changeAvailable ()
void changeFinished ()
void restartRequired ()
template<class T >
static std::vector< std::stringparseComponentLabels (vtkPVXMLElement *hints, unsigned int elemCount=0)
void setShowLabel (bool show)
 Register a decorator. More...
pqPropertyLinkslinks ()
It simply creates a button that the users can press. Unlike other pqPropertyWidget subclasses, the result of clicking this button does not affect the state of the Apply/Reset buttons. It triggers the action prompted by the property immediately.
Definition at line 16 of file pqCommandPropertyWidget.h.
◆ pqCommandPropertyWidget()
pqCommandPropertyWidget::pqCommandPropertyWidget ( vtkSMProperty property,
vtkSMProxy proxy,
QWidget *  parent = nullptr
◆ ~pqCommandPropertyWidget()
pqCommandPropertyWidget::~pqCommandPropertyWidget ( )
override
◆ buttonClicked
virtual void pqCommandPropertyWidget::buttonClicked ( )
protectedvirtualslot
